Explain why applying different forces to objects of different masses result in different accelerations
9 replies · 2K views
helloword365
This is the question:
If the standard body of 1 kg has an acceleration of magnitude a (in meters per second per second), then the force (in newtons) producing the acceleration has a magnitude
equal to a. We now have a workable definition of the force unit.
Explain why applying different forces (N) to objects of different masses result in different accelerations.
NA
I don't really get why applying different forces to objects of different masses would result in different accelerations. I read my textbook, and I understand the formula F(net) = m*a, and I think the reason may be because mass is inversely proportional to acceleration ? But this doesn't really explain why the unit force and acceleration are the same.
A counter example. 2 N force applying 2 kg mass and 1 N force applying 1 kg mass result in same acceleration of 1 m/s^2.
Reply
Hi, thanks for the counterexample, but how does this explain that different forces to different masses result in different accelerations?
The counterexample shows that different forces to different masses do not have to result in different accelerations.
[tex]a=\frac{F}{m}[/tex]
We can choose F and m as we wish. Their ratio F/m decides acceleration.
Reply
Imagine single force ##\mathbf F## acting on mass ##m## on a frictionless surface. Let ##\mathbf a## be the acceleration of the mass. Now look at the figure below.
The figure on the left shows a bird's eye view of two such identical masses being acted upon by identical forces ##\mathbf F##. They have identical accelerations ##\mathbf a## and are started from rest at the same time.
Since the accelerations of the two masses are the same, they move as one. This means that they can be glued together and nothing changes. This is shown in the figure below, middle.
Well, what do we have here? It is shown in the figure below, right. We have mass ##2m## acted upon by total force ##2\mathbf F## having acceleration ##\mathbf a.## Clearly, for constant acceleration, if one doubles the mass one has to double the net force. In terms of an equation $$\mathbf a=\frac{\mathbf F_{\text{net}}}{m}.$$
Reply
Isn't this question allowing too many variables at once?
It seems to me that it should be:
"Explain why applying different forces (N) to a standard body of 1 kg mass result in different accelerations."
or
"Explain why applying same force (N) to objects of different masses result in different accelerations."
As a matter of fact, applying different forces (N) to objects of different masses may very well result in similar accelerations.
If the magnitude of the applied force increases or decreases at the same rate than the magnitude of the mass does, there is no reason to observe any change in the magnitude of the resulting acceleration.
Reply
This is a truly bizarre question. It can be rephrased as "why are all accelerations not of the same magnitude?"
Given that a force of zero produces zero acceleration, the question becomes "explain why non-zero acceleration is possible".
Reply
If f=ma, then a = f/m
Open a couple of books several times - say five for each book - and write down the page numbers you see for each book (simple but by no means perfect) random number generation.
Now insert the numbers into the equation using those from the first book as f and those from the second book as m.
Do you get the same number every time for a the acceleration, or does its value vary depending on the numbers you use?
Question solved.
Reply
hi, thank you! This makes a lot of sense.
or
thank you as well :). And to everyone too as well in this thread. (just reading through them, one by one.)
Reply
