Why is ##x=e^y## the inverse of ##y=\int_1^x \frac{1}{t} dt##?
  • Context: Undergrad
  • Thread starter Thread starter Mike_bb
Mike_bb
Hello!
I have a problem in understanding why ##x=e^y## is inverse function of ##y=\int_1^x \frac{1}{t} dt##.
This question seems strange but I'll try to describe my problem.
As is known, the function ##y= \int_1^x \frac{1}{t} dt## is defined as ##y=ln(x)## but I can't understand why.
In general we can consider the function ##y## as ##y=\int_1^x \frac{1}{t} dt##.
At the definition stage, we know nothing about this function (and its properties) but we know only that it has inverse function.
My questions are:
1. If we know that ##y=\int_1^x \frac{1}{t} dt## then why is ##x=e^y## the inverse function of ##y##?
2. How to find the inverse function ##x=e^y##?
P. S. I tried to change ##ln(x)## to ##log_{10}(x)## and obtained that ##log_{10}(x)=\int_1^x \frac{1}{t} dt## and its inverse function is ##g(y)=10^y## :
Let ##f(x)=log_{10}(x)## and ##g(y)=10^y## then ##g(y)## is inverse function to ##f(x)## because: ##f(10^y)=log_{10}(10^y)=y## and ##g(log_{10}(x))=10^{log_{10}(x)}=x##
Where did I go wrong?
Thanks.
You may differentiate the function ##F(y)=\int_1^{e^y}\frac{1}{t}\,dt## without using the ##ln(x)## function, simplify ##F'(y)## and integrate again.
But why? I want to understand why ##x=e^y## is inverse function.
I think you will see the answer after the calculation (chain rule).
I understand what you mean. But my question is broad: why ##x=e^y## is inverse function instead of ##x=10^y## or ##x=a^y##?
According to the chain rule:
##F'(y)=\frac{1}{e^y}\cdot {d \over dy}(e^y)##
Maybe you continue the calculation first for ##e## and then repeat the complete calculation for the broader way.
##F'(y)=\frac{1}{10^y}\cdot {d \over dy}(10^y)## Why not?
Then you would not get ##F(y) = y## after integrating.
Yes, because you set upper limit of integral as ##e^y## then we would not get ##F(y) = y## after integrating.
But we can set upper limit of integral as ##10^y## and we get ##F(y) = y##.
The simplification in posting #6 goes:
##F'(y)=\frac{1}{e^y}\cdot {d \over dy}(e^y) = 1##.
Mike_bb said:
That's the point. We get ##log(10^y)##. And as I mentioned in post#1 why do we use ##ln(x)## instead of ##log(10^y)##?
In Wolfram Alpha they write ##log()## for the natural logarithm, which is usually written as ##ln()##.
They mention it:
  • Agree
As I mentioned above:
"I tried to change ##ln(x)## to ##log_{10}(x)## and obtained that ##log_{10}(x)=\int_1^x \frac{1}{t} dt## and its inverse function is ##g(y)=10^y## :
Let ##f(x)=log_{10}(x)## and ##g(y)=10^y## then ##g(y)## is inverse function to ##f(x)## because: ##f(10^y)=log_{10}(10^y)=y## and ##g(log_{10}(x))=10^{log_{10}(x)}=x##"
Why can't we define ##y=\int_1^x \frac{1}{t}dt## as ##y=log_{10}(x)## ?
Please see above in posting #13.
There mentioned that ##log(10^x)##. But I wrote above ##y=log_{10}(x)## These are two different functions.
If you put ##10^y## as upper limit, then you would get ##F'(y)=\frac{1}{10^y}\cdot {d \over dy}(10^y) \neq 1## and ##F(y) \neq y##.
  • Agree
Sagittarius A-Star
Big thanks!!! I appreciate you very much! Now I understand how it works!
you're welcome
Seems to me the error is in the sentence before "P.S." end ":"
precisely just after "log10(x)="
A coef is missing
Mike_bb said:
Sagittarius A-Star
In your proof you use the fact that ##exp(x)'=exp(x)##, right?
Here, in the spoiler, I found the same proof, written in a more elegant way:
$$\int\frac1x\,dx,\quad e^u=x,e^u\,du=dx,\,u=\ln(x)$$$$\int\,du=u+C$$$$\int\frac1x\,dx=\ln(x)+C$$
Maybe it's elegant proof, but I like your proof because it shows where ##e^y## came from.
Mike_bb said:
I understand what you mean. But my question is broad: why x=e^y is inverse function instead of x=10^y or x=a^y?
It helps to have a definition of e. One definition is that e is the unique base such that the derivative of e^y at y=0 equals 1. Since y = 0 corresponds to x =1, this is equivalent to saying that the derivative of its inverse function at x=1 is equal to 1. But the inverse function has derivative 1/x, which does equal 1 at x=1.
