Errors in Left and Right Approximation in Calculus?
The discussion revolves around calculating errors in left and right approximations for the integral of the function f(x) = x^3 over the interval from 0 to 10. Participants are exploring how to determine the number of subdivisions needed to achieve a specific error threshold of 0.01.
  • Participants discuss the formulas for left and right approximations and their relationship to the actual integral. There are attempts to clarify the meaning of error in this context and how it relates to the approximations. Some express confusion about the equations and seek clearer explanations.
There is ongoing dialogue with some participants attempting to clarify concepts related to the approximations and error calculations. While some guidance has been offered, there is no explicit consensus on the best approach to take, and confusion remains regarding the calculations and definitions involved.
Participants have noted that some of the equations and concepts discussed may not have been covered in their coursework yet, leading to further questions about the foundational understanding required to tackle the problem.
aizeltine
Moderator's note: This thread is a perfect example of what not to do in the homework help forums. It is unacceptable for the opening poster not to work through the problem and to demand answers. It is inappropriate for the helper to give out those answers, or tell the poster exactly what to do. If it were not already too late, I would have closed/deleted this thread. Since it is too late, I'm leaving it up with this warning that it's an example of what not to do.[/color]
How do you calculate an error using left and right approx? How do you find the exact answer to that integral?
Here's the homework question.
How many subdivisions would you need to use so that the error in the left and right approximations of the function f(x)=x^3 from x=0 to 10 was 0. 01?
So, I know how to calculate the area of right and left but how do I find the real answers first?
And how do i make the error equal to 0.01?
Thanks. Calculus is hard so please help.
here is the calculation of my left and right approximation using 10 subdivisions.
L10= f(0)+f(1)+f(2)+f(3)+f(4)+f(5)+f(6)+f(7)+f(8)+f(9)
= 0+ .25+ 4+20.25+ 64+156.25+324+600.25+1042+1640.3
=3851.3
R10= f(1)+f(2)+f(3)+f(4)+f(5)+f(6)+f(7)+f(8)+f(9)+f(10)
.25+ 4+20.25+ 64+156.25+324+600.25+1042+1640.3+ 2500
=6351.3
if you get the average of the two you have 3400.87
so, Now what?
say you subdivide into n equal intervals, the approximations are
Left
[tex]L = \sum_{i=0}^{n-1}f(x_i)\Delta x[/tex]
Right
[tex]R = \sum_{i=1}^{n}f(x_i)\Delta x[/tex]
Now in this case as x^3 is concave up you know that
[tex]L < \int_0^{10}x^3dx < R[/tex]
So the error in each approximation is less than R-L, if we use that as an approximation of the error or at least as a bound on it, then we get
[tex]e < R-L = \sum_{i=1}^{n}f(x_i)\Delta x-\sum_{i=0}^{n-1}f(x_i)\Delta x = (f(x_n) -f(x_0))\Delta x[/tex]
What?I still don't understand!we haven't learned those equations yet.
Left
Right
What does "e" mean? just please tell me instructions on how to get the answer. please
i pretty much have, but note we don't tell you how to get an answer here, but rather help you find it yourself
the formula is just a quick way of writing what you are attempting, so consider you L10, this has n=10 subdivsions with [itex]\Delta x = \frac{10}{10}= 1[/itex], whilst the x_i is the value of x at the left side of a subdivision
[tex] L_{10}= f(0)+f(1)+f(2)+f(3)+f(4)+f(5)+f(6)+f(7)+f(8)+f(9) [/tex]
[tex] = f(0).1+f(1).1+f(2)+f(3).1+f(4).1+f(5).1+f(6).1+f(7).1+f(8).1+f(9).1 [/tex]
[tex] = \sum_{i=0}^{9} f(x_i).1[/tex]
[tex] = \sum_{i=0}^{10-1} f(x_i) \Delta x[/tex]
whihc is exactly what we had above with n=10
As for the "e" in the above post this is an upper bound for your error
I still don't get it. Can you just please tell me how to find the ACTUAL answer for the f(x) x^3 from 0 10? i will just find the error myself.
to desribe "e" better, assume we kow the value of the integral
[tex]I = \int_0^{10}x^3dx[/tex]
Now for a given n subdivsions as discussed before we know
[tex]L(n)< I< R(n)[/tex]
consider the error in the right approximation
[tex]e_R(n) = R(n) - I >0[/tex]
[tex]e_L(n) = I-L(n)>0[/tex]
note if we sum the error in each
[tex]e_L(n) + e_R(n) = R(n) - L(n) >0[/tex]
do you mean adctually calulating the integral? It is as follows
[tex]I = \int_0^{10} x^3 dx = (\frac{x^4}{4})|_0^{10} = (\frac{10^4}{4})-0 =2500[/tex]
=3851.3
=6351.3
so, Now what?
I have read back over this and you are not approximating the integral correctly, for example f(1) should be:
[tex] f(1) = 1^3 = 1[/tex]
where as you appear to be using the form of the integral which is not correct
[tex] F(x) = \frac{x^4}{4}[/tex]
[tex] F(1) = \frac{1}{4}=0.25[/tex]
You are killing my brain!
My question is simple. how do u calculate the actual answer?
Look at this website
https://docs.google.com/viewer?a=v&...XNBcXP&sig=AHIEtbSxVTswFleaJW05ZNeAXh5TeRCCGg
Notice that in the second page, there is an integral equation where it got ln 2=0.693 as the answer. That 0.693 is just what I need. And that is the actual answer that I need to compare my errors with.
If you want a quick way to do this problem I suggest you try and make sense of mny first post
Furthermore it sounds like you're a little confused about what the left and right aproximations are, so I would suggest you try and draw the problem close to scale, for say n=5 subdivisions
The integral is as follows
Apologies as i think we have been one post out of sync, there is some useful stuff in what i have written so suggest you still take a look
So 2500 is the Actual answer right?
correct
lanedance said:
correct
Thank you.
no worries going back to post 2, for n equal subdivisons or [itex]\Delta x = \frac{10}{n}[/itex] you know the sum of the absolute error of the right and left approximations is
[tex]e_L(n) + e_R(n) = (f(10) -f(0))\Delta x = (10^3-0) \frac{10}{n} = \frac{10^4}{n} = \frac{10000}{n}[/tex]
and in fact as n gets big you can make the assumption through similar triangles that
[tex]e_L(n) \approx e_R(n) \approx \frac{5000}{n}[/tex]
In fact as n gets big you could say e_L(n) ~ e_R(n) and so each one contributes half the error or e_L(n) ~ e_R(n) ~ 5000/n, so its worth comparing this with your estimates
Wait. I could just use 1000/n to be able to get the error of 0.01?
No, why would you change the number to 1000?
You could howerver use the formula I prescribed and solve for n
What equation? And can you please clarify what each variable mean?
no sorry, I think I have been pretty detailed in my explanation, you need to attempt some work
Thank you. I love you so much!
  • · Replies 16 ·
