Dummit and Foote exercise 13.2.13 on algebraic extensions
  • Thread starter Thread starter Math Amateur
    Exercise Field
6 replies · 3K views
Math Amateur
MHB
I am reading Dummit and Foote, Chapter 13 - Field Theory.
I am currently studying Section 13.2 : Algebraic Extensions
I need some help with Exercise 13 of Section 13.2 ... ... indeed, I have not been able to make a meaningful start on the problem ... ...
As indicated above I need help in order to make a meaningful or significant start on the solution to this exercise .. ...Exercise 13 of Section 13.2 reads as follows:
Definitions that may be relevant to solving this exercise include the following:
A result which seems relevant is Lemma 16 plus the remarks that follow its proof ... Lemma 16 and the following remarks read as follows:
[/B]
One thought, though ... there must be some way to use ##\alpha_i^2 \in \mathbb{Q}## ... perhaps in establishing the dimension of ##F( \alpha_1 , \alpha_2, \ ... \ ... \ \ \alpha_{k + 1} )## over ##F( \alpha_1 , \alpha_2, \ ... \ ... \ \ \alpha_{k } )## ... and hence getting some knowledge of the dimension of ##F( \alpha_1 , \alpha_2, \ ... \ ... \ \ \alpha_n )## over ##\mathbb{Q}## ... but even if we do gain such knowledge, how do we use it to show ##\sqrt [3]{2} \notin F## ... ...
... AND FURTHER ... anyway ... what is implied by ##\alpha_i^2 \in \mathbb{Q}## ... ... ?
Help will be much appreciated ...Peter
Math Amateur said:
One thought, though ... there must be some way to use ##2∈Q\alpha_i^2 \in \mathbb{Q}## ... perhaps in establishing the dimension of ##F( \alpha_1 , \alpha_2, \ ... \ ... \ \ \alpha_{k + 1} )## over ##F( \alpha_1 , \alpha_2, \ ... \ ... \ \ \alpha_{k } )## ... and hence getting some knowledge of the dimension of ##F( \alpha_1 , \alpha_2, \ ... \ ... \ \ \alpha_n )## over ##\mathbb{Q}## ... but even if we do gain such knowledge, how do we use it to show ##\sqrt [3]{2} \notin F## ... ...
Good idea. What can you say about ##\dim_\mathbb{Q} F\;##? And what about ##\dim_\mathbb{Q}\mathbb{Q}[\sqrt[3]{2}]\;##? Then what do you know about the fields in between, from ##\mathbb{Q}## to ##F\;:\;\mathbb{Q} \subseteq \mathbb{Q}[\alpha_1]\subseteq \mathbb{Q}[\alpha_1,\alpha_2]\subseteq \ldots \subseteq F\;##?
It means that ##\alpha_i## is a root of ##x^2-r## for some rational ##r \in \mathbb{Q}##, ergo the minimal polynomial of ##\alpha_i## because ##\alpha_i\notin \mathbb{Q}## which rules out that the degree could be less than two.
Thanks for the help, Andrew ... ...
Just a simple clarification though ... ...
You write, in the context of ##\alpha_i^2 \in \mathbb{Q}##, the following ... ...
" ... ... It means that ##\alpha_i## is a root of ##x^2-r## for some rational ##r \in \mathbb{Q}##, ergo the minimal polynomial of ##\alpha_i## because ##\alpha_i\notin \mathbb{Q}## which rules out that the degree could be less than two ... ... "... BUT ..
... how do we know that ##\alpha_i \notin \mathbb{Q}## ... indeed maybe ##\alpha_i## is in ##\mathbb{Q}## ... then ##\alpha_i## will satisfy a polynomial of degree 1 in ##\mathbb{Q}## ... namely ##x - \alpha_i## ... ...
... so doesn't ##\alpha_i^2 \in \mathbb{Q}## mean that
## [ F( \alpha_1, \alpha_2, \ ... \ ... \ \ , \alpha_i ) \ : \ F( \alpha_1, \alpha_2, \ ... \ ... \ \ , \alpha_{i - 1} ) ] ##
is either 1 or 2 ... ...
can you clarify/comment ?{Note : I have to confess that although I think it may well be true that ## [ F( \alpha_1, \alpha_2, \ ... \ ... \ \ , \alpha_i ) \ : \ F( \alpha_1, \alpha_2, \ ... \ ... \ \ , \alpha_{i - 1} ) ] ## is either 1 or 2 (i.e a positive integer less than or equal to 2) I do not know the precise argument for why it cannot be larger than 2 ... say 3 r 4 or 37 or something ... can you explain ...}Peter
Hi Michael!
All cases in which ##\alpha_i \in \mathbb{Q}## can be omitted. Say ##\alpha_1 , \ldots \alpha_{k-1} \in \mathbb{Q}## and ##\alpha_k, \ldots , \alpha_n \notin \mathbb{Q}## then ##F=\mathbb{Q}[\alpha_1,\ldots , \alpha_n]=\mathbb{Q}[\alpha_k,\ldots , \alpha_n]## and we're back in the case where all ##\alpha_i \notin \mathbb{Q}##. (The case in which there isn't a proper extension at all is also trivial, since ##\sqrt[3]{2} \notin \mathbb{Q}## and nothing has to be shown.)
So key to this exercise lies in the formula for finite field extensions:
Let ##\mathbb{F} \subseteq \mathbb{K} \subseteq \mathbb{L}## be finite field extensions, then ##[\mathbb{L}:\mathbb{F}] = [\mathbb{L} : \mathbb{K}]\,\cdot \,[\mathbb{K}:\mathbb{F}]\;##.
In case you cannot use this equation, you might investigate how the roots of the minimal polynomial ##m_{\mathbb{Q}}(\sqrt[3]{2})(x)## can be or cannot be expressed by rationals and roots of the form ##x = \alpha_i = \sqrt{r_i}## with ##r_i \in \mathbb{Q}\;##.
fresh_42 said:
Hi Michael!
Thanks fresh_42 ... appreciate your help ...
Just reflecting on what you have said ... but obviously most helpful ...
Thanks again,
Peter
fresh_42 said:
Hi Michael!
Thanks to Andrew and fresh_42 for all the help ...
Now to finish the exercise based on the help you gave ...Essentially then, it follows that ...
##[ F \ : \ \mathbb{Q} ] = 2^k## where ##0 \le k \le n##Now ... ... suppose ##\sqrt [3]{2} \in F ## ... (and try for a contradiction)Then since ##\mathbb{Q} \subseteq \mathbb{Q} ( \sqrt [3]{2} ) \subseteq F##
... we have that ...
##[ F \ : \ \mathbb{Q} ] = [ F \ : \ \mathbb{Q} ( \sqrt [3]{2} ) ] [ \mathbb{Q} ( \sqrt [3]{2} ) \ : \ \mathbb{Q} ]##
So that##2^k = [ F \ : \ \mathbb{Q} ( \sqrt [3]{2} ) ] . 3##... BUT ...##3## does not divide ##2^k## ... ... Contradiction!So ##\sqrt [3]{2} \notin F##
Can someone please confirm that the above is correct ... ...
Peter
Yes, this is correct. At some place, an extension of degree three (or at least ##3m##) would be needed.
