Einstein says objects do not fall to the Earth?
  • Level: High School
  • Thread starter Thread starter inertiaforce
    Earth Einstein Fall
127 replies · 36K views
Objective permanence for the agoraphobic. Look up at the sky and see through the manifolds... kind of like a joke I guess. I wasn't sure what to think it meant but in my endeavors I finally envisioned a manifold in spacetime so its all good. :-P
DaleSpam said:
Not all physical laws are expressed in terms of an inertial frame. For instance, the EFE is expressed in terms of tensors, and Lagrangian mechanics is expressed in terms of generalized coordinates. So you need to know for each specific physical law you are using whether or not the choice of coordinates is arbitrary. If the choice is not arbitrary for that specific law then, as you said, you cannot use a non-inertial frame with that law.
I rather expected that when I posted. Unfortunately I'm not up to speed on those subjects (tensors, Lagrangian mechanics and generalized coordinates) nor the physical law that uses them. So I cannot appreciate yet how physical law can be stated independently of any background conditions in which the law is said to apply.
A.T. said:
So, it is just a preference for a certain system of coordinates. For example a preference based on the simpler math in those coordinates.
I don't see how you can say that. What I'm talking about is how a physical law is stated. If it's stated for an inertial frame (which is not unusual) then you cannot apply it directly to a non-inertial frame. That is not a matter of preference, it is a requirement. You may have some freedom to choose a particular inertial frame but you have no freedom to apply the law to non-inertial frames.
Take for example :
This law cannot be applied to non-inertial frames, it's not just a matter of convenience.
DrGreg said:
In General Relativity there are no such things as truly inertial frames. However in a small enough region, where the tidal effects of gravity are negligible, you can find a locally-approximately-inertial frame.
Is there a name for that beast? Apparently by definition an "Inertial frame" is global (over all time and space) rectilinear motion. Therefore we cannot say that the space station is at rest in any inertial frame. However, the motion of the space station is inertial in that it has nearly 0 proper acceleration.
How do we properly express this in physics? Do we say "local inertial frame" perhaps "local inertial space" or perhaps "momentarily comoving inertial rest frame". Momentary isn't particularly satisfying because whatever we name this frame it retains it's inertial motion (in the sense of 0 proper acceleration) over time. Can we call it's worldline an "inertial path"?
CKH said:
...If it's stated for an inertial frame...
Here is where the preference comes in. We prefer to state the laws for inertial frames, because that is simpler.
Not in curved space time. There it only applies to a small region approximately.
For one small object that creates only negligible gravity itself you can say this. Build the space-station bigger, and some parts will experience non-zero proper acceleration, so it its not entirely inertial. And when you have two massive celestial bodies, there is no way you can define global inertial coordinates, that have zero proper acceleration everywhere.
OK. I'm curious about what the alternative might be. How would you express the physical law below for any arbitrary frame? Or does each frame have it's own different physical laws? The latter concept is not an attractive approach to defining physical law.
hp?image=http%3A%2F%2Fupload.wikimedia.org%2Fmath%2F8%2Fd%2F5%2F8d5b3bad8da46e0ac5e765608a9a77cf.png
Whenever you mistreat a non-inertial frame as inertial and apply the above physical law, fields appear that are not real, that is they have no existence independently from that frame.
Re global inertial frame:
Right. So the strict definition of an "inertial frame" is something that only exists in principle. As I mentioned we need a term for "local inertial frame". Is that the term that is standard? For the space station there is an instantaneous local inertial frame, but there is also is also continuous inertial motion. If you consider the worldline of the space station, a small region of space around the worldline is "continuously inertial" in that proper acceleration approaches 0. Does such a worldline have a name? E.g. inertial path, geodesic path in spacetime?
Hence we prefer not to use it
That’s how I would call it.
No problem. This way at least you are aware of their existence, if not their mechanics.
Your point is correct, just not universally applicable. For laws expressed in terms of inertial frames you certainly do not have the option to use them in a non inertial frame as is.
For laws expressed in a covariant form or in terms of generalized coordinates the above doesn't apply. Luckily, most laws of physics have a known formulation or generalization in one of these types of structures.
