Einstein says objects do not fall to the Earth?
  • Level: High School
  • Thread starter Thread starter inertiaforce
    Earth Einstein Fall
127 replies · 36K views
PeroK said:
I'd say it's the tendency for objects to collide with Earth.
Maybe that is the case for the unscientific term "falling", but for the scientific term "free fall" in GR it means that no real forces are acting on it. Therefore, a spaceship which is far from any gravitating masses is still in free fall even though there may be no collision with Earth or any other gravitating body.
PeroK said:
So, I'm caught between thinking there must be an experimental reality independent of theory and thinking you need a well-defined theory to describe the experimental reality precisely. And, I suspect I can happily leave that question to the philosophers!
One of the Einstein's greatest gifts was his ability to describe a phenomenon as it is, unencumbered by preconceptions of how it ought to be. GR might be the most striking example, but you also see it in the relativity of simultaneity, the insight that "time is what a clock measures", and more.
PeterDonis said:
Which is correct: if you attach accelerometers to the feather and the ball, they will read zero, indicating that no force is acting on them.
Really? I thought laptops and the like used accelerometers to detect falling motion in order to move the read/write head from the hard disk drive.
Edit: then again, it makes sense that they would read zero... so some special mechanism is probably used in this case.
They do. The accelerometer reads 1g when the laptop is resting on the table, zero when it falls off the table, and some large positive value for a very short time when it hits the floor. I've always assumed (although someone here will know for sure) that any sudden change in the reading, regardless of direction, is what triggers the safety feature.
Which would directly contradict Brian Cox!
So, it seems to me that, whether you use the everyday meaning of "falling" or the precise GR term "free fall", the ball and feather are falling. Which is hardly surprising.
I can't understand why Brian Cox didn't say: "Einstein realized that the ball and feather are not being pulled towards Earth by a force, but are following a natural path through spacetime."
Ah, I guess I had no idea what kind of output an accelerometer produces. I thought that 0 would also be the "rest" value, resulting in no net change when falling.
inertiaforce said:
According to this video, a bowling ball and a feather fall at the same rate because according to Einstein, they aren't falling:
The video actually said that Einstein's view was that no force was acting on the feather or on the ball.
I never saw Einstein make such a claim about gravitational fields. To the contrary, according to Einstein he was "struck by the fact that the force of gravitation possesses a fundamental property, which distinguishes it from electro-magnetic forces. [..] All bodies fall in a gravitational field with the same acceleration"
- https://en.wikisource.org/wiki/A_Brief_Outline_of_the_Development_of_the_Theory_of_Relativity
However, it is possible to describe the same observation in a different way, as others explained.
Suppose two balls were "dropped" at the same time on opposite sides of the Earth. Which way would the Earth fall?
The answer given by
Nugatory said:
Let's assume for simplicity that the two balls have the same mass.
Using Newton's model, the forces between each ball and the Earth would be of equal magnitude and opposite direction, so the Earth would experience no net force and the balls would be drawn towards the Earth according to Newton's ##F=ma## by the forces acting on the balls.
Using Einstein's model, the geodesic paths of the two balls and the Earth would intersect. The curvature of spacetime bends the paths of the two balls towards the path of the earth. Eventually they collide.
I didn't get the above answer, when we say it is the Earth that moves towards the ball, the answer given above, is that the balls followed their curved path towards the earth.
You're right, I didn't word that very well. The two balls travel along geodesics in curved spacetime; the curvature of spacetime means that these straight lines will eventually intersect the equally straight line followed by the center of the earth.
There is a sense in which it is correct to say that the surface of the Earth is accelerating upward: there is an upward force on the surface of the Earth, and this force causes the surface to accelerate upward relative to a freefall path (or geodesic). All parts of the Earth are accelerating upward, in this sense (I wouldn't call it "falling" upward, falling means traveling in the absence of any forces holding you up, and that is not the case with the surface of the Earth; the surface of the Earth is held up by contact forces from the rocks below). This notion of acceleration, relative to a geodesic, or freefall path, is local, so different spots on the Earth are accelerating in different directions.
