F = MA 2011 # 14 (Creating a uniform sound)
  • Thread starter Thread starter SignaturePF
    Sound Uniform
9 replies · 2K views
SignaturePF
See:
https://aapt.org/physicsteam/2012/upload/exam1-2011-1-3-answers_1.pdf
Number 14
None that come to mind
I think this is a conceptual question where each needs to be more proportionally spread apart because it takes longer to reach the next object after colliding with the one before it.
You could work it in reverse imagine you are accelerating upward and use the s=1/2 a t^2
And so every second you are following a t^2 path which if you recall is something like:
1,3,5,7 separation between points which is 1,4,9,16
What is a t^2 path - where did you get those numbers (1,3,5,7) from?
Yes but how does that relate to this question? And why would you take the difference?
If you look at the spacing of pointsfor D they follow the 1,3,5,7 sequence or if you number the points from the bottom you get 1,4,9,16 so right there you know you have a parabolic function.
In contrast E tries to fool you as the points are spaced at 1,4,9,16 so might conclude that E is the answer.
and A isn't spaced as a parabola and is backwards
and B is evenly spaced so that's not a parabola
and C is spaced like A but still isn't a parabola
And how does a parobolic function signify that the sound is uniform?
