Find Expected Value of X(n) from Uniform Distribution
  • Thread starter Thread starter apalmer3
    Maximum
To find the expected value of the largest observation X(n) from a uniform distribution on the interval [0, θ], first determine its distribution function F(t) as F(t) = (t/θ)^n for a sample size n. The density function f(t) is obtained by differentiating F(t) with respect to t. The expected value of X(n) can then be calculated using the integral ∫_0^θ t f(t) dt. This method provides a clear approach to deriving the expected value from the uniform distribution.
apalmer3
I swear that I used to know this.
If you have an independent sample of size n, from the uniform distribution (interval [0,\theta]), how do you find the Expected Value of the largest observation(X(n))?
If X_{(n)} is the maximum in the sample, you first find its distribution. Since you have a random sample of size n, you can write
<br /> F(t) = \Pr(X_{(n)} \le t) = \prod_{i=1}^n \Pr(X_i \le t) = \left(\frac{t}{\theta}\right)^n<br />
Differentiate this w.r.t. t to find the density f(t), and the expected value is
<br /> \int_0^{\theta} t f(t) \, dt<br />
The standard _A " operator" maps a Null Hypothesis Ho into a decision set { Do not reject:=1 and reject :=0}. In this sense ( HA)_A , makes no sense. Since H0, HA aren't exhaustive, can we find an alternative operator, _A' , so that ( H_A)_A' makes sense? Isn't Pearson Neyman related to this? Hope I'm making sense. Edit: I was motivated by a superficial similarity of the idea with double transposition of matrices M, with ## (M^{T})^{T}=M##, and just wanted to see if it made sense to talk...