You did not address my question directly. You claim that we just "prefer" to describe this physical law in an inertial frame. So what is an alternative expression of the physical law?
Perhaps you would say, "instead of using an inertial frame for this physical law, I will define a more complicated physical law for a frame fixed to the surface of the earth"?
How would you do that? I.e. how would you derive an equation for the corresponding physical law of inertia in this frame?
Do you believe that fictitious forces should be considered as having physical existence? (To me that's like believing "my shadow has an independent existence" or "when I turn my head it is equally valid to say my head is still, but my body twisted and caused the entire universe to accelerate, rotate about my head and then stop again".)
For example.
Why derive? Laws can be simply postulated based on observation.
That's a vague philosophical question of little interest to me.
There is a covariant way of expressing [itex]\vec{F} = \frac{d\vec{p}}{dt}[/itex]. First, introduce a scalar parameter, [itex]s[/itex], and a trivial equation of motion for [itex]t[/itex] itself:
Let [itex]t(s)[/itex] be any linear function satisfying
[itex]\frac{d^2 t}{ds^2} = 0[/itex]
Next, we make the equations 4-D instead of 3-D by making [itex]t[/itex] into a coordinate:
[itex]x^0 = t, x^1 = x, x^2 = y, x^3 = z[/itex]
[itex]F^0 = 0, F^1 = F_x, F^2 = F_y, F^3 = F_z[/itex]
Now define the "velocity" with respect to the parameter [itex]s[/itex] as follows:
[itex]U^\mu = \frac{d x^\mu}{ds}[/itex]
In terms of [itex]U^\mu[/itex], we have:
[itex]m \frac{d}{ds} U^\mu = F^\mu[/itex]
Then, to make it covariant, we just have to replace [itex]\frac{d}{ds}[/itex] by the covariant notion of the directional derivative with respect to the parameterized path [itex]x^\mu(s)[/itex]:
[itex]m D_s U^\mu = F^\mu[/itex]
or in terms of connection coefficients:
[itex]m ( \frac{d}{ds} U^\mu + \sum_{\nu \lambda} \Gamma^\mu_{\nu \lambda} U^\nu U^\lambda) = F^\mu[/itex]
This equation has the same form in any coordinate system (although the values of the coefficients [itex]\Gamma^\mu_{\nu \lambda}[/itex] are different in different coordinate systems.
Thanks. I wish I understood your equations better (the notations are quite unfamiliar), but perhaps I get the point. The equation while not written for a particular coordinate system has embedded in it a parameterized coordinate system. In order to use the equation for a coordinate system you plug in some coefficients? It does not seem that any finite set of scalar "coefficients" would be enough. So I have some more questions:
Don't you need a complete mapping of spacetime to some other spacetime?
How would that mapping be described? In other words, given an arbitrary coordinate system, how do you find these "coefficients"?
What are these coefficients in a inertial frame?
Is the force in that last equation (they right side) a real force or does it include fictitious force?
You are mistaken that it is a philosophical question. It is a physical question. Fictitious force fields are called "fictitious" for a real physical reason. They exist only in the frame in which they are measured. They are entirely accounted for by the frame's proper acceleration and have no independent cause nor independent existence. That is, fictitious forces have no frame-independent reality, any more than your shadow has a separate reality from yourself . Your shadow is entirely caused by your own position and motion relative to the sun, it has no independent existence. That fact (for both your shadow and the fictitious forces that accompany your non-inertial motion) is easily verified by experiment. We are easily disabused of the notion that our shadow exists without us, we should be as easily disabused of the notion that fictitious forces exist around us in our environment.
I don't think that's quite the way I would put it. The point is that the equations only vary from one coordinate system to another through the "connection coefficients" [itex]\Gamma^\mu_{\nu \lambda}[/itex]. Those coefficients have different values in different coordinate systems. Essentially, these coefficients record the "fictitious forces" associated with the coordinate system.
For an specific coordinate system, there are only finitely many connection coefficients, of the form [itex]\Gamma^\mu_{\nu \lambda}[/itex]. There are 64 coefficients, in general, although in many cases, you find many of those are zeros and others are repeats. Except that the coefficients can vary from location to location, so in that sense, there are infinitely many parameters.
