Don't have point B (cycle process)
In summary: V_b)^{\gamma-1} is this right?Yes, that's right. Now you have an equation with a single unknown (V_b), which you can solve for.Yes, that's right. Now you have an equation with a single unknown (V_b), which you can solve for.so it would be like this...4.40x10^5 Pa*m^3= (1.6x10^5Pa*m^3) (V_b)^{0.67} then I put logs on both sides...log (4.40x10^5 Pa*m^3)= log (1.6x10^5Pa*m^3) (V
~christina~
One mole of helium is enclosed in a cylinder with a movable piston. By placing the cylinder in contact with various reservoirs and also insulating it at proper times, the helium performs a cycle. Compute the internal energy change, heat transferred, and work perfomed for each segment of the cyle and the total amount of each of these quantities for the entire cyle. Assume helium to be an ideal gas.
http://img179.imageshack.us/img179/4843/graphnc4.th.jpg
[tex]\Delta U= Q + W [/tex]
PV= nRT
[tex]Q= nC_p \Delta T[/tex]
[tex] Q= nC_v \Delta T[/tex]
[tex]\gamma= C_p / C_v = 1.67[/tex]
[tex]C_v= 3/2R [/tex]
[tex]C_p= 5/2R[/tex]
B is unknown but not sure how to find it...
I do have Parts:
A=> P= 8.00x10^4Pa, V= 2.00m^3
B=> P= ? V=?
C=> P= 3.00x10^4 Pa, V= 5.00m^3
D=> P= 3.00x10^4 Pa, V= 2.00m^3
For DA which is isovolumetric
w= 0
[tex]\Delta U= Q [/tex] for U
[tex]\Delta Q= nCv (T_D-T_A) [/tex] for finding heat (Q)
[tex] \Delta E_{int}= C_v \Delta T[/tex] => however I'm not given T so what do I do?
do I use PV= nRT and then solve for T since I have P and V ? so
[tex] \Delta P V /nR = \Delta T[/tex]
For CD which is Isobaric
P= constant
[tex]W= -P(V_F-V_i) [/tex] for the internal E
[tex] \E_{int}= Q + W [/tex] for the work
[tex] PV= nRT [/tex]
[tex] Q= nCP \Delta T [/tex]
[tex] \E _{int}= ? [/tex] not sure about this
For the part AB It is isothermic
T= constant
[tex]T_A= T_B [/tex]
[tex]\Delta U= nR\Delta T= 0 [/tex] internal Energy which is = 0
so based on above [tex] Q= -W[/tex] to find the heat
[tex]P_A= 8.00x10^4 Pa [/tex]
[tex]P_A= 2.00 m^3 [/tex]
[tex]W= nRT ( /frac{V_A} {V_B}) [/tex] => don't have V for the final VB
For part BC
It's adiabatic so Q= 0 thus
[tex] \Delta U= W [/tex]
point B is not known (P or V) initial point
[tex]P_iV_i^{\gamma} = P_iV_f^{\gamma}[/tex]
not sure how to find the [tex]\Delta U[/tex] and that would also = W but if I don't find those then how can I find the W?
Point B
I don't have the P or V for point B so I'm not exactly sure how to find the info I need.
I think that for the [tex]\Delta U= 0 [/tex]
[tex]P_iV_i^{\gamma} = P_fV_f^{\gamma}[/tex]
so I think I can find the V and P. But don't you have to be given [tex]\gamma[/tex] ? or is it a constant?
Well after finding the Pf I was thinking of using the fact that the AB is isothermic and plugging into this..
[tex]Q= W= P_AV_A ln (V_B/V_A)[/tex]
Is this it..I think so but I think I'm missing some things here and there on actually solving this with numbers.
Could someone check it for me?
Thank you.
~christina~ said:
Point B
Here's a tip about finding point B. Point A and B are connected via an isothermal. Similarly, point C and B are connected via an adiabatic expansion. That should allow you to find P and V for point B.
I don't know but I tried to find the volume for b by the equation that I used above but I'm not sure what gamma is and I still don't know how to find the pressure for b.
Treat the helium as an ideal monoatomic gas--that should tell you what gamma is.
Relating point A to point B (isothermal):
[tex]P_a V_a = P_b V_b[/tex]
Relating point C to point B (adiabatic):
[tex]P_c V_c^{\gamma} = P_b V_b^{\gamma} [/tex]
Two equations; two unknowns. :wink:
okay so [tex]\gamma= 1.67 [/tex]
so I have the [tex]P_a= 8.00x10^4Pa [/tex] and [tex] V_a= 2.00m^3 [/tex]
so [tex] P_aV_a= P_bV_b= 1.6x10^5Pa*m^3 [/tex]
well for this [tex]P_cV_c^{\gamma} = (3.00x10^4 Pa)(5.00m^3)^{1.67}= 4.40x10^5 Pa*m^3= P_b V_b^{\gamma} [/tex]
um..:confused: what do I do now? I don't think I can substitute one into the other and or etc. Am I missing something else, Doc?
