Estimating singular values from QR decomposition
  • Level: Graduate
  • Thread starter Thread starter vibe3
    Decomposition
vibe3
I have a matrix for which I know its QR decomposition: [itex]A = QR[/itex]. I want to estimate the largest and smallest singular values of [itex]A[/itex] ([itex]\sigma_1[/itex] and [itex]\sigma_n[/itex]) however in my application it is too expensive to compute the full SVD of [itex]A[/itex].
Is it possible to estimate the largest/smallest singular values from the QR decomposition? The only result I've been able to find so far is
[tex] \left| \prod_i r_{ii} \right| = \prod_i \sigma_i[/tex]
where [itex]r_{ii}[/itex] are the diagonal entries of [itex]R[/itex]. I'm not sure if this implies that the singular values of [itex]R[/itex] are the same as the singular values of [itex]A[/itex]. If that's true, it might be possible and less expensive for my application to compute [itex]SVD(R)[/itex] rather than [itex]SVD(A)[/itex].
The singular values of ##A## are the nonzero eigenvalues of ## A^H A ## or ## A A^H ##. The largest eigenvalue of a matrix can usually be computed using the power method with just a few iterations. The smallest eigenvalue of a full-rank matrix is the largest eigenvalue of the inverse, so again the power method can work; if you have hte QR the inverse is cheap to compute. If not full rank ... I'm not sure what clever methods there are.
jason
The problem is that my matrix [itex]A[/itex] is very ill-conditioned, so computing eigenvalues from [itex]A^T A[/itex] is unreliable (hence the reason I'm computing the QR decomposition instead). I'm looking for a numerically stable way to estimate the singular values from the QR decomposition for ill-conditioned matrices.
Suppose we have [itex]A = QR = U \Sigma V^T[/itex]. Then suppose the SVD of [itex]R[/itex] is [itex]R = U_r \Sigma_r V_r^T[/itex].
Because [itex]Q[/itex] is orthogonal, [itex]A = Q U_r \Sigma_r V_r^T[/itex] which implies [itex]U = Q U_r[/itex] and [itex]V = V_r[/itex]. This would then mean that [itex]\Sigma = \Sigma_r[/itex] and so the singular values of [itex]R[/itex] and [itex]A[/itex] are the same. Is this correct logic?
jason
Did you meant to write that the singular values of A are the square root of the eigenvalues of [itex]A^HA[/itex] ?
Yes, this is mathematically sound. A and R would have the same singular values.
oops. yep.
