Factorisation Theorem for Sufficiency
  • Thread starter Thread starter Coolster7
    Theorem
The discussion revolves around the application of the factorisation theorem to likelihood functions to determine sufficiency statistics. Participants explore when to set h(x) to 1, noting that in some cases, like the exponential distribution, it is appropriate, while in others, like the Poisson distribution, h(x) must involve x and not just be a constant. The key point is that h(x) should not depend on the parameter θ, which clarifies its role in the factorisation process. Additionally, there is a query about whether the sample size n should be treated as a constant or if it needs to be sufficient for the parameter. Overall, the conversation emphasizes understanding the conditions under which the factorisation theorem can be applied effectively.
Coolster7
I'm having trouble with applying this theorem to likelihood functions in order to obtain a sufficiency statistic for the relevant variables.
_________________________________________________________________________________________
The factorisation theorem being:
Under certain regularity conditions;
T(X) is sufficient for θ ⇔ f(x|θ) = h(x)g(t(x),θ)
for some functions h and g.
__________________________________________________________________________________________
The main problem I'm having is when to allow h(x) = 1.
For example in the exponential distribution you get a likelihood function: f(x|θ) = θn(1-θ)\sum(xi) - n
you set h(x) =1 here and g(x) = (t,θ) = θn(1-θ)t - n where t = \sum(xi)
However, in the Poisson distribution you get a likelihood function: 1/(x1!x2!) x e-2θθx1+x2.
here you set h(x) = 1/(x1!x2!) and not h(x) = 1.
Is this because h(x) has to be a constant or involving just x?
So say for example you had a likelihood function:
f(x|θ) = xnσ-2ne-0.5nx2σ-2
using the Factorisation method would you let h(x) = 1 with g(x, σ) = f(x|θ)
and say x is sufficient for σ
OR would you let h(x) = xn and g(x, σ) = σ-2ne-0.5nx2σ-2
Note: Obviously there is the same outcome for the sufficiency statistic, but in a different problem this may not be the case.
Can anyone help me please?
The idea is to have h(x) not depending on the parameter. Whether it's a constant or not.
Likes 1 person
Ah I see, thanks for this I understand now.. it's simple really.
Actually just one more question. What about n? Would n need to be sufficient for the parameter or is it treated as constant/number?
Anyone?
The standard _A " operator" maps a Null Hypothesis Ho into a decision set { Do not reject:=1 and reject :=0}. In this sense ( HA)_A , makes no sense. Since H0, HA aren't exhaustive, can we find an alternative operator, _A' , so that ( H_A)_A' makes sense? Isn't Pearson Neyman related to this? Hope I'm making sense. Edit: I was motivated by a superficial similarity of the idea with double transposition of matrices M, with ## (M^{T})^{T}=M##, and just wanted to see if it made sense to talk...
  • · Replies 16 ·
  • · Replies 54 ·