Why not? Use one equation to write [itex]P_b[/itex] in terms of [itex]V_b[/itex], then plug that into the second.
okay, but I guess my algebra's then
this is what I did.
PaVa=PbVb then
[tex]P_b =1.6x10^5Pa*m^3 /V_b[/tex] then I plug that into the other equation...
[tex] 4.40x10^5 Pa*m^3= \frac{1.6x10^5Pa*m^3} {V_b} V_b^{\gamma} [/tex]
and that would cancel the Vb? (I don't think so)
Recall this property of exponents:
[tex]\frac{X^a}{X^b} = X^{a-b}[/tex]
unless you mean that
it would be..
and so based on the rule that I forgot...
[tex] 4.40x10^5 Pa*m^3= (1.6x10^5Pa*m^3) (V_b)^{\gamma-0} [/tex]
is this correct?
~christina~ said:
is this correct?
No.
[tex]\frac{X^a}{X} = \frac{X^a}{X^1} = X^{a-1}[/tex]
Doc Al said:
No.
so it would be this...
[tex] 4.40x10^5 Pa*m^3= (1.6x10^5Pa*m^3) (V_b)^{\gamma-1} [/tex]
Now you're cooking. :smile: (Although I didn't check your numbers.)
Now you should be able to solve for [itex]V_b[/itex] (using a calculator, of course!).
Okay so if that's like that then.
[tex]2.75= Vb^{.67}[/tex]
so
Vb= 4.52 m^3
and then since I have Vb
PaVa=PbVb
[tex]1.6x10^5 Pa m^3= Pb(4.52m^3) [/tex]
[tex]Pb= 1.017x10^5Pa[/tex]
um that looks funny though since the graph has Pa is 10^4...
Yeah, something's not right. Check your values for volume: Realize that the values on the diagram need to be muliplied by [itex]10^{-3}[/itex].
so [tex] P_aV_a= P_bV_b= 1.6x10^2Pam^3[/tex]
so then [tex]Pb= 1.6x10^2 Pam^3/Vb[/tex]
[tex]P_cV_c^{\gamma} = (3.00x10^4 Pa)(5.00x10^-3)^{1.67}= 4.30 Pa*m^3= P_b V_b^{\gamma} [/tex]
[tex] 4.30 Pa*m^3= (1.6x10^2Pa m^3) (V_b)^{\gamma-1} [/tex]
[tex]2.68x10^-2= V_b^{.67}[/tex]
[tex]V_b= 4.52x10^-3 m^3[/tex]
[tex]P_aV_a= P_bV_b[/tex]
[tex]\frac{1.6x10^2Pam^3} {4.52x10^-3m^3} = P_b [/tex]
[tex]P_b= 3.54x10^4 Pa[/tex]
I think I got it.
Now to find the work what do I do? since I know that the point b) is both an isotherm and a adiabat.
you didn't say whether this was right or not but assuming it is.
w= 0
[tex] \Delta U= C_v \Delta T[/tex] => however I'm not given T so what do I do?
[tex]\Delta T= \frac{(8.00x10^4-3.00x10^4)(2x10^-3)} {(1mol)(8.314472 m3·Pa·K·mol)} = 6.013x10^3 K [/tex]
and I think I take that and plug this below to find the [tex]E_{int} [/tex]
and since Cv= 12.5 for He
[tex]\Delta U= nC_v \Delta T = 1mol(12.5)(6.013x10^3 K)= 7.516x10^4 J [/tex]
and [tex]\Delta U= Q= 7.516x10^4 J [/tex] right?
and W= 0
P= constant
[tex]W= -(3.00x10^4Pa)(5.00x10^{-3}- 2.00x10^{-3})= -9x10^8 J [/tex]
[tex]Q= (1mol)(20.8J/mol*K)= 20.8 J[/tex]
[tex] \Delta U= Q + W [/tex] for the work
so it would be
[tex]\Delta U= 20.8J + -9x10^8J= -8.99x10^8 J [/tex]
Last part.
For part BC
[tex]Point C=> P_f= 3.00x10^4 Pa, V_f= 5.00m^3[/tex]
I found the Vi and Pi though before (assuming their correct)
not sure how I find the work though...and it's equal to the U
so I need help on that. I think you have to take take the integral of the area under the curve but not sure how that would be set up unfortunately.
Thanks Doc Al :smile:
I think I got it.
Looks good! Be careful with terminology: On a P-V diagram only lines can be isotherms or adiabats, not points.
w= 0
and W= 0
Your methodology is correct, but redo your calculation of delta T and what follows. (You forgot to multiply by the volume.)
P= constant
This is work, not internal energy (of course).
Redo this calculation. Also, since the gas is being compressed, the work done on it will be positive.
Redo this. What's delta T?
so it would be
You'll have to redo this, given the above.
~christina~ said:
Last part.
