Eye protection while watching a total solar eclipse
  • Context: Stargazing
  • Thread starter Thread starter DrClaude
    Eclipse Eye Solar
41 replies · 7K views
I got myself some glasses for the upcoming solar eclipse, but they are very dark! They work fine for looking at the Sun in all its glory, but I suspect I won't ne able to see anything of interest during the eclipse.
Does anyone have experience filtering out the harmful UV while still being able to see something during the eclipse?
Reply
Astronomy news on Phys.org
They should be fine for everything other than totality. I used some to watch the annular eclipse a few months ago and it was fantastic. For totality, I don't think you need any protection.
Reply
  • Love
Yes, good safety glasses are too dark to see anything except the sun (and corona?). You should plan to take them off and on. It's nice to look around and see other effects. The shadow patterns through leaved trees are fascinating. Apparently, animals also react strangely.
I don't know if those fast reacting welding masks may be safe and allow you to look around. Welding masks with shade numbers of 12 to 14 are supposed to be safe.
Personally, I would just flip the glasses up and down.
PS. I will miss both total eclipses. I was in Fort Worth when it was total in the Northwest and I am now in the Northwest when it will go through Fort Worth. :-(
Reply
  • Sad
I believe one needs to be careful with autodarkening ones. My welding helmet will darken when first placed in the solar flux but seems to respond only to the fluctuation (AC) to maintain (and recalculate) the darkening ongoing. So better to use a simple old-fashioned welding glass. Beware.
https://www.garagejournal.com/forum/threads/welding-helmet-eclipse-fail.368737/
Reply
NASA Guidance: https://science.nasa.gov/eclipses/safety/
To put it simply: you wear eclipse glasses during the partial phases and take them off during totality.
Reply
I am organizing a grass roots effort to help prevent blindness in wildlife during eclipses. It has been pretty unsuccessful so far, but we hope to improve our success rate in this upcoming eclipse across the US. You can sign up at the link below if you are willing to help. Your rabies vaccinations must be up to date, BTW. :wink:
Sign up here
https://www.cnn.com/2024/03/13/world/eclipse-zoo-animal-behavior-nasa-soundscapes-scn/index.html
Follow-up question:
During totality, it is safe to view the eclipse directly; it is also safe to remove the solar filter from a telescope/lens. What about extended viewing through binoculars? I don't know what the optical properties of the corona are (e.g. spectrum) and so wonder if increased UV dose is a possibility.
Reply
Andy Resnick said:
Follow-up question:
BE CAREFUL! Telescopes and binoculars gather MUCH MORE light than the naked eye. You can do real damage in a split second.
Reply
The corona is very, very hot. Its thermal spectrum peaks in the x-rays. Plenty of UV. Fortunately, it is not very bright.
The problem with "I'll only look during totality" is that there is no warning that totallity is going to end. Bailey's Beads are bright and I would say they last a second, possibly less. Then the sun gets even brighter.
This is a huge risk. I wouldn't take it. If forced, I'd wear a patch over one eye, so I'd at least have one left.
Reply
Andy Resnick said:
Follow-up question:
That's an extraordinarily interesting question, IMHO, as when I plug the different temperatures for the sun(5800 K) and its corona(3,000,000 K) into my Planck's Law spreadsheet, the difference between the two tells me that looking at the corona is between 3500 (@ 800 nm) and 54,000 (@ 400 nm) times as intense*. Yet, everyone and their mother says it's just fine to look at the total solar eclipse for as long as you like.
IMHO, your question might require its own thread, as the paradox just gets worse.
Unless of course someone can succinctly explain why, according to Plank's law, the sun's surface provides the earth with 1000 w/m² of power, the sun's corona provides the earth with 15,000,000** w/m² of power, yet we are not all dead?
*When measuring the 'B' value: W/m²/sr/nm
**Just a ballpark figure, as I'm extraordinarily bad at maths.
I have heard that some people use X-Ray or CT-scan reports (what's that black film called?) to view eclipses. I don't know how well they work though?
