Einstein equations don't work at large scale?
  • Level: High School
  • Thread starter Thread starter gen x
125 replies · 11K views
gen x
Below short video explain that Einstein equations don't work at large scale and dark matter/energy are just "fix" to make equations try to work. I also know that Einstein theory dont fit in quantum world.
I am interested what are the consequences that theory not works in large and micro scale, does it mean that fundament of theory is maybe wrong so we need new theory of gravity or that theory need just little correction ?
<Instagram video removed by moderator>
gen x said:
Below short video
This source does not meet the PF standards. So we can certainly discuss your questions, but we will not be relying on or discussing the source itself.
I agree with this statement regarding dark matter, but not dark energy. Dark energy is the cosmological constant, which is a fully legitimate free parameter of the theory itself.
This is not an uncommon situation in science. It can go either way. Historically, slight deviations in Saturn’s orbit led scientists to propose the existence of additional planets that had not been observed. Eventually with improvements in their telescopes they were able to observe Neptune and Uranus. Slight deviations in Mercury’s orbit led scientists to propose the existence of another planets closer to the sun. Despite improvements in telescopes it was never found. When GR was developed it explained the slight deviations in the orbit of Mercury.
So two very similar deviations from the theory. One led to the discovery of new sources. The other led to discovery of new physical laws.
At this point dark matter could go either way. We have neither observed dark matter nor invented a suitable new theory. But work is proceeding on both fronts.
Back in 1780, it was discovered that Newtonian gravity did not correctly predict the positions of the outer planets. Herschel proposed a previously unknown planet, backed its location out of the maths, and discovered Uranus. If social media had been a thing at the time, it would have been awash with armchair scientists (and legit ones pushing their own theories, to be fair) saying what an idiot Herschel was trying to prop up an obviously dead theory by proposing a new planet. They'd have been wrong.
(Edit: I see I've confused my history of the outer planets. Uranus seems to have been discovered just by improved observational techniques. Neptune, however, was identified from anomalies in Uranus' observed orbit compared to prediction and then sighted based on the orbit of an unknown planet required to correct those anomalies.)
They'd have been right in the late 1890s about the failure of Newton to correctly predict the position of Mercury - we needed GR for that.
Social media wasn't yet called that but did kind of exist in the 1990s/2000s when the so-called Pioneer Anomaly was unexplained, and it did have many people arguing that this was definitely a failure of gravitational theory. It turned out to be a modelling oversight - a totally mundane but subtle interaction between the power supply and antenna that nobody had thought to include in the model.
I don't think we should rule out any of these three possibilities with respect to the dark sector. It could be evidence of GR failing (as MOND advocates would say). It could be evidence of new forms of "stuff" that we haven't yet seen elsewhere (the mainstream view). It could be a failure to model correctly (as Deur says, for example). I can't see the video, but if it's taking the view that GR is definitely wrong because of dark energy/matter then I would say it's stuck its neck out a long way at this point.
And indeed this is the current situation. We are currently working along both paths.
I see we said much the same things!
Today we know that Newton mechanics is wrong(even it is enough accurate for every day life for low speeds...)
So there is possibility one day we will find that time and space are absolute instead relative and there is no space-time curvature and something else cause gravity?
That is certainly a possibility. It is under investigation.
However, even if it turns out to be true, relativity and spacetime curvature will still be taught in schools. Just like Newtonian gravity is still taught in schools.
@Dale
@Ibix
I would like that some day it turns out that time is absolute, it better suit human intuition.
If time is relative as we learn today, universe is old 13.8 billions years, looking from witch frame if absolute frame at rest dont exist?
So universe age is different from different places in space?
The frame that sees the Cosmic Microwave Background as uniform. This is the nearest thing to "on average at rest with respect to matter in the universe" that there is.
If you define space as the uniform CMB rest frame then the universe is the same age at all places and this is tautologically true. If you define space a different way then the universe is a different age at different places and again this is tautologically true.
Cosmologists always use the same definition of space (CMB rest frame) because the maths is easiest using that definition. So the age of the universe is stated with that definition with little acknowledgement, basically for the same reason road signs state the speed limit as 30mph without specifying "with respect to the Earth's surface". Strictly, the "with respect to" should always be supplied, but in practice it usually isn't unless it differs from the usual answer.
