Why is aerogel used as an insulating material in skylights?
  • Thread starter Thread starter felipe douglas
    Energy
Aerogel is utilized as an insulating material in skylights due to its porous structure, which effectively prevents convection currents between the two panes. The discussion highlights that during winter, warmer air rises from the lower pane to the upper pane, creating convection cells that can transfer heat. The presence of aerogel mitigates this heat transfer, making option B the correct reasoning for its use. Additionally, while insulation is beneficial in summer, the primary focus remains on its winter performance.
  • Understanding of thermal dynamics and convection principles
  • Familiarity with aerogel properties and applications
  • Knowledge of insulation materials and their effectiveness
  • Basic concepts of heat transfer in building design
  • Research the thermal conductivity of aerogel compared to traditional insulation materials
  • Explore the design principles of skylights and their impact on energy efficiency
  • Investigate the role of convection in heat transfer within building structures
  • Learn about advancements in insulation technologies for energy-efficient architecture
Architects, engineers, and builders involved in energy-efficient design, as well as students studying thermal dynamics and insulation materials.
felipe douglas
Your house will have several skylights. To minimize heat flow, each skylight will have two transparent panes separated by an intermediate layer. Since visibility through the skylight isn't important, the gap between the panes will be filled with aerogel: a porous, ultralight translucent material that is almost 100% gas. Why not just use the gas alone? Why add the porous framework of the aerogel?
a. During the cold winter, natural buoyance causes gas to rise from the cooler lower pane to the hotter upper pane. Many convection cells develop in between the panes and heat is carried efficiently from the upper pane to the lower pane. The porous framework prevents such convection.
b. During the cold winter, natural buoyance causes gas to rise from the hotter lower pane to the colder upper pan. Many convection cells develop in between the panes and heat is carried efficiently from the lower pane to the upper pane. The porous framework prevents such convection.
c. During the hot summer, natural buoyance causes gas to rise from the hotter lower pane to the colder upper pane. Many convection cells develop in between the panes and heat is carried efficiently from the lower pane to the upper pane. The porous framework prevents such convection.
d. During the hot summer, natural buoyance causes gas to rise from the cooler lower pane to the hotter upper pane. Many convection cells develop in between the panes and heat is carried efficiently from the upper pane to the lower pane. The porous framework prevents such convection
none
C? because Natural buoyancy causes hotter air to rise in colder air.[/B]
Start with examining the difference between the four options.
a] winter: cool air near lower pane, hot air near upper pane
b] winter: hotter air near lower pane, cool air near upper pane
c] summer: hotter air near lower pane, cool air near upper pane
d] summer: cool air near lower pane, hot air near upper pane
Do these all make sense? Can you rule any out?
can definitely rule out D
im thinking B or C? since the air is hotter in the lower pane..
What exactly is the difference in the wording between b and c? Which of them would be a reason for the aerogel?
since aerogel helps to insulate heat, it would be helpful during the winter? (B?)
Insulation can be useful in the summer too. Why doesn't the explanation in C make sense?