How is it possible for opposite sides of the Earth to be accelerating in different directions, without the Earth expanding? I think it's helpful to think of a lower-dimensional analog. Think of spacetime as the surface of a globe, and think of the time axis as being measured North-South, while spatial distances are measured East-West. Suppose you have two objects on the equator, a distance of 10 meters apart. As time moves on, those objects move north along lines of longitude. If there were no forces acting on those objects, they would be getting closer and closer together, until they collide at the North Pole. It requires a force to keep the two objects 10 meters apart as they move North.
Interesting how people can be experts about gravity without being able to tell us the mechanism of gravity.
In my opinion when he said they were not falling he meant that in their frame of reference the Earth was moving toward them.
Well, you have to think about what it means to understand the "mechanism" behind some physical phenomenon. It usually (if not always) means to explain the phenomenon in terms of more basic phenomena. So we explain chemical reactions in terms of interactions of molecules, and explain molecules in terms of interactions of atoms, and explain atoms in terms of interactions of electrons, protons and neutrons, and explain protons and neutrons in terms of interactions of quarks. But at some point, you've gotten down to as basic a level as you know. At that point, giving "mechanisms" has to stop.
General Relativity views curved spacetime as the most basic level of describing gravity. There is no mechanism more basic, at least not until we develop a quantum theory of gravity.
Agreed. My understanding of GR is that since there is no absolute state of rest or absolute state of motion, it is therefore just as valid to say that the Earth is moving toward an object as it is to say that an object is moving toward the earth. Both frames of reference are equally valid. Motion and rest are relative. There is no absolute state of motion or absolute state of rest. Therefore, it is apparently just as valid to say that the Earth is moving toward the ball and feather as it is to say that the ball and feather are moving toward the earth. Therefore, if it is just as valid to say that the Earth is moving toward the ball and feather, then that means that the Earth would run into the ball and feather at the same time, which is what we saw in the experiment when the ball and feather hit the ground at the same time. The whole point of relative motion is that you can't tell who's moving. That's why relativity says that everything is "relative" to the observer. There is no absolute frame of reference to tell who's moving and who's at rest. You can't distinguish between rest and motion.
So if a quantum theory of gravity doesn't happen should we look for some other method or just throw up our hands?
Some other method of doing what? General Relativity provides a description of gravity as curved spacetime. There is no need for a "mechanism" beyond that, except to take into account phenomena that are not described by General Relativity.
"Discovering a mechanism" amounts to explaining one theory in terms of a second theory. There's no point in doing that, unless the second theory is more complete than the first--describes more phenomena, and is more general.
1) Movement is relative. The Earth's surface moves in the frame of the ball.
2) Proper acceleration is absolute. But proper acceleration away from the center doesn't imply movement away from the center. See the green apple hanging on the branch at 0:40 in the below animation. It must accelerate upwards just to stay at constant height, like the Earth's surface.
That is a good analogy. Here is a visualization for both sides of the planet and the inside:
http://www.adamtoons.de/physics/gravitation.swf
Guys, watch this video from 12:00 to 12:46. Now imagine this explanation from the frame of reference of the ball and feather. From the ball and feather's point of view, could it be said that there is a gravitational field causing the Earth to be accelerated in their direction?
Here is the video:
This video shows the effect of acceleration in flat space time, far from gravity sources. What they call "gravity" is a inertial force in an accelerated frame.
No. That is an inertial frame, so there is no inertial force there. The Earth surface accelerates in their direction, because of the EM-repulsion from below, which is a real force, that causes proper acceleration.
But in the non-inertial frame of the surface, there is an inertial force that accelerates the ball and feather down. Inertial forces and curve-linear coordinates like in the video in post #47 are two different way to describe non-inertial frames.
No. In the frame in which the ball and feather are at rest, it is true that the ground is rushing upward, but it's not rushing upward because of gravity.
