Easy laplace conversion from s to t-domain gone wrong
  • Thread starter Thread starter Twinflower
    Laplace
The discussion revolves around converting the Laplace transform \( I(s) = \frac{2}{s^2 + s} \) into the time domain. Participants are exploring the steps involved in this conversion process, particularly focusing on the use of partial fraction decomposition.
  • Participants discuss various steps taken to manipulate the expression, including dividing by \( s \), creating new fractions, and attempting to simplify. There are questions about the legality of certain steps and whether partial fraction decomposition should have been applied earlier in the process.
Some participants have provided guidance on the importance of using partial fractions and have pointed out potential errors in the original poster's approach. There is ongoing exploration of the correct method to achieve the time domain conversion, with no explicit consensus reached yet.
Participants are operating under the constraints of homework rules, which may limit the depth of guidance provided. There is a focus on understanding the reasoning behind each step rather than simply arriving at the correct answer.
Twinflower
I(s)=\frac{2}{s^2 + s}
Convert this to the time domain
Step 1 - Divide by s
I(s)=\frac{\frac{2}{s}}{s + 1}
Step 2 - Substract and add 1 to create new fractions
I(s)=\frac{\frac{2}{s}-1+1}{s + 1}
Step 3 - Split into new fractions
I(s)=\frac{\frac{2}{s}}{s + 1} - \frac{1}{s + 1} + \frac{1}{s + 1}
Step 4 - Contract the two newbie fractions
I(s)=\frac{\frac{2}{s}}{s + 1} - \frac{2}{s + 1}
Step 5: Split up the first fraction
I(s)=\frac{2}{s} \frac{1}{s + 1} - \frac{2}{s + 1}
Step 6 - Convert to time domain
i(t)=2e^{-t}-e^{-t}
BUT, this is not correct. It should be: 2-2e^{-t}
What is wrong in my approach here?
i(t)=2e^{-t}-e^{-t}
You started with I(s) = \frac{2}{s^2+s} = \frac{2}{s(s+1)} = \frac{2}{s}\frac{1}{s+1} and ended up with I(s) =\frac{2}{s} \frac{1}{s + 1} - \frac{2}{s + 1} and you see nothing wrong with this? Why did you not just apply partial fractions to
I(s) = \frac{2}{s(s+1)}?
RGV
What's wrong is your first step. Factor the denominator to s(s + 1) and then use partial fraction decomposition to rewrite 2/[s(s + 1)] in the form A/s + B/(s + 1).
i(t)=2e^{-t}-e^{-t}
Thank you Ray.
Can you tell me exactly what step in my first approach which was "illegal"?
Twinflower said:
Thank you Ray.
You don't see your claim that
-\frac{1}{s+1} + \frac{1}{s+1} = -\frac{2}{s+1} when going from Step3 to step 4? You don't see that the fraction
\frac{\frac{2}{s}}{s+1} in the first term in Step 3 is exactly the same as I(s), so you have really done nothing that will be useful?
RGV
OK, I'm going to do this one more time from scratch.
With partial fraction decomposition this time.
<br /> I(s) = \frac{2}{s^2 + s}<br />
Step 1 - Factor the denomenator
<br /> I(s) = \frac{2}{s(s + 1)}<br />
Step 2 - Set up the partial fractions stuff
<br /> \frac{A}{s}+\frac{B}{s + 1}<br />
Step 3 - Merge A and B fractions
<br /> \frac{A(s+1)+B(s)}{s(s + 1)}<br />
Step 4 - Determine A and B
(A+B)s = 0
A = 2
Using that A = 2, B must be -2 to fullfill the first equation.
Step 5 - Replace A and B with determined values
<br /> \frac{2}{s}-\frac{2}{s + 1}<br />
Step 6 - Convert to the holy time domain
\frac{2}{s} = 2
\frac{-2}{(s+1} = -2e^-t
i(t) = 2(1-e^-t)
Hey Serena! Long time no see ;)
I managed this one after realizing that I had to utlize the partial fraction-stuff :)
But I still need some help in this other thread of mine about the fifth harmonic of a square wave passing trough a HP filter. And my exam is on monday :/
https://www.physicsforums.com/showthread.php?t=603179
(A+B)s = 0
A = 2
\frac{2}{s} = 2
i(t) = 2(1-e^-t)
This is almost OK now, but it is a bad idea to write things like \frac{2}{s} = 2 because that is false, and might get you a mark of zero just for writing it. If you mean that the inverse transform of 2/s is 1, why not just say so, or maybe use a better notation, such as L^{-1}(2/s) = 1 or 2/s \longrightarrow 1? Also, in LaTeX, if you want e^{-t} rather than your e^-t,, you need to use a curly bracket. To get a^{anything}, put the "anything" between curly brackets, like this: {anything}. If you don't, you will get a^anything.
RGV
I didnt find the arrow in latex, but in my hand written notation i always use that.
There are various types of arrows.
\text{\rightarrow gives} \rightarrow, \text{\longrightarrow gives} \longrightarrow, \text{\Rightarrow gives} \Rightarrow, \text{\Longrightarrow gives} \Longrightarrow.
I like \to (##\to##), which is nice and short to type.
I also like \mathcal{L} ##\mathcal{L}^{-1}(\frac 2 s) = 2##, or more formally ##\mathcal{L}^{-1}_s[ \frac 2 s ](t) = 2##.
I, too, like mathcal, but have also seen things like \frac{1}{s} \leftrightarrow 1 .
However, this uses the somewhat lengthy "\leftrightarrow". Is there a shorter version?
RGV
Thread now about latex syntax. I have a feeling I will need to use some Laplace symbols soon so it's great info. Ty