If the history of science has taught us one thing, it's that human intuition is a very poor guide to how the world actually works.
  • Agree
The interesting thing about intuition is that it is not fixed. Intuition is built on experience. At this point I have enough experience with relativity that I find it pretty much as intuitive as Newtonian mechanics. The actual laws of physics cannot be changed by intuition, but intuition can be built around the actual laws of physic.
I think it is important to note that this has already happened. In Aristotle's day the intuitive physics was that forces produced velocity, not acceleration. Newton's assertion that forces produce acceleration was unintuitive. That has changed. Students now find Newton's laws intuitive. And despite the fact that Newton's laws have been demonstrated to be incorrect, they are still taught in schools, and the previously unintuitive portion specifically still remains valid and has become intuitive.
I would expect the future to mirror this. I would expect that future students will consider relativity's non-absolute time to be intuitive, and that it will continue to be used even after relativity has been supplanted by some future theory. I would not count on a future theory to rescue an old intuition.
More precisely, if we just use the matter we can actually see as the source in the Einstein Field Equation, the model does not match the data.
More precisely, they are additional things we add to the source, over and above the matter we can actually see, in order to make the model fit the data.
Describing this as the Einstein Field Equation "not working", however, is not correct. The source is a free parameter in the equation. Adjusting free parameters in a model to get a best fit to the data is something that is done all the time in science. It doesn't mean the equations don't work.
What we are missing is an understanding of what kind of "stuff" dark matter and dark energy are, i.e., where they would fit in the other equations we have for describing matter and energy--not the Einstein Field Equation, but things like the Standard Model of particle physics, which does not contain anything that would account for dark matter or dark energy.
(Note that "dark energy", if it is in fact just a cosmological constant, i.e., an intrinsic property of spacetime, does fit into the Einstein Field Equation without needing to modify the source, i.e., the stress-energy tensor, at least according to the modern view of how that equation is to be derived from an underlying Lagrangian.)
Not "wrong", no. It is a valid approximation to GR in the regime where gravity is weak and all relative speeds are small compared to the speed of light.
In the sense that we might find some other underlying theory that has these properties, yes.
But GR (and a fortiori Newtonian mechanics) will still be a valid approximation to whatever underlying theory we might find, in the domain where we already know it works. So we will never find out that GR is "wrong". But we might find out that it is only an approximation to something else.
  • Agree
This is a very important point in understanding how science actually works. Popper popularized the idea of falsification, but verification is also important. Experiments verifying a theory do not disappear simply because another experiment falsified it.
gen x said:
@Dale
@Ibix
@Ibix beat me to it but yeah
EDIT: Yeah you gotta click the link to get my drift
Am Totally lost here! Am in the dark!
In simple straightforward terms, are you guys saying Newton's laws are wrong? Also theory on relativity?wrong? ... then what else could be wrong in science!
...plus I've always asked myself, this constant g=9.81... , how did that come into existence, I understand the pull is different at different points on earth's surface, but who determined and ascertained this value to hold as true.
No. See post #13.
The laws of physics plus the particular configuration of matter in the Earth.
I don’t think there is an answer that is both simple and complete.
Newton’s laws have been experimentally shown to be correct in the classical limit.
If you consider Newtonian space and time to be part of Newton’s laws then that has been experimentally shown to be incorrect at high speeds. But Newton’s 2nd law can be rewritten in a way that is correct at high speeds.
If you consider Newtonian gravity to be part of Newton’s laws then that has been shown to be incorrect in strong gravitational fields. But the concept of curved spacetime for gravity comes from taking Newton’s 1st law seriously.
If you consider forces to only act on matter then Newton’s 3rd law had been shown to be incorrect in electromagnetism. But Newton’s 3rd law is the mechanical expression of the conservation of momentum, which applies to electromagnetism.
So Newton’s laws have a domain of applicability, the classical domain. Inside that domain they are experimentally validated. Outside that domain they are experimentally falsified, and other laws are experimentally validated. Newton’s laws are the classical limit of those other laws, meaning that it is part of them.