It is its definition.
You really need to see how all this stuff follows from the definition of ln(x)
We define ln(x), x > 0, called the natural logarithm, as ln(x) = ∫(1 to x) (1/y) dy. Note ln(1) = 0 and ln'(x) = dln(x)/dx = 1/x. ln'(x*y) = y/x*y = 1/x (using f(g(x))’ = df/dx = (df/dg)*(dg/dx) = f'(g(x))*g'(x)). Hence, since they have the same derivative, ln(xy) = ln(x) + C. Let x = 1. ln(y) = C. ln(x*y) = ln(x) + ln(y). This is why the definite integral was from 1 to x. It leads to the simple relation ln(x*y) = ln(x) + ln(y).
An inverse of a function f(x), g(x), is a function such that f(g(x)) = x and g(f(x)) = x. Let e(x) be the inverse of ln(x). That ln(x) has an inverse is evident from its graph. Let a = e(x), b = e(y). ln(a) = x. ln(b) = y. e(x+y) = e(ln(a)+ln(b)) = e(ln(a*b)) = a*b = e(x)*e(y). Let e(1) = e, called Euler’s number. It is a very important number in math. e^n = e*e*…*e, n times. So e^n = e(n). So far, e^n has only been defined for n a natural number. This allows us to define e^x for any x as e(x), and from now on we will use e^x instead of e(x).
a^x is defined as e^(x*ln(a)). a^(x+y) = e^((x+y)*ln(a)) = e^(x*ln(a))*e^(y*ln(a)) = (a^x)*(a^y)
a^x = a^(0 + x) = a^0*a^x. Dividing by a^x, we have a^0 = 1, which is what was asked - it pops out here without any further ado.
a^(x-x) = (a^x)*(a^-x) = 1. a^-x = 1/(a^x)
(a^x)^y = e^(y*ln(a^x)) = e^(y*ln(e^(x*ln(a)) = e^(y*x*ln(a)) = a^(x*y)
a = a^(x/x) = (a^(1 /x))^x or (x√)a = a^(1/x).
From this, you should be able to derive all the exponent rules given in a Precalculus text, only this time for any real numbers. For example x^a/x^b = (x^a)*(1/x^b) = (x^a)*(x^-b) = x^(a-b),
The logarithm of x to base a will be written as loga(x) and is the inverse of a^x, if it exists. Suppose a^x has an inverse, then a^(loga(x)) = x. e^(loga(x)*ln(a)) = x. ln(x) = loga(x)*ln(a). The logarithm to base a is defined as loga(x) = ln(x)/ln(a). We want to show that ln(x)/ln(a) is the inverse of a^x. a^(ln(x)/ln(a)) = e^(ln(a)*ln(x)/ln(a)) = e^ln(x) = x. loga(a^x) = ln(a^x)/ln(a) = ln(e^(x*ln(a))/ln(a) = x*ln(a)/ln(a) = x. Hence the inverse of a^x, loga(x) exists and is ln(x)/ln(a)
loga(x) has the usual properties of logarithms. loga(xy) = ln(xy)/ln(a) = (ln(x) + ln(y))/ln(a) = loga(x) + loga(y).
Now we look at some calculus. log(e^x) = x. (1/e^x)*(e^x)’ = 1. e^x = (e^x)’. The derivative of e^x is the same function. Very interesting.
Let's find the derivative of x^a when a is not just an integer but any real number. (x^a)’ = (e^(a*ln(x))’ = e^(a*ln(x))*(a*ln(x)’ = e^(a*ln(x))*a/x = a*(x^a)/x = a*x^(a-1). Hence, the general formula is the same as when a = n.
Thanks
Bill
As I understand, we define ##ln(x)## as integral and then suppose that ##x=e^y## and further we find properties of ##e##.
It is defined as the inverse, not a supposition.
It is like force is defined as f=m*a, not suppose f=m*a.
Thanks
Bill
How?? I want to define it as ##x=10^y## in such a manner. But it doesn't work.
I'm not sure I understand what you mean but ##F=ma## is not defined as you want. ##F=ma## has experimental background.
You may want to define it that way, but that is not its definition in mathematics.
F=M*A is a definition needed for Newton's laws to have physical content, which is, as John Baez expresses it, get thee to the forces.
The same goes for the definition of e^x in math. To conform to its usage in mathematics, it needs to be defined that way. You can't really argue about a definition. The only issue is whether the definition is consistent, and in both cases mentioned, it is.
Thanks
Bill
What is the "it" that you want to define as ##x=10^y##?
  • · Replies 17 ·
  • · Replies 20 ·
