Elevator Physics: Power & Mass Analysis
The discussion revolves around the physics of an elevator system, specifically analyzing the power required for the motor to operate under certain conditions. The problem involves a cab with a mass of 2000kg and a counterweight of 2600kg, focusing on the dynamics of descending at a constant speed of 10m/s over a distance of 300m.
  • Participants explore the relationship between work and mechanical energy, questioning how height affects energy changes in the elevator system. There are attempts to relate power to the work done and to clarify the implications of constant speed on calculations.
Participants are actively engaging with the problem, raising questions about the relationships between force, work, and power. Some have provided calculations related to work done by the counterweight and cab, while others are considering how to incorporate time into their power calculations. There is a recognition of the need to connect various concepts without reaching a definitive conclusion.
Participants are operating under the assumption that the cab's mass remains constant, and they are discussing the implications of adding passengers. The discussion also notes the absence of friction in the pulley system, which may influence the calculations being considered.
Newton22
The mass of the cab is 2000kg and the mass of the counterweight in an elevator is 2600kg. Assume the mass of the cab remains constant.
The cab must descend a distance of 300m from the top floor to the bottom floor, and must do so at a constant speed of 10m/s.
A)What must the power of the motor be in order to accomplish this? Give your answer in Watts.
B) If passengers enter the cab and the mass of the cab is increased, how does this affect the power required?
P = Fv
P = (10m/s)F
The pully is assumed to have no friction and no mass.
The total force that is opposing the downward motion is :
F(counterweight) - F(cab)
25500N - 19600N = - 5900N
Don't know what to next. I think all we need to know is the force but what does the height have anything to do with it?
Please help and thanks
What is the relationship between work and mechanical energy?
W = Kf - Ki
W = .5MVf^2 - .5MVi^ 2
Also
W = Ui - Uf
OK - so how does height relate to the change in mechanical energy for the elevator system?
W = Uf - Ui
Uf of the cab is 0
Uf of the counterweight is 2600*9.81*300 = 7651800J
Ui of the cab is 2000*9.81*300 = 5886000J
Uf - Ui
7651800J - 5886000J = 1765800J
So the work is going to be 1765800J
The power is the rate that the work is done rather than the total work.
How can we relate potential energy to the power?
Maybe P = (Ui - Uf)/t how can we solve this
Off the problem statement - you are told the cab etc has a constant speed.
How do you find time from speed and distance?
This is the same as putting ##F=(m_c-m_{cw})g## then doing ##P=Fv = (m_c-m_{cw})gv##
... but you asked the question :)
If the elevator did not do the constant speed - then this would give an average power off the average speed.
aha so you solve for the time knowing speed and distance. Would it then be correct to insert this time into the equation P = (Ui-Uf)/t ?
That would be correct :)
  • · Replies 47 ·
9K
16K
11K
