MHB Finding Equilibrium Solutions & Stability of $(1)$
  • Thread starter Thread starter evinda
    Equilibrium
The discussion focuses on finding the equilibrium solutions and stability of the system defined by the equations $(1)$, specifically $\dot{x}=-y-x(1-\sqrt{x^2+y^2})^2$ and $\dot{y}=x-y(1-\sqrt{x^2+y^2})^2$. The only equilibrium solution identified is $(0,0)$, which is determined to be asymptotically stable based on the Jacobian matrix $J=\begin{pmatrix}-1 & -1\\ 1 & -1\end{pmatrix}$, yielding eigenvalues of $-1 \pm i$. The discussion concludes that solutions near $(0,0)$ converge to this point as $t \to \infty.
  • Understanding of dynamical systems and equilibrium points
  • Familiarity with Jacobian matrices and eigenvalue analysis
  • Knowledge of limits and stability criteria in differential equations
  • Basic proficiency in calculus, particularly partial derivatives
  • Study the stability of nonlinear systems using Lyapunov's method
  • Explore the behavior of solutions in phase space with streamplots
  • Learn about bifurcation theory and its implications on stability
  • Investigate numerical methods for solving differential equations
Mathematicians, engineers, and students studying dynamical systems, particularly those interested in stability analysis and equilibrium solutions in nonlinear differential equations.
evinda
MHB
Hello! (Wave)
I want to find the equilibrium solutions and determine their stability.
$(1)\left\{\begin{matrix}
\dot{x}=-y-x(1-\sqrt{x^2+y^2})^2\\
\end{matrix}\right.$
I also want to check the behavior of the solutions of $(1)$ when $t \to \infty$. There are four possible answers.
  1. there exists exactly one equilibrium solution and it is asymptotically stable. Furthermore, $\forall$ solution $(x,y)$ of $(1)$ we have that $\lim x(t)=x_0$ and $\lim y(t)=y_0$ where $(x_0,y_0)$ equilibrium solution.
  2. there exists exactly one equilibrium solution and it is asymptotically stable. Furthermore, $\forall$ solution $(x,y)$ of $(1)$ we have that $\lim x(t) \neq x_0$ and $\lim y(t) \neq y_0$ where $(x_0,y_0)$ equilibrium solution.
  3. $\exists$ exactly one equilibrium solution and it is stable but not asymptotically stable. Also $\forall$ solution $(x,y) \neq (x_0, y_0)$ of $(1)$ we have that $\lim x(t) \neq x_0$ and $\lim y(t) \neq y_0$ where $(x_0,y_0)$ is the equilibrium solution.
  4. $\exists$ exactly one equilibrium solution and it is stable but not asymptotically stable. Also $\forall$ solution $(x,y) \neq (x_0, y_0)$ of $(1)$ with $x^2(0)+y^2(0)>1$ we have that $x^2(t)+y^2(t) \geq 1$.
  5. $\exists$ exactly one equilibrium solution and it is unstable. $\forall$ other solution $(x,y)$ of $(1)$ we have that $\lim (x^2(t)+y^2(t))=1$.
I have thought the following so far.In order to find the equilibrium solutions, we set $\dot{x}=0$ and $\dot{y}=0$.
$\dot{x}=0 \Rightarrow -y-x (1-\sqrt{x^2+y^2})^2=0 (\star)$
and
$\dot{y}=0 \Rightarrow x-y (1-\sqrt{x^2+y^2})^2=0 \Rightarrow x=y(1-\sqrt{x^2+y^2})^2$
$(\star): -y-y(1-\sqrt{x^2+y^2})^4=0 \Rightarrow y=0 \text{ or } 1+(1-\sqrt{x^2+y^2})^4=0, \text{ which is rejected}$.
So $y=0$ and $x=0$.So $(0,0)$ is the only equilibrium solution.
If we set $f_1(x,y)=-y-x(1-\sqrt{x^2+y^2})^2$ and $f_2(x)=x-y(1-\sqrt{x^2+y^2})^2$, then we have
$\frac{\partial{f}}{\partial{x}}=-(1-\sqrt{x^2+y^2})^2+\frac{2x^2(1-\sqrt{x^2+y^2})}{\sqrt{x^2+y^2}}$.Is this right?
Because in order to determine the stability, we compute the Jacobi matrix at the equilibrium solution, but $\frac{\partial{f}}{\partial{x}}(0,0)$ is not defined.
Am I doing something wrong? (Thinking)
Is this right?
Hey evinda!
$\pd {f_1}x$ is a limit isn't it?
More specifically:
$$\pd {f_1}x(0,0)=\lim_{h\to 0} \frac{f(0+h,0)-f(0,0)}{h} = \lim_{h\to 0}\frac{-h(1-\sqrt{h^2})^2-0}{h}=-1$$
(Thinking)
I like Serena said:
Hey evinda!
More specifically:
(Thinking)
Ah yes... Then we have
$$\pd {f_1}x(0,0)=-1 \\ \pd {f_1}y(0,0)=-1 \\ \pd {f_2}x(0,0)=1 \\ \pd {f_2}y(0,0)=-1$$
and thus the Jacobi matrix at $(0,0)$ gets the following form:
$J=\begin{pmatrix}
-1 & -1\\
1 & -1
\end{pmatrix}$, right?
Then we get that the eigenvalues are these ones: $-1 \pm i$ and so $Re(\lambda_1)=Re(\lambda_2)=-1<0$ which implies that the equilibrium is asymptotically unstable.Is the above correct so far? (Thinking)
What can we say about the limits $\lim x(t)$ and $\lim y(t)$ where $(x,y)$ any other solution of the problem? (Thinking)
evinda said:
... and thus the Jacobi matrix at $(0,0)$ gets the following form:
$J=\begin{pmatrix}
-1 & -1\\
1 & -1
That's the correct Jacobian.
But doesn't $Re(\lambda_1)=Re(\lambda_2)=-1<0$ mean that it's stable? (Shake)
After all, the solutions are of the form $\tilde x=\tilde x_0 e^{\pm it} e^{-t}$, which converges doesn't it? (Wondering)
Let's take a look at a streamplot:
What does it show us about those limits? (Wondering)
EDIT: Note in particular that solutions close to (0,0) converge.
Therefore (0,0) is asymptotically stable.
  • · Replies 16 ·
  • · Replies 65 ·
  • · Replies 0 ·
