Expansion coefficient of liquid Propane ?
4 replies · 24K views
bitman
Hi
Does anyone have a figure for this.
I've trolled the net for nearly 2 hours now with no success.
Any help or guidance much appreciated.
Bitman
CRC handbook lists the density at various temperatures fordifferent pressures:
At 1 atmosphere (gas)
T (k) density(mol/L)
250 0.050
275 0.045
300 0.041
325 0.037
350 0.035
375 0.032
400 0.030
450 0.027
500 0.024
At 10 atmospheres (liquid)
275 11.962
300 11.102
Also note that at 1 atmos and tempertures > 0C that mgb's figures agree with the ideal gas law with at most 2% error. So if you are working in this range then you don't need to look it up, you can calculate it.
PV = NRT
with N and P held constant.
dV/V = dT/T
or dV/dT = V/T
Hi
I'm really interested in the liquid properties. I can do the gas stuff (mostly, when I get the sums right :-0 ).
I'm interested in the change of density between 353k (448.9psi) and 293k(124.6 psi).
I thought as it was a liquid it was incompressable thus the pressure didn't matter. If so it should have a fixed coefficient of expansion.
Your figures, mgb_phys, at 10 atm seem to indicate -0.288% per degree C.
So assuming the pressure change is inconsequential I'm looking at a reduction in liquid density of 17.28%.
Thanks for the info and the time.
Please protest if you think these conclusions are incorrect.
Bitman
The handbook only gives 1Mpa and 10Mpa - you can interpolate the values you need.
1Mpa
275 = 11.962
300 = 11.102
325 - gas
10Mpa
325 = 10.860
350 = 9.973
375 = 8.905
293K/124.6psi looks very close to boiling point