For part BC
Yes, you'll have to integrate:
[tex]W = -\int p dV[/tex]
Hint: Write p as a function of V, taking advantage of [itex]pV^{\gamma} = C[/itex] (where C is a constant).
oh okay.
[tex]\Delta T= \frac{(8.00x10^4-3.00x10^4)(2x10^-3)} {(1mol)(8.314472 m3·Pa·K·mol)} = 12.027 K [/tex]
[tex]\Delta U= nC_v \Delta T = 1mol(12.5)(12.027K)= J [/tex]
[tex]\Delta U= Q= 150.3375 J [/tex]
um yes :rolleyes:
Oh yeah, I forgot about that.
[tex]W= -(3.00x10^4Pa)(2.00x10^{-3}-5.00x10^{-3} )= 90 J [/tex]
[tex]W=nR \Delta T[/tex]
[tex]90J= 1mol (8.314472 m3·Pa·K·1·mol-1 )\Delta T [/tex]
[tex]\frac{90J} {1mol (8.314472 m3·Pa·K·1·mol-1)}= 10.82K[/tex]
[tex]Q= (1mol)(20.8J/mol*K)(10.82K)= 225.056 J[/tex]
you'll have to redo this, given the above.
[tex]\Delta U= 225.056J + 90J= 315.056 J [/tex]
hm..my teacher gave us a hint on this part and he said to use PV=nRT though. I would say that relates to [itex]pV^{\gamma} = C[/itex] but it doesn't include the gamma on the V so is it related?
I have issues with integration.
Thank you very much Doc Al :smile:
Your numbers look much better.
As far as finding the work done in an adiabatic process, I don't quite see the point of your teacher's hint. PV=nRT applies to all ideal gas processes, not just adiabatic ones.
Give my previous suggestion a shot and try to set it up properly. Then we'll worry about doing the integration. (It will turn out to be an easy integral. :wink:)
okay. (sorry about the late post-few tests this week)
[tex]W= -\int p dV= C \int \frac{dV} {V^{\gamma}}[/tex]
and I think that's weird looking. Is it? (Okay I found this online but I'm not sure how they did the integration to get=> [tex]W= \frac{C(V_f^{1-\gamma}- V_i^{1-\gamma})} {1-\gamma}[/tex]
Thank you Doc Al
Well, what's the integral of [itex]x^n[/itex]? Of [itex]x^{-n}[/itex]?
[tex]\int x^n= \frac {x^{n+1}} {n+1} [/tex] n not = -1
[tex]\int x^{-n}= \frac {x^{-n+1}} {-n+1} [/tex] as long as x not = 1 but I think this one is wrong though.
Thanks Doc :smile:
All perfectly correct! If you think the second one is wrong, check it by taking the derivative of the answer. :wink:
Once you are convinced that both are correct, compare the second one with the integral you need for this problem.
okay I did and the other with the negative is fine.
I was wondering if there was supposed to be a (-) in the second part above. (the example I saw on the net didn't but why is that?)
[tex]\int x^{-n}= \frac {x^{1-n}} {1-n} [/tex] [itex]rearranged[/itex]
well the last thing is that I wasn't getting how they had Vf and Vi but I figured it out that it's because of the initial and final Volumes BUT if the pressure is not constant then why don't we include Pi and Pf??
Thanks Doc
Since [itex]PV^\gamma = C[/itex], P and V are not independent variables. We chose to evaluate [itex]\int Pdv[/itex] using the variable V. But we could easily have changed variables and wrote it in term of P, in which case we would have used Pi & Pf.
  • #31
Since , P and V are not independent variables. We chose to evaluate using the variable But we could easily have changed variables and wrote it in term of P, in which case we would have used Pi & Pf.
I forgot AB for isothermal process
T= constant
[tex]Q=-W[/tex]
[tex]W= nRT ( \frac{V_A} {V_B}) [/tex]
thanks
  • #32
Almost. You're missing a natural log.
  • #33
Okay I think I get it.
[tex]W= nRT ln ( \frac{V_A} {V_B}) [/tex]
I think I get how it gets to this [tex]W= \frac{C(V_f^{1-\gamma}- V_i^{1-\gamma})} {1-\gamma}[/tex]
is it negative because you are taking the integral of [tex]\frac{1} {V^{\gamma}}[/tex] so it is actually [tex]V^{-\gamma} [/tex] ?
if it is then why did you put a negative in the integral at the begining?
I know it's like the neverending thread, so I promise that that was my last question. :biggrin:
Thank You Doc Al.
  • #34
~christina~ said:
[tex]W= -\int p dV[/tex]
If you're asking about the negative sign in this equation, it's there because you want the work done on the gas. [itex]\int p dV[/itex] by itself is the work done by the gas.
  • #35
but if there is work that is done by the gas (vol increasing) then it should be + then ? (in this case)
I understand it as if the vol increases then there is work doen by the gas.
If the volume decreases then there is work on the gas.
Thanks.
