- 29,902
- 21,785
mfb said:Correct. As Earth's gravitational field is weak you can treat both time dilation effects as independent. Add the velocity/height relation for an orbit and you can get a closed formula. Here is a graph. At 3000 km clocks run at the same speed as on the ground (for circular orbits). Below they run slower, above they run higher.
I thought I'd seen the calculation once that the ISS was high enough. Apparently not. I'll remember that. Thanks.
