Electrical Forces help. Two questions
  • Context: Undergrad
  • Thread starter Thread starter robinhood1331
    Electrical Forces
This discussion focuses on two physics problems involving electrical forces and conservation of energy. The first problem involves a 4.8-g particle with a charge of +9.9 μC approaching a fixed 7.8-g particle with a charge of +5.2 μC, requiring the calculation of the closest distance between them using Coulomb's law and energy conservation principles. The second problem involves two 3.2-g beads with equal charges accelerating towards each other at 538 m/s², where the goal is to determine the magnitude of the charge on each bead using the relationship between force, mass, and acceleration, alongside Coulomb's law. Key constants used include k = 9.0 × 109 N • m²/C².
  • Understanding of Coulomb's law and electrical forces
  • Familiarity with Newton's second law (F = ma)
  • Knowledge of conservation of energy principles
  • Basic algebra and unit conversion skills
  • Study the application of Coulomb's law in various scenarios
  • Learn about the Work-energy theorem in classical mechanics
  • Explore the concept of potential energy in electrical systems
  • Review unit conversion techniques for mass and charge in physics problems
Students studying physics, particularly those tackling concepts in electromagnetism and mechanics, as well as educators seeking to clarify these principles for their students.
robinhood1331
Did a practice test but I would like to understand these two questions a bit more. I know the answers to both but that doesn't mean anything if i don't get it. Any help would be appreciated
A very small 4.8-g particle carrying a charge of +9.9 μC is fired with an initial speed of directly toward a second small 7.8-g particle carrying a charge of + The second particle is held fixed throughout this process. If these particles are initially very far apart, what is the closest they get to each other? (k = 1/4πε0 = 9.0 × 109 N • m2/C2)
Two tiny beads, each of mass 3.2 g, carry equal-magnitude charges. When they are placed 6.4 cm apart and released in outer space, they begin to accelerate toward each other at 538 m/s2. What is the magnitude of the charge on each bead? (k = 1/4πε0 = 9.0 × 109 N • m2/C2)
Welcome to PF;
Those are great questions - please tell us how you understand them so we can see how best to help you.
i.e. there are a number approaches - how would you go about finding the answers and what is your reasoning along the way?
In Classical Physics
1. Force = mass x acceleration.
2. Energy = ½ x mass x (velocity²) = Force x distance = ...
3. Simple math requires Position(now) = Position(then) + (velocity(then))x(time interval between then and now) + ½ x acceleration x (time interval between then and now²)
4. Velocity(now) = velocity(then) + acceleration(between then and now) x (time interval)
5. Two common forces are electrical and gravitational. Both follow inverse square laws (in simple situations). The inverse square law is F = kPp/(r²) where F=force, k is a constant of Nature, r is distance between particles and P and p are quantities associated with the Law (mass or charge in these two cases) of Particle1 and particle2.
6. momentum = velocity x mass
7a. >>and most important<< energy (including potential energy) is conserved.
7b. >>and just as important<< momentum is conserved.
All the rest is algebra (and geometry).
Simon Bridge said:
Welcome to PF;
Its been over a year since I've taken physics 1. My practice was for physics 2 which I'm finally taking. All the other questions I was able to answer but these two seem to borrow concepts from physics 1 so I'm a bit clueless.
I figured for the second question, I'd solve for force=ma and then solve for the charges given coulombs law since I have the force. Thats what I'm doing but I'm not getting 890 nC which is the answer.
F= ( 3.2g)(538 m/s)
F=1721.5
F = kPp/(r²) and solve for P.
Edit: Forgot to change the units for question 2. I guess that's what happens when you take so long to take physics 2. Help would still be appreciated for question 1! I noticed I was missing information when I posted it.
A very small 4.8-g particle carrying a charge of +9.9 μC is fired with an initial speed 8.0 m/s of directly toward a second small 7.8-g particle carrying a charge of +5.2 μC + The second particle is held fixed throughout this process. If these particles are initially very far apart, what is the closest they get to each other? (k = 1/4πε0 = 9.0 × 109 N • m2/C2)
Yah - for Q2 you can just use that the force is equal to the mass times acceleration - and Coulombs force law.
The other approach is to say that the force is proportional to the gradient of the potential energy.
Q1 uses conservation of energy - or the Work-energy theorem.
Start out by describing the initial and final conditions in terms of potential and kinetic energy.
  • · Replies 19 ·
