Finally, discuss some physical limitations that might
  • Thread starter Thread starter Jamin2112
    Physical
8 replies · 2K views · last reply
Jamin2112
"Finally, discuss some physical limitations that might ..."
Part (d) of problem 1 here: http://faculty.washington.edu/joelzy/402_502_W13_hw4.pdf
I have (I(t) I'(t))T = cos(t/√(LC))k1 + sin(t/√(LC))k2, some k1, k2 ε ℂ2 for my solution and so I know that decreasing the value of LC increases the ticking frequency of this clock.
But I'm at a loss for what to put for this "discuss some physical limitations" thing. Thoughts?
For one thing - do you think this clock will run forever? Even if so, does the current level stay constant or does it get harder to detect over time? Do the values of R, C and L change in any way over time?
Theoretically, yes.
Well, it oscillates, since current is V = RI, R is constant, I is oscillating.
I don't really know since I'm not an electrical engineer
I do not see any dependence of the solution on R. How come?
If we want it to tick with a constant frequency, then we want the node to be a center, so we want R=0. Right? We want I(t)=0 periodically.
Jamin2112 said:
Theoretically, yes.
Does it seem reasonale to assume that whatever circuit you use to detect the zero crossings of the current has a limitation as to how low the current can be before it can't tell the difference between that low level and zero?
And BTW you can't have R = 0 in real life. Besides, the problem specifies a resistor.
And FYI R, C and L do change over time & environment. That's why crystal oscillators are used in your PC!
Do you think it is physically possible to have R = 0? The circuit is called LRC for a reason.
Isn't my intuition right, though, that we want the vector field of (I I')T to be something circling the origin forever?
