Fabricating bipedal-ish walker legs,
  • Thread starter Thread starter jehan60188
    solidworks
The discussion centers on the design and stabilization of a single-actuator walker for a class project, utilizing a Pololu motor. The original Klann mechanism was deemed too unstable due to interference among components, leading to a redesign that, while functional, lacks elegance. The participant seeks advice on how to document the redesign process effectively in a report, weighing the merits of including the unsuccessful model versus focusing solely on the new design.
  • Understanding of mechanism design principles
  • Familiarity with SolidWorks for 3D modeling
  • Knowledge of Pololu motor specifications and applications
  • Experience in technical report writing
  • Research stabilization techniques for mechanical designs
  • Explore methods to prevent component interference in robotic mechanisms
  • Learn best practices for documenting design failures in engineering reports
  • Investigate alternative walker designs and their mechanical advantages
Engineering students, mechanical designers, and hobbyists interested in robotics and mechanism design, particularly those facing challenges in stability and documentation of their projects.
jehan60188
so, I have to make a single-actuator walker for a class. it has to have two (unpowered) wheels, and two legs (it's a mechanism design class)
here's the motor i have to use: http://www.pololu.com/catalog/product/71
i've drafted out a klann mechanism, and even made an assembly in solidworks
http://imgur.com/8WbZb
but it's too rickety when I build it!
http://imgur.com/lDcE4
so rickety, that I can't test it.
but i know (from manually manipulating it) that the nuts, bolts, and legs will interfere with each other
so, two questions:
how can I stabilize, and how can I prevent interference?
thanks!
Well, I totally redesigned the mechanism.
It is inelegant, and boring, but it works.
The only problem is that this project includes a report, which I've done in great depth for the other mechanism. This current mechanism does not lend itself to a good report (one that can demonstrate my knowledge of the course material).
what should i do?
1) have a short report, or
2) add a section to my report discussing the failure of creating my previous mechanism, and a short section featuring the new mechanism?
jehan60188,
I believe you should write your report to include the un-successful model and explain how you redesigned the new model to fix what was wrong with the old one. Learning from your mistakes is much more valuable than getting it perfect first time.
10K
