Equilibrium points doubt (ODE system solution)
The discussion revolves around the concept of equilibrium points in nonlinear ordinary differential equation (ODE) systems, particularly in the context of a two-body problem involving a star and a planet. Participants explore the existence and stability of equilibrium points, as well as the implications of gravitational interactions in multi-body systems.
  • One participant outlines the process for determining equilibrium points by setting the ODE system's function to zero and discusses the use of the Jacobian and eigenvalues for stability analysis.
  • Another participant questions the existence of equilibrium points in a two-body problem, noting that the only potential equilibrium point leads to an undefined situation due to a zero denominator.
  • It is suggested that if an equilibrium point were to exist, it would imply a constant solution, which contradicts the nature of a body moving in a gravitational potential.
  • Some participants assert that there are no fixed points in the two-body problem, even when considering additional bodies orbiting the star, as the gravitational forces do not allow for a stable equilibrium configuration.
  • A later reply emphasizes that the gravitational force dynamics prevent the existence of fixed points, as the acceleration would always be directed towards the center of mass, leading to instability.
Participants generally agree that there are no fixed points in the two-body problem and that this conclusion extends to systems with multiple bodies. However, the discussion includes varying perspectives on the implications of this lack of fixed points and the nature of stability in such systems.
The discussion does not resolve the mathematical intricacies involved in defining equilibrium points in nonlinear ODE systems, nor does it clarify the conditions under which stability can be assessed in gravitational systems.
This discussion may be of interest to those studying dynamical systems, celestial mechanics, or nonlinear differential equations, particularly in the context of gravitational interactions and stability analysis.
Zebx
Hi. I'm not sure about something related to the equilibrium points (or fixed points) of a non linear ode system solution. As far as I know, to check if an equilibrium point exists, I need to put the function of my ode system equal to zero. Then once the point is found, I can use it to evaluate its stability. If I have 2 equilibrium points for example, one of which is linearly stable, then it means that if I use this point as my initial condition I will get a constant solution. Moreover, if I evaluate the Jacobian of my system in the stable equilibrium point, I can use the eigenvalues to check what timesteps I have not to use in order to have stable solutions.
I was trying to apply what said before (supposing it is all correct) to my ode system. I already checked the methods used works and plot some solution, but I wanted to try to see if I could apply the above analysis properly. For instance I started by considering a 2-body problem with a star at the center of the system and a planet orbiting around it. Looking at the equations I already have a problem: the function is zero just if I use ##(x=0, y=0, z=0)##, but since I have ##\sqrt{x^2 + y^2 + z^2}## at the denominator I would get infinites. So I thought that maybe it's normal cause, if I actually had an equilibrium point for my system and I used it as starting condition, I should get a constant solution, but it's impossible to have a constant solution for my problem since I have a body moving in a star potential. So basing on this I thought that maybe this is one of these cases in which you can't have a clue about stability from jacobian study.
Is my reasoning correct?
Technology news on Phys.org
Describe the motion of a planet with its center of mass at the center of mass of its sun?
Yes, I consider the star not moving at all.
Yes; there are no fixed points in the two-body problem. If you regard one mass as fixed at the origin then the domain of the problem is [itex]\mathbb{R}^3 \setminus \{0\}[/itex].
You can talk about the stability of a periodic orbit by considering fixed points of a return map.
Ok, thank you. So I suppose there are no fixed points even if I increase the number of bodies orbiting the star. I mean if I have a system of, say, 6 planets around the star still fixed in the origin. In that case I would have for every body a series of terms like ##C(\vec{x} - \vec{x}_i)/\lvert\vec{x} - \vec{x}_i\rvert^3##, where ##i = 1, \dots, 6##, so the only way to have my ##F(\vec{x}) = 0## is to have ##\vec{x} = \vec{x}_i##, which is clearly not possible, even for just two bodies (the system doesn't include close encounters).
Consider: There are a finite number of bodies, so there is one with maximal [itex]x_i[/itex] coordinate. The corresponding component of the gravitational force is then negative, and thus so is the acceleration unless there is some other force to balance it. Thus there can be no fixed points.
Perfect! thank you very much.
  • · Replies 22 ·
