F uniformly continuous -> finite slope towards infinity
8 replies · 3K views
Stardust*
f uniformly continuous --> finite slope towards infinity
Given [tex]f:R \rightarrow R[/tex] uniformly continuous. Show that [tex]\limsup_{x\rightarrow \infty} \displaystyle|f(x)|/x<\infty[/tex] i.e.
[tex]\exists C \in R: \, |f(x)|\leq C|x|[/tex] as [tex]x \rightarrow \pm \infty[/tex].
The idea of uniform continuity:
[tex]\forall \varepsilon >0, \, \exists \delta>0:\, \forall x,y \in R, |x-y|<\delta \, \Rightarrow \, |f(x)-f(y)|<\varepsilon[/tex].
If f were a linear function, it could be quite easy...
But f is unknown, so I tried sth else:
let's say uniform continuity gives the certainty we can always find a box in which the studied part of the function's graph is contained properly.
In this case we need a corner of the box to be in 0 (as the denominator simply has |x-0|=|x|) and let the other corner move as far as possible towards infinity, along the x-axis. Moreover in vertical we have to forget the the typical |f(x)-f(y)|, leaving |f(x)| only.
This suggests that the contribution of f(y) must somehow be negligible, I mean we can find a larger side of length f(x) for the box to keep the function inside it, without caring about f(y).
These are my thoughts till now. The first problem is: are these ideas right?
The second one is: how to express them in a formal, mathematical language?
so how about picking e = 1, then there exists d>0 such that |f(x+d) -f(x)| < 1 for all x, now consider the function g(x) = x/d + f(0)?
Are you suggesting to use g(x) instead of f(x)?
Surely g(x) is uniformly continuous, but I find no clues about how it is useful...
Could you tell sth more?
what can you say about g(x) vs f(x)?
(may neeed to be careful with axis crossings so maybe coonsidering g(x)-g(0) and f(x)-f(0) would help)
In a previuos post you suggested to use g(x)=x/d+f(0).
I think you meant that even g(x) is uniformly continuous.
But I fear the presence of f(0) in the formula for g(x) does not affect things so much. You are just saying: take the value of f(0) and use it to build a convenient line crossing the y-axis at f(0). But it is well known that a straight line is uniformly continuous, and the connection between g and f is quite weak for me.
Now some thoughts of mine:
chosen [tex]\varepsilon[/tex], I find my d such that [tex]y=x+d=d[/tex] (for x=0). But if [tex]\varepsilon[/tex] is constant, it binds the range in which d can run, preventing y from 'reaching' infinity, while our limit should get to infinity.
I hope somehow there exists a greater value for [tex]\varepsilon[/tex], maybe the [tex]\psi=\sup_{i \in I}\{\varepsilon_i\}[/tex], where I is an appropriate set of index. But nothing suggests [tex]\psi[/tex] cannot be infinity...
Anyway I would like to do something like this:
[tex]\lim_{y\rightarrow \infty, x=0}=\displaystyle \left| \frac{f(y)-f(x)}{y-x}\right|=\lim_{y\rightarrow \infty}\left|\frac{f(y)-f(0)/f(y)}{y}\right|[/tex]
where the fraction f(0)/f(y)n should be negligible. But this cannot be said so easily at the moment. Moreover we want the whole fraction to be finite (at least minor than a certain C), which means the speed of f(y) and y can be compared.
Am I on the right way to the solution (right way... there exist many, I think, but I'm still looking for one :blushing:)?
could you convince yourself that g(x)>=f(x) for all x=nd, where n is a natural number?
the way we defined it g(0) = f(0)
But we know nothing about f(x) from g(x)... Anyway you are adding a linear piece to the value of the original function in 0: this does not mean that g(x)>=f(x) always, unless you thought of g(x) as:
[tex]g(x)=x/\delta +f(x)[/tex]
In this case I do agree g(x) must be higher than or equal to f(x) itself, at least for every x>0.
as f is uniformly continuous with e=1, you know there exists d>0 such that |f(x+d) -f(x)| < 1 for all x
now consider the function g(x) = x/d + f(0), clearly
g(x+d)-g(x) = ((x+d)/d + f(0)) - (x/d + f(0)) = 1
so g is increasing at least as quickly or faster than f
Now your idea is clearer to me, but I still do not have a good idea to use g(x)...
