Eigenvalues of heat equation with mixed boundary conditions
12 replies · 4K views
mathmari
MHB
Hey! :o
Find the solution of the problem $$u_t(x, t)-u_{xx}(x, t)=0, 0<x<1, t>0 \tag {*} \\ u(0, t)=0, t>0 \\ u_x(1,t)+u_t(1,t)=0, t>0$$
I have done the following:
We are looking for solutions of the form $$u(x, t)=X(x) \cdot T(t)$$
$$u(0, t)=X(0) \cdot T(t)=0 \Rightarrow X(0)=0 \\ X'(1) \cdot T(t)+X(1) \cdot T'(t)=0 \Rightarrow \frac{X'(1)}{X(1)}=-\frac{T'(t)}{T(t)}$$
$$(*) \Rightarrow X(x) \cdot T'(t)-X''(x) \cdot T(t)=0 \\ \Rightarrow \frac{X(x) \cdot T'(t)}{X(x) \cdot T(t)}-\frac{X''(x) \cdot T(t)}{X(x) \cdot T(t)}=0 \\ \Rightarrow \frac{T'(t)}{T(t)}=\frac{X''(x)}{X(x)}=-\lambda$$
So, we get the following two problems:
$$\left.\begin{matrix}
X''(x)+\lambda X(x)=0, 0<x<1\\
X(0)=0 \\
\frac{X'(1)}{X(1)}=\lambda \Rightarrow X'(1)-\lambda X(1)=0
\end{matrix}\right\}(1)
T'(t)+\lambda T(t)=0, t>0
\end{matrix}\right\}(2)$$
For the problem $(1)$ we do the following:
The characteristic polynomial is $d^2+\lambda=0$.
  • $\lambda <0$ :
    $X(x)=c_1 \sinh (\sqrt{-\lambda} x)+c_2 \cosh (\sqrt{-\lambda}x)$
    Using the initial values we get that $X(x)=0$, trivial solution.
  • $\lambda=0$ :
    $X(x)=c_1 x+c_2$
  • $\lambda >0$ :
    $X(x)=c_1 cos (\sqrt{\lambda}x)+c_2 \sin (\sqrt{\lambda}x)$
    $X(0)=0 \Rightarrow c_1=0 \Rightarrow X(x)=c_2=\sin (\sqrt{\lambda}x)$
    $X'(1)-\lambda X(1)=0 \Rightarrow \tan (\sqrt{\lambda})=\frac{1}{\sqrt{\lambda}}$
That means that the eigenvalue problem $(1)$ has only positive eigenvalues $0<\lambda_1 < \lambda_2 < \dots < \lambda_k < \dots $ that are the positive roots of the equation $\tan \sqrt{x}=\frac{1}{\sqrt{x}}$.
Is this correct??
Why can we say that the number of the eigenvalues is countable ?? (Wondering)
How can we show that $$\lim_{k \rightarrow +\infty} \frac{\sqrt{\lambda_k}}{k \pi}=1$$ ?? (Wondering)
Hi! (Wave)
mathmari said:
Is this correct??
Yep. (Smile)
Take a look at this plot of $\tan y$ and $\frac 1 y$.
The tangent has a period of $\pi$ and in each period it has exactly 1 intersection with $\frac 1 y$.
Since there are a countable number of periods of the tangent, that means that the number of solutions is also countable. (Thinking)
In the same graph, you can see that each successive intersection of $\tan y$ and $\frac 1 y$ is closer and closer to where $\tan y$ intersects the axis. That is at $k\pi$.
So those intersections, that correspond to $\sqrt {\lambda_k}$, approach $k\pi$.
Thus:
$$\lim_{k\to \infty} \frac{\sqrt {\lambda_k}}{k\pi} = 1$$
(Wasntme)
I understand! (Sun)
When we have an other problem, and we find that the eigenvalues are the positive roots of the equation $\tan (\sqrt{\lambda } \pi)=\frac{1}{\sqrt{\lambda}}$, is the argument the same?? (Wondering)
I have also an other question...
To divide with $X(1)$ are we sure that it isn't zero?? (Wondering)
mathmari said:
I understand! (Sun)
Good! (Happy)
Yes. (Nod)
In this case the limit would be $$\lim_{k\to\infty} \frac{\sqrt{\lambda_k}}{k} = 1$$
No, we can't be sure. (Shake)
So, can't we do that or do we have to suppose that $X(1) \neq 0$ ?? (Wondering)
Easiest is to avoid dividing by $X(1)$. (Wasntme)
Otherwise we should distinguish two cases. One where $X(1) \neq 0$ and one where $X(1) = 0$. (Nerd)
How could we avoid dividing by $X(1)$ ?? (Wondering)
When do you need to? (Thinking)
We have the problem $$u_t(x, t)-u_{xx}(x, t)=0, 0<x<1, t>0 \tag {*} \\ u(0, t)=0, t>0 \\ u_x(1,t)+u_t(1,t)=0, t>0$$
$$u(0, t)=X(0) \cdot T(t)=0 \Rightarrow X(0)=0 \\ u_x(1,t)+u_t(1,t)=0 \Rightarrow X'(1) \cdot T(t)+X(1) \cdot T'(t)=0 \Rightarrow \frac{X'(1)}{X(1)}=-\frac{T'(t)}{T(t)}$$
X(0)=0 \\
\end{matrix}\right\}(2)$$ If we don't divide by $X(1)$ how else could we use the condition $u_x(1,t)+u_t(1,t)=0 \Rightarrow X'(1) \cdot T(t)+X(1) \cdot T'(t)=0$ ?? (Wondering)
Substitute $T'(t)=-\lambda T(t)$? (Thinking)
Afterwards, we can divide by $T(t)$.
If we assume that the solution for $u$ is non-trivial, $T(t)$ must be non-zero for at least one value of $t$. (Wasntme)
Ok... I see... (Emo)
The graph of $\tan (y \cdot \pi)$ and $\frac{1}{y}$ is the following: https://www.wolframalpha.com/input/?i=plot%5Btan%28y*%28pi%29%29%2C1%2Fy%2C+%7By%2C0%2C20%7D%5D
So do we say the following ?? (Wondering)
The $\tan (y \cdot \pi )$ has a period of $\pi$ and in each period it has exactly 1 intersection with $\frac 1 y$.
Since there are a countable number of periods of the tangent, that means that the number of solutions is also countable. How do we know that there are a countable number of periods of the tangent ?? (Wondering)
Sounds fine to me. (Smile)
Each period on the positive axis is identified by $k\pi$ where $k \in \mathbb N$.
In other words, we have a bijective mapping from each period to $\mathbb N$.
That means we have a countably infinite number of periods. (Wasntme)
I understand! Thank you very much! (flower)