No, you don't need anything more than the connection coefficients associated with a specific coordinate system. This is equivalent to knowing how vectors transport from place to place (that is, knowing which vectors over there are parallel to which vectors over here.)
The connection coefficients can be found through parallel transport, which can be determined empirically (at least, if you make a few assumptions about what is "force-free" motion).
The special fact about Cartesian coordinates in an inertial frame is that the connection coefficients are all zero. It's not enough that the frame be inertial--spherical coordinates have nonzero connection coefficients even in an inertial frame.
No, the force on the right is "real" forces, and all the "fictitious" forces are captured by the term
[itex]m \Gamma^\mu_{\nu \lambda} U^\nu U^\lambda[/itex]
Fictitious forces are all velocity-dependent, even though that isn't always apparent.
You need a mapping from an open subset of spacetime to an open subset of R4. This mapping is called a coordinate chart (hopefully that term sounds familiar to you now).
Every spacetime has a metric. This is the quantity which represents distances and durations in the spacetime. To use a coordinate system you have to know how to express the metric in terms of the coordinates. That is the "coefficients" you mention earlier.
All of this is covered in chapters 1 and 2 of Sean Carrolls lecture notes on general relativity. Your questions and comments keep on running headlong into this material, so I would again encourage you to study it.
EDIT: note that stevendaryl spoke of the Christoffel symbols as your "coefficients" and I spoke of the metric tensor in terms of the coordinates. You can obtain one from the other, so they are closely related.
If it doesn't affect the quantitative outcome of predictions, then it isn't a physics question.
To physics it's irrelevant how you call them. It doesn't affect the quantitative outcome of predictions.
To me, there certainly is a physical distinction between "fictitious" and non-fictitious forces. For one big difference, the latter obey Newton's 3rd law of motion (or a generalization) and the former do not. For another, fictitious forces can be made to vanish through a coordinate change. For another, fictitious forces always have a similar form--they are quadratic in the generalized 4-velocity, and are proportional to mass. All of these differences are physically and quantitatively important. I would not lump this in with a "philosophical" distinction that makes no difference to the physics.
CKH didn't ask me about that distinction, but about "physical existence". Musing about what "really exists" and what doesn't is what I consider philosophy.
Well, in my opinion, the best way to respond to philosophical questions is to steer them toward conceptually related questions that are more physics-oriented, such as: In what concrete ways are fictitious forces different from nonfictitious forces.
That's a good approach. Thanks.
Specifically the subdiscipline of metaphysics called ontology.
Thanks, nice explanation. You have removed the mystery of "coordinate independence" in this equation. As I understand it, this equations applies at an event, a single point in spacetime or infinitesimal patch of spacetime, if you prefer.
Where is the "physical law" in this covariant equation. It seems to be the same physical law as:
One difference is that the covariant version adds a coordinate transformation. That inclusion is not necessary to express the underlying physical law. You can state the physical law without a transformation and then just apply the transformation when you need to. The transformation is an "add on" for mathematical purposes I imagine.
Another difference is that this covariant version applies only to a point while the simple version applies to all inertial frames (throughout time and space).
Using this covariant version by plugging in the coefficients for a given coordinate system, can we claim a "different physical law" for that coordinate system?
Did we choose an inertial frame in which to express the coefficients just for convenience?
Both versions of the physical law are based on the concept of an inertial frame. The inertial frame is essential for stating the physics of motion. SR and GR are constructed upon this concept. The use of an inertial frame is not simply a preference for expressing physical law in a simpler formula, rather it is the foundation of the physical law.
Newton figured it out. He knew he should not include environmental conditions in his equations for motion. He ignored gravity, air resistance, spin of the Earth and so on, in order to discover the underlying physical laws of motion. That was a major step forward for physics and had nothing to do with a "preference" for an inertial frame on Newton's part, it is rather the discovery of the inertial frame (although it seems so obvious to us now) that made the laws of motion possible.
No, the covariant version is more general than the simple version. There is no case where the simple version applies that the covariant version does not also apply. In addition, there are cases where the simple version does not apply, and in those cases the covariant version does (e.g. non-inertial frames).