Human intuition is individually formed by regular experiences of each human, which usualy cover only a narrow range of physical scenarios.
This unfortunately means, that the more general our theories get, the less intuitive they likely become for most humans.
Isaac Asimov's essay The Relativity of Wrong is worth a read. George Box put it rather more pithily as "All models are wrong. Some are useful."
@Dale answered in more detail, but in short Newton's laws are approximations to relativity, and are very good ones as long as velocities are small compared to ##c## and the gravitational field strength is low. They are also approximations to quantum theory, and are very good ones as long as you have enough particles that the quantum randomness averages out. So Newton's laws are absolutely fine to use for pretty much everything in every day life. But we can make observations with high velocities or strong gravity or one or two particles where Newton's laws make measurably incorrect predictions, and then you need either relativity or quantum theory or both.
However, we have a lot of reasons to suspect that one or other or both of relativity and quantum theory aren't quite right. For example, particles in quantum theory can exist in a superposition of states but relativity can only write down the gravitational field of a particle in one state or the other, not "a little bit of both". So our excellent theory of gravity can't handle sources of gravity that our excellent theory of particles say do exist. And the problem is that we can see these contradictions, but we can't do any experiments in the regimes where the problems are significant. For example we can easily put particles in superposed states, but the gravitational effect of a proton is so tiny that we can't measure it to see what it really looks like. And we can measure the gravitational effect of a 100kg mass, but we can't put it into a superposed state. So we keep looking for experiments or observations we can make where our theories give the wrong answer, so we can start to see what the next theory will look like.
Some people do argue that dark energy and dark matter are exactly that: there is no such thing as dark matter or dark energy, the theory of gravity is wrong and a better theory will correctly predict galactic rotation and cosmological expansion without needing them. There is no consensus on this at this time, and some people continue to try to directly detect dark matter or energy while others try to develop new gravitational theories that don't need them. Time will tell.
Maybe better word is logic , instead intuition.
Will Newton laws still be just approximation if one day we find that time is absolute?
If gravity is correct we will not have these problems today.
Maybe one day we will find theory that is correct from 10^-35m to 10^27m
No it isn't a better word. Logic by itself just excludes self-inconsistent theories, but doesn't tell anything about whether time should be absolute or relative.
What is time, what is energy?
I find the disciption of space-time in relativity more intuitive and easier to understand than that of non-relativistic physics.
gen x said:
What is time
If you define "time" like Einstein did (Time is what a clock measures), then it was experimentally verrified, that time is not absolute. (for example: muon storage ring twin-paradox experiment, Bailey et al. 1977):
https://en.wikipedia.org/wiki/Time_dilation#Moving_particles
An example using atomic clocks was the Hafele–Keating experiment:
https://en.wikipedia.org/wiki/Hafele–Keating_experiment
For me it is much more logically that car is long 4m at 50km/h and at 200km/h as well
Personal preferences aren't logic.
Consider in the lab frame a test-charge, moving parallel to an infinite current carrying neutral wire. In the lab frame there is a magnetic force ##\vec F=q(\vec v \times \vec B)## on the test-charge.
How would you explain this force in the rest-frame of the test-charge?
This can be logically answered with length contractions of the distances between charges in the wire:
No. Intuition is the correct word. It is true that most people find relativity unintuitive. It is false that it is illogical.
No. It is more intuitive for you. “Intuitive” is a statement of opinion. It can be “for you”. “Illogical” is a statement of fact. It cannot be “for you”.
In any case, it is both logical and experimentally confirmed. That is the way the universe works. Even if you do not accept the assumptions of relativity, the experimental evidence requires its conclusions.
Using the Mansouri Sexl test theory, which does not assume relativity, we have $$t=aT + ex$$$$x=b(X-vT)$$ where to second order ##a \approx 1+\alpha v^2/c^2##.
Relativity is ##\alpha=-0.5## and absolute time would be ##\alpha=0##. But modern versions of the Ives Stillwell experiment place ##-0.50000008<\alpha<-0.49999992##. So absolute time is completely excluded by the evidence. Regardless of how appealing you find absolute time, the universe demonstrably does not work that way.
How universe works that way if we find that relativity don't works at large scale and quantum world?
