Falcon 9 predicted lunar impact
  • Topic: Stargazing
  • Thread starter DaveC426913
  • Featured
14 replies · 4K views · last reply
DaveC426913
2025 Award
TL;DR
Falcon 9 is expected to impact the Moon's limb at or around Wed Aug. 5 at 2:34:32.9 a.m. ET
https://www.cbc.ca/news/science/falcon9-rocket-moon-impact-9.7290981
Telescope view of the Moon in a half-lit phase, with the terminator running diagonally from top to bottom; cyan crosshair markers in the upper left and a green crosshair near the center.
"You need to be taking an image every tenth, hundredth of a second, something like that, to try and catch this brief flash," he said. "If you're trying to catch the plumes, that's probably quite a bit easier because we expect the plume to last [in] the order of one to 10 minutes, something like that."
Alas, I always leave it till too late to ensure my gear is in working order for a night sky event.
But seeing conditions look pretty favourable for me, so...
Clear Sky Chart for Hamilton forecast from 2026-08-03, showing rows for cloud cover, ECMWF cloud, transparency, seeing, darkness, smoke, wind, humidity and temperature, with a red ellipse circling a block of favourable conditions on Tuesday, 4 August.
As the saying goes:"the Moon is not there, if nobody is looking..."
:oldbiggrin:
Somebody on Facebook posted their image but said they couldn't see anything.
Greyscale telescope image of the Moon's limb with a Sun-facing crater region, text reading 'Attempt to capture impact of Falcon 9 second stage into Einstein crater' and an arrow labelled 'approximate impact location'.
The problem, it seems is that the plume is way, way too dim next to the well-exposed Moon.
So with a little Photoshop magic, boosting the exposure by scads and scads, there it is.
Grayscale telescope image of the lunar limb with a bright white rectangle patch and a red arrow pointing to a faint dark plume, boosted in exposure; title reads Attempt to capture impact of Falcon 9 second stage into Einstein crater.
Yes it did, but it was very hard to see.
We must wait a few days for the radar image of the crater it produced.
So did it impact or not? Kinda hard to tell from your images...
Yes. Open the second pic in a new window at full scale.
You really have a talent for finding those interesting tidbits! I'm glad I'm following you.
pinball1970 said:
So, I'm guessing the black circle in the center of the photo on the RHS is the impact crater.
But what's all that bright white stuff? Is it the ejected material from the impact? If so, why does it show-up as brighter white if it's just the same regolith as what it fell onto? Did the impact change it in some way (perhaps compact or fuse it)?
I assume the middle part where you have that back and white contrast is the crash site and possibly displaced dust and rock.
There seems to be highlights on other craters however, that could be a slightly different angle, lunar time so light reflects a little more. Not sure.
My guess is that subsurface regolith dust is lighter in colour than surface dust - that regolith exposed to the elements for millions of years darkens for some reason.
Also, keep in mind that we are not necessarily seeing a difference in colour value - it could be more an issue of reflectivity - perhaps the ejected material is finer-grained and therefore reflects light slightly better.
Especially if you factor in how much the image exposure might be changed. We have no idea what the actual difference in albedo might be. It could be tiny.
Maybe, the dust plume ejected above the surface was illuminated by direct sunlight, while the crater is a hole full of shadow.
The dust plume should have fallen back within minutes. Presumably we are seeing the ejecta blanket.
NASA has released images of impact.
https://science.nasa.gov/solar-syst...s-falcon-9-crater-on-moon-learns-new-details/
Grayscale lunar surface photo from Lunar Reconnaissance Orbiter showing scattered small craters and bright ejecta patches across gray regolith.
Caption: This is an animated before-and-after view of the crater formed after a Falcon 9 upper stage struck the Moon’s surface on Aug. 5, 2026. These images were taken between Aug. 11 and 12 by the Narrow-Angle Camera on NASA’s Lunar Reconnaissance Orbiter. These images are enlarged three times from the original, with north facing up, and they cover an area about a quarter of a mile wide.
"... scientists measured its 60‑foot width. Scientists also determined the crater is less than 10 feet deep based on the length of its shadow..."
According to the article:
"The images [...] show bright and dark rays stretching out from the crater. The darker streaks are made of surface dust and rocks altered over a long time by solar wind, galactic cosmic rays, and micrometeorite impacts. This weathered material was excavated by the collision from 1.5 feet into the lunar surface. The brighter streaks near the crater rim are made of fresh material excavated from deeper underground."
