Conical Tank Water Drainage: Finding Time to Empty with Differential Equations
  • Thread starter Thread starter chae
    Conical Tank
The discussion focuses on solving a differential equation related to the drainage of water from an inverted conical tank. The equation derived is dy/dt = -k(y0/r0)²(1/πy), where 'k' is a constant. The tank's water level decreases from 16 feet to 9 feet in one hour, prompting the need to find the total time required to empty the tank completely. Participants emphasize the importance of integrating this differential equation to express 'y' as a function of time for further analysis.
  • Understanding of differential equations
  • Familiarity with integration techniques
  • Knowledge of volume calculations for conical shapes
  • Basic principles of fluid dynamics
  • Learn techniques for solving first-order differential equations
  • Study the application of separation of variables in differential equations
  • Explore volume and surface area calculations for conical shapes
  • Investigate real-world applications of fluid dynamics in engineering
Students studying calculus, engineers working with fluid systems, and anyone interested in mathematical modeling of drainage systems.
chae
Water drains out of an inverted conical tank at a rate proportional to the depth (y) of water in the tank. Write a diff EQ as a function of time.
This tank's water level has dropped from 16 feet deep to 9 feet deep in one hour. How long will it take before the tank is empty.
V=1/3pir2y
dV/dt=pi(r0/y0)2y2dy/dt
The solution to the first question is: dy/dt=-k(y0/r0)2(1/piy)
I don't really know how to go about finding the time it will take to empty the tank.
Please help!
hey, welcome to physicsforums! your solution to the first question is correct. (I'm guessing you're using 'k' as a constant. this is good.) So now, you need to make use of this differential equation to get 'y' as a function of time. You have hopefully done this kind of integral before. It just needs a bit of rearranging to get a nice answer.