In other words, the simple version requires the use of an inertial frame. It is not an option if you want to use the simple version. However, there is a generalization of the simple version which does not require the use of an inertial frame. If you want to use the general version then the use of an inertial frame is optional.
If you use the general version in an inertial frame then it will automatically reduce to the simple version.
I wouldn't claim it as a "different physical law". I would claim it as a generalization of the simplified physical law. In cases where the simplified law applies, the generalized law matches it. In addition, the generalized law applies to other cases where the simplified one does not.
But isn't an inertial frame still required since the coefficients in the transformation term are defined relative to an inertial frame (with Cartesian coordinates)? The transformation term disappears in an inertial frame, thus the transformation term itself is relative to an inertial frame.
Where "force-free" motion == local inertial motion or no proper acceleration?
No. There is no need for a transformation at all. If I give you some coordinates, say ##(k,l,m,n)## and a metric ##ds^2 = n^2~dk^2+ dl^2 + dm^2 - k^2~dn^2## then you can do all of the physics directly in that frame without ever calculating or worrying about the transformation between this frame and an inertial frame.
If you do not know the metric in a given frame then you can either calculate it by transforming from an inertial frame, or you can simply measure it experimentally. Usually the former is easier to do, but that does not mean that it is required.
Yes, it's the same law, just the form is generalized so that it works equally well in any coordinate system.
No, there's no coordinate transformation involved. The meaning of the connection coefficients [itex]\Gamma^\mu_{\nu \lambda}[/itex] is in terms of parallel transport. There is an observer that is traveling with a 4-velocity [itex]U^\mu[/itex]. There is a vector [itex]A^\nu[/itex] and the observer carries that vector without changing its direction or magnitude, then the components of that vector will change at a rate given by:
[itex]\frac{d A^\nu}{ds} + \Gamma^\nu_{\mu \lambda} A^\mu U^\lambda = 0[/itex]
Why are the components changing, if you are keeping the vector [itex]A^\mu[/itex] constant in magnitude and direction? Think about a 2D plane (the x-axis oriented left-right and the y-axis oriented up-down, and you are carrying a vector of length 1 that is pointing in the y-direction. You move this vector from a point on the x-axis to a point on the y-axis. This is shown in the figure below
But when expressed in terms of polar coordinates, the components change as you move the vector around. In polar coordinates, the basis vectors are [itex]e_\theta[/itex], which points in the direction of increasing [itex]\theta[/itex] (where [itex]\theta = 0[/itex] along the x-axis and [itex]\theta = \frac{\pi}{2}[/itex] on the y-axis, and [itex]e_r[/itex], which points in the direction of increasing [itex]r[/itex], the distance from the center. On the x-axis, the vector is pointing in the direction of [itex]e_\theta[/itex], so its components would be [itex]A^r = 0, A^\theta > 0[/itex]. On the y-axis, the same vector is pointing in the direction of [itex]e_r[/itex], so its components would be [itex]A^r > 0, A^\theta = 0[/itex]. So as you move the vector along the circular path shown, [itex]\frac{dA^r}{ds} > 0[/itex] and [itex]\frac{dA^\theta}{ds} < 0[/itex].
That's true if space is "flat", meaning that it is describable using Cartesian coordinates that apply everywhere. If space is not flat, then you can't do any better than have connection coefficients that apply at a single point.
No, it's just that the details for how things are described are different in different coordinate systems, just like things are described differently using polar or Cartesian coordinates.
I don't think that's quite correct. What it's based on is the notion of "parallel transport", which is the notion that one vector at one point is parallel (the same magnitude and direction) to another vector at another point. What's nice about inertial Cartesian coordinates is that it's really simple to know when one vector is parallel to another vector: you just see if the components are equal.
I don't quite agree. Newton wasn't up to speed on differential geometry, because he'd just invented calculus, and differential geometry would still be 200 years later. But really what's more fundamental in physics is the notion of parallel transport. Inertial motion can be defined in terms of parallel transport, or the other way around. They are more or less equivalent concepts. But what you don't need is the notion of an inertial frame. In curved space (or curved spacetime), there are no inertial frames, although there is still inertial motion.