FactChecker said:
Best advice yet. :-)
It also is good for National Talk Like A Pirate Day. Arrggghhhh....
A fine PF source...
Because the corona is extraordinarily diffuse. It has a high temperature, but very little heat. Same reason you can out you hand in a 400 degree oven (without touching anything) with no problem, but not a pot of 212 degree boiling water.
Note that the sun's surface is right next to the corona. and the corona doesn't heat it up. They aren't even in equilibrium.
Reply
Yeah, that's about what I thought. According to exposure tables, the corona is 17 stops slower than the photosphere. 17 stops = optical density 5, so the total amount of light coming from the corona is 0.001% of the light from the photosphere. That's why it's safe to look at it unaided.
In terms of the relative spectra, if coronal UV light output is truly 50000x more than the photosphere (and that is something I am unable to verify), then the emitted UV from the corona is half the amount as compared to the UV emitted from the photosphere, which would indicate that observing through a lens is not advised (and probably not naked eye, either....), but UV photography of the corona could be interesting to try out, if you have the equipment.
I'm skeptical of the 50,000 number- I think it should be lower- but I have no alternate suggestion.
That is surely an approximation. The corona isn't even in thermal equilibrius with itself, so it doesn't really have a temperature. There is also an inner and outer corona, and the (bright) inner one is at least partially obscured by the moon.
Also - and this is not safety advice - glass is opaque to short-wavelengty UV.
Vanadium 50 said:
That is surely an approximation. The corona isn't even in thermal equilibrius with itself, so it doesn't really have a temperature. ...
Doesn't have a temperature? NASA says it's around 3,000,000 °F
@ ≈2:30 in the video
Yes, I had a solar filter crack once when my eye was not looking through the eyepiece. I was lucky. you might not be.
Reply
  • Wow
I dug out the horrible static UV filter/shield that came with my Harbor Freight stick welder and looked at the sun. I declare it sufficiently dark.....sun very dim and no afterimages on my aging retinas. I believe it is marked as a number 11. However, I do bump into terrestial objects without any optical inhibition. Very dark indeed and shin damage more likely than retinal damage.
Welding masks with shade numbers of 12 to 14 are supposed to be safe. I'm not sure if you can tell when UV is damaging your eyes. Some sunburn damage does not show up for a few hours. I recommend playing it safe.
DONT do it !!, please dont ... as per post #9
Dave
Reply
I know about this from photography. The color temperature of a light source tells you the black body temperature where the light was created. It has nothing to do with how much power the light itself has where you are. (LED lamps aren't black body, so ignore them for this discussion.)
For example: If a lamp has a 3200° kelvin color temperature, and you filter out 90% of the light entering your camera, what is left will still have the same 3200°k temperature. It will just be dimmer. Fewer photons, but the same range of frequencies. You can make the color temperature of a lamp go up by passing the light through a bluish filter (CTB) to reduce some of the lower frequencies. This would change the light's color to more closely resemble daylight. But it would still be dimmer because you have still reduced the total number of photons.
So you can't multiply the light output by 50000x simply because the color temperature is higher. The corona is extremely hot, but there are very few actual atoms there. Those atoms produce high frequency photons, but nowhere near as many photons as the sun's surface does.
Dave
Sigh... obviously that's good advice pre-and post- totality. I was asking about during totality.
Besides, there are plenty of solar-viewing binoculars on the market- those are to be used pre-and post-totality.
Again, I was asking specifically about viewing during totality.
Welding masks with shade numbers between 12 and 14 are considered acceptably safe- as long as they are arc-welding shades and not auto-darkening (or made for gas welding).
https://eclipse.aas.org/sites/eclip...Tech-Report-Solar-Eclipse-Eye-Safety-2023.pdf
Also, don't put one in front of a lens for photography- the optical quality of the shades are poor and will distort your image.
But that is the problem. Totality ends so fast and suddenly that with binoculars you'd have eye damage before you can blink.
Reply
If an auto-darkening welding mask is not fast enough, then you will not be fast enough. They go dark in 1/10,000 to 1/25,000 sec.
Reply
