Dynamics question (polar kinematics). Please help.
A rocket is launched vertically and tracked by a radar station, which measures the angle and distance to the rocket. To find the rocket's velocity and acceleration, one must differentiate the position vector using polar coordinates, specifically relating the distance (r) and angle (theta) over time. The unit vectors for polar coordinates are defined, with the hat (^) indicating a unit vector and the absence of it representing the magnitude. The discussion highlights confusion about relating time to the variables without a specified time frame. Understanding the differentiation process and the relationship between r and theta is crucial for solving the problem.
MC_UNLV
A rocket is fired vertically and tracked by a radar station on the ground, a distance (r) away from the rocket. When the station reads an angle of (theta) = 60* between the rocket and the ground, we are given that the distance r = 30,000ft, r(double-dot) = 70 ft/sec, and theta(dot) = 0.02 rad/sec. Find the magnitude of the velocity and acceleration of the rocket at this position.
I know that to solve this, you need to find r(dot), and that this is somehow related to r as a function of time. I do not understand how to get this relationship, or how to find r(dot). Can anyone please help?
Let
\vec{r}=r(\theta{})\hat{r}
Differentiating with respect to time and using the chain rule gives
\vec{\dot{r}}=\dot{r}\hat{r}+r\frac{d\hat{r}}{d\theta{}}\frac{d\theta{}}{dt}
and
\frac{d\hat{r}}{d\theta{}}=\hat{\theta}
Why? Differentiate this expression again to arrive at an expression for r double dot in terms of the unit vectors r and theta. This should get you started.
Forgive my ignorance, but what does the "^" above r and theta mean, and what is the difference between the r with and without the ^?
The ^ represents the unit vector. In Cartesian coordinates it's
\hat{x}\mbox{ and }\hat{y}
The r without the hat (^) is the magnitude of r. Have you been exposed to polar coordinates and the associated unit vectors?
Yes, I understand vectors, I just have seen it with different notations.
I still do not understand what you are trying to say with the expressions in your first reply. I do not get how to relate time to the values of r and theta, if a specified time is not given.
  • · Replies 20 ·
9K