OK. this is more than a bit over my head. I understand we are generalizing a law so that it may be stated in "any" coordinate system, but we are only doing it at one point. So perhaps we are only interested in the rates of change in coordinates at this point; maybe first and second derivatives?
Unfortunately I don't understand the notation so it's still a little foggy what's going on. What is it that designates the coordinate system? Can you tell me easily what each letter designates in the full equation or provide a reference?
This [itex]A^\nu[/itex] vector is a unit 4-vector indicating a direction in which coordinates?
You said that the coefficients are all zero in any (Cartesian) inertial frame. That seems to imply that the "from" coordinates are Cartesian coordinates in an inertial frame. In that special case there are no fictitious forces to account for, so that entire term drops out.
There are a lot of coefficients (64). What are all these coefficients?
As I said, [itex]U^\mu = \frac{d x^\mu}{ds}[/itex], so that's the "4-velocity". [itex]A^\mu[/itex] is any other 4-vector.
[itex]A^\mu[/itex] is any 4-vector (not necessarily a unit vector). You pick whatever coordinate system you like, and then that coordinate system determines the components of [itex]A[/itex] and [itex]U[/itex] and determines the coefficients [itex]\Gamma^\mu_{\nu \lambda}[/itex].
It's not a transformation, so there are no "from" coordinates. However, you can use transformations to figure out connection coefficients in one coordinate system from the connection coefficients in another coordinate system. The connection coefficients themselves are not transformations, though.
They describe how the components of vectors change from place to place. Let me go through the example of 2D flat space in polar and cartesian coordinates. In the case of Cartesian coordinates [itex]x,y[/itex], if an object is moving around, then its velocity is given by the vector [itex]U = U^x e_x + U^y e_y[/itex] where [itex]U^x = \frac{dx}{dt}[/itex] and [itex]U^y = \frac{dy}{dt}[/itex], and where [itex]e_x[/itex] is the basis vector in the x-direction and [itex]e_y[/itex] is the basis vector in the y-direction. The nice thing about Cartesian coordinates is that the basis vectors are constant. [itex]e_x[/itex] points in the same direction no matter what your location.
But now switch to polar coordinates [itex]r[/itex] and [itex]\theta[/itex]. Then if you have an object that is moving around, its velocity is given by [itex]U^r e_r + U^\theta e_\theta[/itex] where [itex]U^r = \frac{dr}{dt}[/itex] and [itex]U^\theta = \frac{d\theta}{dt}[/itex], and where [itex]e_r[/itex] and [itex]e_\theta[/itex] are basis vectors in the [itex]r[/itex] and [itex]\theta[/itex] directions, respectively. If you work out what the basis vectors [itex]e_r[/itex] and [itex]e_r[/itex] are in terms of a cartesian basis [itex]e_x[/itex] and [itex]e_y[/itex], you will find:
[itex]e_r = cos(\theta) e_x + sin(\theta) e_y[/itex]
[itex]e_\theta = - r sin(\theta) e_x + r cos(\theta) e_y[/itex]
Note that [itex]e_r[/itex] is not constant. When [itex]\theta = 0[/itex], it points in the x-direction. When [itex]\theta = \frac{\pi}{2}[/itex], it points in the y-direction. Similarly, [itex]e_\theta[/itex] is not constant, either. We can characterize how [itex]e_r[/itex] and [itex]e_\theta[/itex] change with position by taking derivatives:
[itex]\partial_\theta e_r = - sin(\theta) e_x + cos(\theta) e_y = \frac{1}{r} e_\theta[/itex]
[itex]\partial_\theta e_\theta = - r e_r[/itex]
[itex]\partial_r e_\theta = \frac{1}{r} e_\theta[/itex]
The general pattern is that [itex]\partial_\nu e_\lambda[/itex] is equal to some combination of other basis vectors. The coefficient [itex]\Gamma^\mu_{\nu \lambda}[/itex] is the number multiplying [itex]e_\mu[/itex]. So for our example, we can read off:
[itex]\Gamma^\theta_{\theta r} = \frac{1}{r}[/itex]
[itex]\Gamma^r_{\theta \theta} = -r[/itex]
[itex]\Gamma^\theta_{r \theta} = \frac{1}{r}[/itex]
