Find B such that AB=BA (Linear Alg)
  • Thread starter Thread starter QuarkCharmer
22 replies · 10K views · last reply
QuarkCharmer
This is from Lay, 2.1 #11 (the second part). Not a homework problem, just for fun.
Let A be the 3x3 matrix, A = [1,1,1; 1,2,3; 1,4,5]. Find a matrix B such that:
[tex]AB = BA[/tex]
where B is not the zero or identity matrix
Okay, so I know that typically, AB != BA, since matrix multiplication is non-commutative, but in some cases it can happen. What I did was make some 3x3 matrix B:
B = [a,b,c; d,e,f; g,h,i]
Then I wrote out AB = BA in matrix form, and solved both sides. Let's call AB matrix C, and BA matrix D. I set each entry in C to it's corresponding entry in D to form a system of 9 equations and 9 unknowns. I turned this into a 9x10 augmented matrix and attempted to rref it with my TI-89 but the resulting matrix is too big to display on the screen. I can scroll right and left, but I can't see anything below row 6.
Now, I am pretty confident that, if I did find a value for each entry in B (a,b,c,...,i) then it would form a matrix B such that AB = BA. But I don't think this is the right way to go about this problem at all. I can't believe they would expect me to solve 9 equations with 9 unknowns.
So my questions are:
1.) Would my approach have worked, say, if I computed it in mathematica.
and
2.) What is the proper approach to tackle this problem? I know there must be some way to go about this that is reasonable.Thanks!
-QC
Why not just compute it be hand? You don't need software for a 3x3.
It's a 9x10 (augmented),
I assumed B was 3x3. A and B both have 9 entries, so that's 9 equations. Unless there is some other way to go about it that I am not seeing.
If this:
2. Matrix Algebra
Introductory Example: Computer Models in Aircraft Design
2.1 Matrix Operations
2.2 The Inverse of a Matrix
2.3 Characterizations of Invertible Matrices
2.4 Partitioned Matrices
2.5 Matrix Factorizations
is the second chapter of your book then read section 2.2 & come back to the question
That's the book (well the chapters). I guess I'll make note of it and skip it. Seems like they would ask questions possible with only the knowledge provided in chapters 1-2.1.
Would my method have worked, if I cared to work out the 9x9 matrix?
Note that if you were to write this matrix equation, it would be three equations, not nine. Therefore the system is under-determined, and there may be many possible solutions. I'm not sure how you got nine equations out of it; they can't be unique.
your method would work, and it would find all possible matrices for B, though I certainly wouldn't want to go through all that work
You could just forget about the values of A, and think about what matrices would make AB=BA, you have the zero matrix and the identity, but what other simple matrices can you come up with?
You could also just start off with a 2x2 matrix and see if it gives you some insight.
I can't think of any way to form this as a 3x3 matrix.
Here is how I get 9x9.
The equations on the right are the simplified equations from the left. Then the standard matrix formed by the 9 equations is at the bottom. In this case vector x has components a,b,c,...
CornMuffin, how would you know to start off with a 2x2?
Well, the identity and zero matrix are the only solutions I can think of for any A, such that AB=BA. Unless they just want some scalar multiple of the identity matrix, which I think would work (trying that now to be sure). Something like [5,0; 0,5], but that's still the identity matrix basically.
Sure, but it's not the identity matrix, so it is one possible solution :)
If that's the answer they were looking for that is pretty lame. There still "could" be some matrix B which satisfies this argument. I'll go with some cheap multiple of the identity matrix for now and revisit after I read the rest of chapter 2.
Thanks for the help
Sometimes it is easier to start off with a simpler matrix... by using any simple 2x2 matrix first, it might help you find a matrix B with a larger matrix
edit: there are other matrices that would work that is not a multiple of the identity
Once you get all your equations set equal to each other, you have
\begin{pmatrix}
0&-1&-1&1&0&0&1&0&0&:0\\
1&1&4&0&-1&0&0&-1&0&:0\\
-1&-3&-2&0&0&1&0&0&1&:0\\
1&0&0&1&-1&-1&3&0&0&:0\\
0&1&0&-1&0&-4&0&3&0&:0\\
0&0&0&-1&-3&-3&0&0&3&:0\\
1&0&0&4&0&0&4&-1&-1&:0\\
0&1&0&0&4&0&-1&3&-4&:0\\
0&0&1&0&0&4&-1&-3&0&:0
\end{pmatrix}
Thanks for the help
I think that solving nine simultaneous equations is pretty "lame." Finding simple answers to problems that seem complicated is what is cool.
But I don't know what the authors were looking for. That depends on whether they're the type of author that has a sense of humor or not.
you can use a scalar multiple of the matrix A, or of the inverse of A, or you can even use something like B=A^3+5A+2A^-1 :D
I haven't done the math, but perhaps it might be easier to find A-1 so you get B = A-1BA.
There's an extremely easy choice of B, an extremely easy choice...
If you make B the inverse of A, that would work; however I don't think that's what the author wants for an answer since inverses are covered in the next section...
You all are making this much too complicated. Why not just let B=A (I'm guessing this is what you were getting at, sponsoredwalk).
Maybe A is a bit simpler than A⁵³⁵ :redface:
Okay... let's try something.
B is not supposed to be the zero matrix or the identity.
So let's pick the "best" next thing...
Pick a matrix with all entries set to zero, except the top left one...
Yep, that does the trick! :wink:
I guess you will need to set more conditions...
Edit: Oh, and yes, B=A or B=A-1 will also do the trick. :)
I don't have mathematica either, but I just tried to see what wolframalpha.com makes of it:
http://m.wolframalpha.com/input/?i=solve+{{1%2C1%2C1}%2C{+1%2C2%2C3}%2C{+1%2C4%2C5}}*{{a%2Cb%2Cc}%2C{d%2Ce%2Cf}%2C{g%2Ch%2Ci}}+%3D+{{a%2Cb%2Cc}%2C{d%2Ce%2Cf}%2C{g%2Ch%2Ci}}*{{1%2C1%2C1}%2C{+1%2C2%2C3}%2C{+1%2C4%2C5}}&x=0&y=0
Wolframalpha gives a generic solution based on a, b, and c.
If we pick (1,0,0) we get the identity matrix.
If we pick (1,1,1) we get matrix A back.
If we pick (0,1,1) we get [0,1,1; 1,1,3; 1,4,4].
Take your pick!
This doesn't work. Multiplying by [itex]B[/itex] on the right leaves ones on the first column, whereas multiplying by [itex]B[/itex] on the left leaves ones on the first row.
Oops!
