Eigenvalues getting mixed up when looping through matrices in Matlab
6 replies · 3K views
member 428835
Hi PF!
I am looping through a linear system and each time I do I generate a new matrix, call this matrix ##A##. When finding the eigenvalues of ##A## in Matlab is use
Code:
[a,sigma2M] = eig(A);% a eigenvector and sigma2M matrix of eigenvalues
sigma2(:,ii) = sum(sigma2M);% create matrix with rows of eigenvalues for the iith system
where the ii is the for loop. The plot I get looks bad and you can see how some eigenvalues get mixed up (vertical axis are eigenvalues). Any ideas? I'd really appreciate it!
Orodruin said:
Sort the eigenvalues?
Doesn't it automatically do this for me? Is there a way to have this automated?
If it did you would not get the result you are getting. Use the sort function.
I also recommend against using sum to get the eigenvalues out. The matrix contains the eigenvalues on the diagonal so use diag instead. For a square matrix it will give you a vector containing the diagonal elements.
Good call on the diag function. I'd like the eigenvalues to remain paired with their corresponding eigenvectors. When I use sort on the eigenvalues, that only change their positions? Do you know of a way to have the eigenvectors align with the eigenvalues?
If you have the sort function output two return values, i.e.,
Code:
[B,I] = sort(A);
then B will contain the sorted list of eigenvalues and I will be a list of indices which is the order of the original indices. You can sort the eigenvectors by using the array I accordingly as an argument of the matrix containing the eigenvectors.
