Extension of upper spring with three masses in decelerating elevator
  • Thread starter Thread starter aruji73
    Calculations
7 replies · 14K views · last reply
aruji73
What is the distance the upper spring is extended from its unstretched length?
Now, three masses m1 = 3.3 kg, m2 = 9.9 kg and m3 = 6.6 kg hang from three identical springs in a motionless elevator. The springs all have the same spring constant of 229.57N/m
Now the elevator is moving downward with a velocity of v = -2.3 m/s but accelerating upward with an acceleration of a = 4.8 m/s2. (Note: an upward acceleration when the elevator is moving down means the elevator is slowing down.)
cm
I did
(3.3(9.8+4.8))/229.57=0.20987 m =20.987 cm
cm
I did
That looks good to me.
Is there a problem regarding significant digits?
Hi I am not sure my answer is supposed to be in cm but I am sure I have done it right puzzling indeed
In your problem you have mensioned three springs and three masses. Whether the springs are connected with each other? If yes, who?
springs are connected is m1 at top is connected to m2 in middle which is connected to m3 in the bottom
So, the spring at the top is supporting, directly or indirectly, all three masses? Won't that increase the tension in it?
this is the pic
Right, so what is the tension in the top spring? If you're not sure, start with the free body diagram of the bottom mass and work up.