Instead I think I have found something useful starting from your initial suggestion (maybe it's what you told me till this point, but unfortunately I have not fully understood).
The definition of uniform continuity tells that:
[tex]\forall \varepsilon >0, \, \exists \delta>0:\, \forall x,y \in R, |x-y|<\delta \Rightarrow |f(x)-f(y)|<\varepsilon[/tex]
So there exists a particular [tex]\varepsilon '[/tex] such that there is a [tex]\delta '[/tex] for which [tex]\forall x,y \in R,|x-y|<\delta'[/tex] and [tex]|f(x)-f(y)|<\varepsilon '[/tex].
This means that for this fixed quantities, we can always check that the function's graph is contained in small boxes of side [tex]\delta' \,and\,\varepsilon '[/tex]. The problem is that we have now fixed these values, while the objective is to make a statement which means there is a greater box containing the function as [tex]x \rightarrow \infty[/tex]. Then my idea is that we can consider all those smaller boxew from a generic x (as big as we want) back to 0, moving with steps of length [tex]\delta '[/tex]: this means we make a number of steps [tex]n=|x|/\delta '[/tex].
So taken x>0, we surely have:
[tex]|f(x)-f(x-\delta ')|<\varepsilon '[/tex]
[tex]|f(x-\delta ')-f(x-2\delta ')|<\varepsilon '[/tex]
[tex]|f(x-2\delta ')-f(x-3\delta ')|<\varepsilon '[/tex]
[tex]|f(x-n\delta ')-f(0)|<\varepsilon '[/tex]
With this last passage, we get to f(0), or even a little before it. Anyway things should work well.
Let's sum all this inequalities:
[tex]|f(x)-f(x-\delta ')|+f(x-\delta ')-f(x-2\delta ')|+|f(x-2\delta ')-f(x-3\delta ')|+\ldots+|f(x-n\delta ')-f(0)|<n\varepsilon '[/tex]
using the generalised triangular inequality, this brings to:
[tex]|f(x)-f(0)|=|f(x)-f(x-\delta ')+f(x-\delta ')-f(x-2\delta ')+f(x-2\delta ')-f(x-3\delta ')+\ldots+f(x-n\delta ')-f(0)|<n\varepsilon '[/tex]
So:
[tex]|f(x)-f(0)|<n\varepsilon '[/tex], but before we stated [tex]n=|x|/\delta '[/tex].
This leads to [tex]|f(x)-f(0)|<|x|\displaystyle\frac{\varepsilon '}{\delta '}[/tex]
Using the fact that:
[tex]|\,|f(x)|-|f(0)|\,|<|f(x)-f(0)|<|x|\displaystyle\frac{\varepsilon '}{\delta'}[/tex], and noting that the RHS is surely positive as we move to +infinity, we can write
[tex]|f(x)|<f(0)+|x|\displaystyle\frac{\varepsilon '}{\delta '}=|x|(\displaystyle \frac{f(0)}{|x|}+\frac{\varepsilon '}{\delta '})[/tex]
We chose our [tex]\varepsilon '[/tex], so we actually cannot control the
[tex]\delta '[/tex], but if it is greater than d'>|x|, there's no problem since the thesis is automatically fulfilled. If it is [tex]\delta ' <|x|[/tex] we can put:
[tex]|f(x)|<|x|(\displaystyle \frac{f(0)}{|x|}+\frac{\varepsilon '}{\delta '})<|x|(\displaystyle \frac{f(0)}{\delta '}+\frac{\varepsilon '}{\delta '})<[/tex] which is a constant value identified with C.
In the end, we showed that:
[tex]|f(x)|<|x|C[/tex], for a generic x, as asked by the exercise.
I hope this proof is correct...