Think of the ball and feather falling toward a platform, and this platform is hovering above the ground by using rockets. Then from the frame in which the ball and feather are at rest, the platform is rushing upward using rocket power.
If the platform is resting on the ground, then the platform is being held up by contact forces. Gravity isn't holding it up.
Now I understand, If I'm right ,that opposites ball when released hit the Earth surface at the same time because the curve path of the balls and that of the Earth collide at the same time, as time move on.
I didn't understand "It requires a force to keep the two objects 10 meters apart as they move North." How does this correspondence to acceleration of Earth surface in different direction.
What is the source of Earth acceleration in all direction. I can think as Earth revolves around sun at constant velocity experience acceleration as it changes direction continuously. Also the Earth rotation on its axis.
Once again, picture two objects both moving straight north, starting at the equator. Do you see that the distance between them shrinks as they move North? To keep the distance between them from shrinking, you have to have a force pushing them apart. That force pushes one object to the west, and it pushes the other object to the east.
An analogous thing is happening to two points on the opposite sides of the Earth. It requires a force to keep those two points from getting closer together. The force has to keep the two points apart.
Pressure. The material that the Earth is made out of is under pressure, and that pressure exerts an outward force on all points on the surface of the Earth.
That's true about just about all of science; the same criticism can be levied at just about all of classical mechanics: We know that like charges repel and unlike charges attract, and we can describe the forces using Coulomb's law ##F=Cq_1q_2/r^2## but that's a description not an explanation of mechanism.
What is the term referred to the above phenomenon.
So, the pressure of the material, which actually causes experiences of the weight?
But we studied, we feel weight because of Earth gravity. It seems gravity and weight are two different thing.
I understand due to gravity or due to curvature of space, as each points on Earth follow this curved path, they build internal pressure, which exert on our body and we feel it as weight.
But as commonly understand, our body is pulled to the Earth surface and it exert pressure on the surface, in return the surface exert equal opposite force on us.
Weight is still the same thing as in the classical explanation - the force which an object exerts on its support, equal and opposite to the "normal force". But you are right that in GR the "normal" comes first, as a result of the support's "pressure" or more generally just its tendency to keep a fixed distance from the Earth's center (or from the definition of "fixed support"), and that weight is then just its equal and opposite counter force.
Edit:
As to "What is the term referred to the above phenomenon.", can you say which phenomenon that is? Do you mean why the earth, or anybody for that matter, does not collapse under its own gravity? I guess the term would be "rigidity", until we move to the surface of a gas giant ;)
stevendaryl said:
"Pressure. The material that the Earth is made out of is under pressure, and that pressure exerts an outward force on all points on the surface of the Earth."
The above statement, where it says, "...The material that the Earth is made out of is under pressure..."
Yes, you don't actually feel gravity when you stand on the ground. You feel the force of the ground pushing up against your feet.
You can't feel gravity. If you were falling, you wouldn't feel any different than if you were floating in space (well, except for the air rushing past you). The only time you feel weight is when you are being prevented from falling, by the ground (or whatever is holding you up). As I said, what you feel as weight is an upward force preventing you from falling.
Yes, that's the way that Newton viewed gravity.
https://testtube.com/dnews/which-falls-faster-a-feather-or-a-bowling-ball/?utm_source=FB&utm_medium=DNews&utm_campaign=DNewsSocial
What does this mean exactly? The Earth comes up to the ball and the feather?
Since Newton came up short, gravity never attracts and nothing accelerates in a fall anymore. It just looks like it does. It's all because of Einsteins wonderful Equivalence principle, of which he used to look at gravity from a different perspective in a unique coordinate system.
Many years ago I developed a thought experiment that allows me to see how a rendition of the Equivalence principle works. Perhaps it will help others. A good thought experiment is even better than youtube, and is all we had back then anyway.
The trick is to temporarily imagine Earth expanding as stevendaryl briefly mentioned earlier. In this imaginary case, the surface of an enlarging model Earth rises to meet the surfaces of the bowling ball and feather "simultaneously".
