Equivalence Relations on Z: Proving m~n and Describing the Partition
The discussion focuses on proving that the relation defined by m~n if m-n is a multiple of 10 is an equivalence relation on the integers Z. The participants demonstrate the reflexive, symmetric, and transitive properties required for equivalence relations, correcting misconceptions about the nature of the differences involved. They clarify that m-n must be a multiple of 10 rather than zero, and provide detailed proofs for each property. Additionally, they describe the associated partition of Z, indicating that integers can be grouped based on their equivalence classes modulo 10. The conversation emphasizes the importance of clear notation and accurate definitions in mathematical proofs.
nitenglo
Prove that the following is an equivalence relation on the indicated set. Then describe the partition associated with the equivalence relation.
1. In Z, let m~n iff m-n is a multiple of 10.
2. The attempt at a solution
Reflexive: m-n = 0
0 Z, and 0 is a multiple of every number, therefore, m~n
Symmetric:
1. m~n
2. m-n = 0 Z, and 0 is a multiple of every number
3. -(m-n) = 0 Z, and 0 is a multiple of every number
4. -(m-n) = n-m = 0 Z, and 0 is a multiple of every number
5. Therefore, n~m
Transitive:
1. m~n and n~t
. and n-t = 0 Z, and 0 is a multiple of every number
3. (m-n)+(n-t) = m-t = 0 Z, and 0 is a multiple of every number
4. Therefore, m~t
You have have asserted that various numbers are "in the indicated set", but you haven't given any proof they are.
I edited the problem.
For part 2 I think what you mean to say is n - n = 0 (which is clearly divisible by 10). In this problem you're not looking for the difference to be 0, but rather a multiple of 10 (say 10x for some integer x), or that 10 divides their difference.
Thank you fourier...can you take a look at the work I did for proving m~n and see if it is correct.
Reflexive: m-n = 0
To prove the relation is reflexive, what you must prove is that m \sim m.
Symmetric:
1. m~n
It isn't true that m-n must be zero. You probably mean that m-n = 0 (mod \ 10).
Transitive:
1. m~n and n~t
It is not true that m-n must be zero.
Reflexive: m-n = 0
Symmetric:
1. m~n
5. Therefore, n~m
Transitive:
1. m~n and n~t
4. Therefore, m~t
Please, only edit the Original Post to correct typos and/or errors in the statement of the problem. Additionally, edit the OP to supply any essential information you may have initially left out. It may help clarify matters, if you indicate what is changed in the edit.
If you are making corrections to your solution of a problem, it's best to add another post to the thread. Otherwise it's nearly impossible to follow the sequence of events in the thread.
for part 2 you start with ##m \sim n## which in this case means m - n = 10x for some x ∈ ℤ & you have to show ##n \sim m##. Part 3 is a bit more complicated because you have ##m \sim n## which means m - n = 10x for x ∈ ℤ & ##n \sim t## which means n - t = 10y for y ∈ ℤ.
Reflexive: m-n = 0
You mean m~m. Then m- m= 0.
0 Z, and
Symmetric:
1. m~n
No, if m~n then m- n is a multiple of 10, not necessarily 0.
5. Therefore, n~m
Transitive:
1. m~n and n~t
[/quote]
Again, no! m-n is a multiple of 10, not necessarily 0. m-n= 10k, for some integer k and n- t= 10j for some integer j. So m- t is equal to what?
4. Therefore, m~t
Sorry I forgot to post this earlier...this is what I have came up with so far...
Reflexive: m-n = m=n mod 10. ∈ ℤ and is a divisible by 10 (same as being a multiple) Therefore, m~n
Symmetric: m~n = m-n = n mod 10. ∈ ℤ and is a divisible by 10. Then -(m-n)= n-m = n=m mod 10. Therefore, n~m
Transitive: ?? I am kind of stuck here... I know that if m~n and n~t then show m~t.
I think that it goes like this...
n= t= m mod 10. and m=n= t mod 10 therefore m~t.
But I am not sure.
You're trying to prove ##m \sim n## is an equivalence relation, where ##m \sim n## if ##m \equiv n\, (mod 10)##, so what does it mean when ##m \equiv n\, (mod 10)##? For symmetry for example the problem is to show if ##m \equiv n\, (mod 10)## then ##n \equiv m\, (mod 10)##, how would you do that?
So I redid it again...here it goes.
Reflexive: let n∈ℤ, then for any n∈ℤ n-n=0 is a multiple of 10. ∴ n~n
Symmetric: Let m, n∈ℤ and m~n. Then m-n is a multiple of 10. That is m-n ≡ 10k, k∈ℤ and n-m ≡ 10(-k), -k∈ℤ. ∴ n-m is a multiple of 10 and n~m.
Transitive: Let m, n, p∈ℤ and m~n, n~p. Then m-n, n-p are multiples of 10. That is m-n ≡ 10k1 and n-p≡10k2, k1, k2∈ℤ. Now (m-n)+(n-p) ≡ 10k1 + 10k2, k1, k2∈ℤ ≡ 10 (k1 + k2), k1, k2 ∈ℤ ≡ m-p ∴ m-p is a multiple of 10 and m~n, n~p shows that m~p.
Partition:
Fix n∈ℤ. Then m~n and m-n is a multiple of 10.
m-n = 10k, k∈ℤ
m= n+10k, k∈ℤ
∴ n= {m: m= n+10k, k∈ℤ} =n+10k : k, ∈ℤ
I thought you had to show that you get a partition of the integers but they just want a description... I think I get what you did for that part but maybe you could clean it up & actually describe in words what all that means. The rest looks ok to me.
Certainly your notation is bad- "n= {m: m= n+10k, k∈ℤ}" you have an integer, n, equal to a set of integers!
Perhaps you meant "[n]' on the left, indicating the equivalence class n is in. Of course, there are only 10 such equivalence classes. You could just write each out:
{0, 10, -10, 20, -20, ...}, {1, 11, -9, 21, -19, ...}, etc.
  • · Replies 30 ·
