Experimental calculated values and Uncertainties
The discussion focuses on calculating values and uncertainties based on significant figures. Users share their calculated values of 0.3765 with an uncertainty of 0.1274 and 0.69897 with an uncertainty of 0.0789, and how they rounded these figures according to ASTM protocol. There is a debate on whether uncertainties should have more than one significant figure, with the consensus leaning towards reporting them in line with the least precise measurement. The importance of consistency in reporting significant figures is emphasized, and the conversation raises questions about the correct way to report uncertainties in calculations. Ultimately, the discussion highlights the complexities and nuances of significant figures and uncertainty reporting in scientific calculations.
Yoshimine
1. After I calculated from my original data with lowest significant figure of 3, I got 0.3765 and uncertainty of 0.1274
2.original data with lowest significant figure of 2 .calculated value of 0.69897 and uncertainty of 0.0789
This is how I answered
1. 0.377 uncertainty of 0.127
2. 0.70 uncertainty of 0.01
My teachers dosent mark our workbook so we don't know whether they are correct or not
any help is appreciated,thank you.
I use the ASTM protocol for rounding (5's round to an even number: .15 rounds up while .25 rounds down). By that rule your 0.3765 rounds to 3 sig figs as 0.376, 0.1274 rounds to 3 sig figs as 0.127, 0.69897 rounds to 2 sig figs as 0.70, and 0.0789 rounds to 2 sig figs as 0.08.
Can the uncertainty be 3 significant figure?
To me, it would not make sense to report an uncertainty with more than one significant figure. Additionally, it wouldn't make sense to report something like '0.377 +/- 0.1' -- because your uncertainty is in the tenths place, the hundredth and thousandth places of the measurement are pretty worthless.
If you want a vaguely more authoritative reference, a quick google search will turn up http://www.wellesley.edu/Chemistry/Chem105manual/Appendices/uncertainty_sigfigs.html .
I need to to be consistent with the original data and significant figur for uncertainty need to be 1 for my answer, but I cannot follow those two because it would not make sense.does it mean that there is no correct way to report?
