Factoring (x-1)y² + (1-x²)
  • Thread starter Loppyfoot
    Factoring
10 replies · 3K views · last reply
Loppyfoot
Could someone help me factor,
((x-1)y^2)+(1-(x^2))
Is it possible to get to:
(x-1)(y^2-x-1)?
Yes, it is possible to get there.
Work with the left-hand term; 1-x2. When you factor that, things should start looking more manageable.
So I get (x-1)y^2 + (1-x)(1-x)
Where do I go from there in order to factor out the (x-1)?
What happens if you take out a -1 from one of the terms on the right?
Oh so, I got (x-1)y^2 - (x+1)(x-1) COrrect?
You can take out -1 from just the right-hand term.
(x-1)y^2 + (1-x)(1-x) = (x-1)y^2 + (-1) (?) (1-x)
Loppyfoot said:
Ok, so I got: (x-1)y^2 - (x+1)(x-1)
Incorrect. Look at the bolded term again. You're only taking -1 out of one quantity in the parentheses.
Oh, so would it be:
(x-1)y^2 - (-x-1)(x-1)?
But how do I get to:
(x-1)(y^2-x-1)?
Oops, sorry, in post #3 you made an error which I didn't notice initially.
You need to factor this correctly for it to make any sense. Once you have it factored correctly and you take out a (-1) from one of the terms in the parentheses, you should be able to then rearrange the expression into something that resembles what you're trying to show.
Hint: you already know how the result needs to look. Use this to your advantage...
All you really need are these 3 rules:
[tex]a^2-b^2=(a-b)(a+b)[/tex]
[tex]ab=-(-a)(b)=-(a)(-b)[/tex]
[tex]ab+ac=a(b+c)[/tex]
Notice the first difference of two squares, as fss has pointed out you have made a mistake in factoring the 1-x2, so fix that first before moving on.
