Equilibrium constants help Enough work for 8 marks?
The discussion focuses on calculating the activation energy (Ea) for the decomposition of C2H6 using provided rate constants at various temperatures. The correct approach involves using the Arrhenius equation, k = A * exp(-ΔE/RT), and transforming it into a linear form: ln k = ln A - (ΔE/R)(1/T). By plotting ln k against 1/T, the slope of the resulting line will yield the activation energy when multiplied by the gas constant R (8.314 J/(mol·K)). This method provides a clear and effective way to determine Ea from the given data.
  • Understanding of the Arrhenius equation and its components
  • Familiarity with natural logarithms and their properties
  • Basic knowledge of graphing linear equations
  • Proficiency in using the gas constant R (8.314 J/(mol·K)) in calculations
  • Learn how to derive the Arrhenius equation from experimental data
  • Study the method for linear regression to analyze plotted data
  • Explore the significance of activation energy in chemical kinetics
  • Investigate the implications of temperature on reaction rates
Chemistry students, educators, and professionals involved in chemical kinetics and reaction rate analysis will benefit from this discussion.
westy6711
Activation energy from a decomposition.
. The rate constant for the decomposition of C2H6 is given in the table below. Calculate the activation energy.
105 k/s Temperature/K
2.5 823
4.7 833
8.2 843
12.3 853
23.1 863
35.3 873
57.6 883
92.4 893
141.5 903
This is what i have so far...
Ea = R x (("T1" x "T2") / ("T2" - "T1")) x ln("k2" / "k1")
8.314 x (823 x 903) / (903 – 823) x In(141.5 / 823) = ?
I haven't a clue if this is even right, am i meant to plot a graph?
Any help would be very much appreciated.
I don't quite follow your table, but here's a general solution.
For rate laws, the equation relating k to temperature is k = A * exp(-ΔE/RT).
So you need to use your existing data and fit it to the equation by finding the constants A & ΔE (A is an arbitrary constant & ΔE is the activation energy).
If you take the natural log of both sides, you will get
ln k = ln A + (-ΔE/R)(1/T)
That can be graphed:
y-coordinate= ln k
y-intercept= ln A
x-coordinate = 1/T
slope = -ΔE/R
SO: If you graph ln k vs 1/T from your data, then multiply the slope by R, you will get your activation energy.
Thank you so much, That did it :)
