Exam question, simple physics calculus.
The discussion revolves around a physics problem involving the calculation of the volume of an iron screw placed in a bowl of water. The original poster presents a scenario where the mass of the bowl with water is 395g, and the mass with the screw is 565g. The problem raises questions about the relationship between mass, volume, and density, particularly how the displacement of water affects the calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use the densities of iron and water to derive the volume of the screw, questioning the validity of their calculations and the teacher's feedback. Some participants suggest visual aids to clarify the displacement concept, while others point out potential errors in the equations used. There is a discussion about whether to subtract the water's density in calculations and the implications of the mass difference.
The conversation is ongoing, with various interpretations of the problem being explored. Some participants express agreement with the original poster's reasoning, while others offer corrections or alternative perspectives. There is no clear consensus, but several participants provide insights that may guide further understanding.
Participants note the importance of correctly identifying the initial conditions and the implications of water displacement on the calculations. There is also mention of the need to adhere to forum rules regarding unrelated questions, indicating a structured approach to discussion.
An Indiot
A full bowl cointains water, its mass is 395g.An iron screw is placed on the bowl and the mass is now 565g.
This seemed simple, but I asked my teacher to clarify and he said that upon placing the screw on the water an equal volume of water is removed so the volume remains the same.
Find the screw's volume.
Iron's density = 7,86g/cm^3.
water's density = 1g/cm^3
screw volume + water volume = 395cm^3
water volume = 395g/1g/cm^3
Water volume =395cm^3
565g-395g =170g
7,86g/cm^3 - 1g/cm^3 = 6,86g/cm^3
(it's pretty hard for me to explain why I did this but basically if I don't minus the water's density the volume, the answer won't compute the water that was removed)
170g/6,86g/cm^3
24,71cm^3
Teacher said it was wrong because this made no sense/was wrong and that I was too complicated, the part was wrong for him was this one:
7,86/cm^3 - 1g/cm^3 = 6,86/cm^3
so the solution was:
170g/7,86cm/cm^3
21,something cm^3
I tried to proove that I was right and I did this
x= water's volume
y= screw's volume
dx= water's density
yx= screw's density
x+y=395
x.dx+y.dy=565
dx=1
dy=7,86
x+7,86y =565
x+7,86y-6,86y = 565 -6,86y
x+y = 565 - 6,86y
395 = 565 - 6,86y
395-395 = 565 -395 - 6,86y
0 = 170 - 6,8y
0+6,86y = 170 -6,86y +6,86y
6,86y = 170
6,86y/6,86 = 170/6,86
y=24,78134
Where did I go wrong.
Haha, all righty, first of all 595 - 325 = 270!
http://img26.imageshack.us/img26/2167/screenshotdocument1micr.png
I sometimes find drawing a picture simplifies things. The first picture on the left shows the amount of water (LIGHT BLUE WATER) that will be displaced AFTER the screw is dropped in - in the 2nd picture the screw is in and that LIGHT BLUE WATER there before is now displaced.
So before, the mass was
mass of water that stays + mass of light blue water = 325g
After, the mass is
mass of water that stays + mass of steel = 595g
I guess this makes it clearer that mass of steel - mass of light blue water = 270g
I hope you can take it from here.
All you need now is to remember that DENSITY = MASS DIVIDED BY VOLUME!
For some reason I got the screw's volume as being around 39cm3 or something. Might be wrong, sorry tired, 5am over here!
You have a wrong number in your first equation.
You wrote: x+y=395
when it ought to be x+y=325 because 325 is the volume in cm^3 of the bowl. You will get the correct answer if you correct this.
I am sorry the numbers are supposed to be 395 and 565.
Do I need to minus the water's density and divide 170 by that? or just divide 170 by the screw's density?
Wow it's unbelievable, this is why I failed the exam and thus the whole subject.
He kept telling me that to find the mass of the screw I just had to do
(565-395)/7.86
I tried to explain him why I thought that was incorrect, is it possible that if I complain about this he can unfail my test?
(565-395)/7.86
I agree with you. The problem as you state it says that "and he said that upon placing the screw on the water an equal volume of water is removed so the volume remains the same."
Thus if you divide the difference as above by the density of the bolt, you do not get the volume of the bolt.
I agree with your answer of 24.78 cm^3. Here's why:
mw + mb = 565
where mw is the mass of water after a mass of water equal to the volume of the bolt multiplied by the density of water comes out and where mb is the mass of the bolt.
mw = 395 - rhow * vb
where rhow is density of water and vb is volume of bolt.
mb = rhob * vb
where rhob is density of bolt
Solving
565 = 395 - rhow * vb + rhob * vb
vb = 24.78 cm^3
So, once again, I agree with you.
PS Sorry about my misread yesterday on the numbers. I was using a Kindle that has a very small print so I misread the number.
Thank you very much all of you.
One more question.
I had a problem on uniform acceleration.
I had to calculate the distance a car traveled in a given time given its starting speed and acceleration.
I used the formula:
x=Vo.t+ (Vf-Vo)/2.t
Where Vf= a.t +Vo
Would this be the same as the traditional formula
x= Vo.t+ a/2.t^2
Said teacher corrected me
x= Vo.t+ (Vf-Vo)/2.t^2
That's wrong right?
Should I roundhouse kick him? I'm mad.
According to forum rules you should start a new thread with your second, unrelated question. But I shall tell you this: If you are using a formula, terms that are added absolutely must have the same dimensions.
