Eigenvalues of a 3×3 matrix with parameter k
Yankel
Hello all,
I have a matrix A and I am looking for it's eigenvalues. No matter what I do, I find that the eigenvalues are 0, 1 and (k+1), while the answer of both the book and Maple is 0 and (k+2). I tried two different technical approaches, both led to the same place.
The matrix is:
\[A=\begin{pmatrix} 1 &1 &k \\ 1 &1 &k \\ 1 &1 &k \end{pmatrix}\]
I have stated with calculating
\[\lambda I-A\]
which is
\[A=\begin{pmatrix} \lambda -1 &-1 &-k \\ -1 &\lambda -1 &-k \\ -1 &-1 &\lambda -k \end{pmatrix}\]
Now I calculate the determinant of this matrix. Whatever I do, I get the wrong answer. Can you please assist ?
Thank you.
Hi Yankel,
I believe you actually want to find $\text{det }(A-\lambda I)=0$ in order to calculate the eigenvalues. What do you get when you try that?
Yankel said:
Hello all,
The matrix is:
\[\lambda I-A\]
which is
Thank you.
Check your calculations again! You should find that $\det(\lambda I - A) = \begin{vmatrix} \lambda -1 &-1 &-k \\ -1 &\lambda -1 &-k \\ -1 &-1 &\lambda -k \end{vmatrix} = \lambda^2(\lambda-k-2).$