The easiest way to visualize this comprehensive thought experiment is to imagine we have a large, sealed bell jar that we may began to evacuate of air. The internal experiment must also take place in a gravity-free area of space, or free-fall (the same thing).
In this bell jar we place several soap bubbles. For PeroK's 2-ball thought experiment, somewhat towards the center, we place a large soap bubble we will call earth. Above(?) it we place a smaller bubble we call ball 1. Below "earth" we place another similar sized small bubble we call ball 2. Now we began to evacuate the chamber by opening a valve that is hose-connected to an indefinitely large tank that already contains a near vacuum. We have a well equipped lab. When the air leaves the chamber, the Earth body and two smaller balls will all began to enlarge, or swell, because the air pressure on the outside of the bubbles reduces. If we keep opening the valve further all the time, the bubble expansion will accelerate. If we open the valve slightly, then leave the setting, the expansion will only represent an undetectable steady inertial movement. We will choose the former for our acceleration experiment.
Now imagine the bubbles want to maintain their center-to-center distances, i.e. remain at rest. In this case the surface of the large Earth bubble will expand into the space that the surfaces of the smaller bubbles also wish to expand and occupy. The surface of model Earth will rise to hit the balls at the same time the swelling balls have a small "enlargement gravity" of their own. This is classic Equivalence principle. There is a catch, but I won't say for now and chance breaking this Lawrence Welk spell.
For inertiaforce's thought experiment, one can carry the thought experiment a bit further and imagine that beside one of the other normal balls (ball 1) there is a tiny bubble. This delicate little guy can be the feather. If the surfaces of the feather and ball 1 are equally distant from the surface of earth, they will strike Earth simultaneously (or Earth will strike them). Now it is important that both small bubble surfaces, not the centers, be equi-distant from the surface of earth. Otherwise one can imagine that the larger "heavy" ball has a head start to make contact. The ball and the feather also do one other thing that is remarkably like gravity. They both seem to "fall" towards Earth's center and towards one another at the same time. If the ball and feather are in close proximity compared to their relative distance from earth, they may even make "swelling" contact before contacting the surface of our model earth. Besides "falling" towards the center of model earth, they also seem to move closer together on their own, which is in keeping with properties of all material objects, which of course have a small amount of gravity of their own. Ignoring ball 2, these three bodies seek not the center of earth, but a common center.
One other Equivalence thought coincidence, that is remarkable, results when we place a special small bubble on the surface of our Earth bubble. This precious bubble can be our human observer. This flat-footed human bubble must enlarge in our vacuum chamber also. So the relative comparative size of this "human" and that of model Earth never change, ala Poincaré. We could even grant him/her a bubble for a yardstick, but our oblivious human observer still has no way to measure that he/she is part of a slow bang process. But yet the human bubble experiences a mysterious acceleration that he/she interprets as gravity. As we, the real humans, safely watch the chamber from our assigned privilaged rest outside our little bell-jar universe model, we will see that as the model Earth bubble expands, the small human bubble actually squashes a bit as he/she rides the accelerating surface of the Earth bubble. This equivalent compression is so true in our real world, over many years I have permanently become nearly an inch shorter from the perpetual stress of standing, and I, like all of us, am always longer when I lie down.
And that is my shortest condensed rendition of the Equivalence principle. I think Poincaré would have particularily liked it.
P.S.
Earlier I mentioned a catch to this ancient thought experiment though. If we really evacuated a chamber, the air between the bubbles would expand also. That means the bubbles would be drawn apart in expanding space and perhaps never make contact. It seemed a story spoiler to openly mention this too soon. I'm sorry if it nagged at some of you throughout.
Wes
Stevendaryl said nothing about the "Earth expanding", which is exactly the wrong way to explain this, and leads people to conclude that GR is a bunch of nonsense.
He says that the surface accelerates away from the center. But that doesn't imply movement away from the center (expansion). He also gives a much better analogy:
