Find B such that AB=BA (Linear Alg)
  • Thread starter Thread starter QuarkCharmer
The discussion revolves around finding a matrix B such that the product of matrices A and B commutes, i.e., AB = BA, where A is a specific 3x3 matrix. The original poster notes that this is not a formal homework problem but rather an exploration of matrix properties.
  • Participants discuss various methods to find matrix B, including setting up a system of equations based on the matrix multiplication. Some question the feasibility of solving nine equations with nine unknowns, while others suggest simpler approaches or alternative matrices.
The conversation is ongoing, with participants exploring different interpretations and methods. Some have proposed using simpler matrices or scalar multiples of the identity matrix as potential solutions, while others express skepticism about the complexity of the problem.
There is a mention of constraints regarding the type of matrix B, specifically that it should not be the zero or identity matrix. Participants also reference sections of a textbook that may provide relevant background knowledge.
QuarkCharmer
This is from Lay, 2.1 #11 (the second part). Not a homework problem, just for fun.
Let A be the 3x3 matrix, A = [1,1,1; 1,2,3; 1,4,5]. Find a matrix B such that:
[tex]AB = BA[/tex]
where B is not the zero or identity matrix
Okay, so I know that typically, AB != BA, since matrix multiplication is non-commutative, but in some cases it can happen. What I did was make some 3x3 matrix B:
B = [a,b,c; d,e,f; g,h,i]
Then I wrote out AB = BA in matrix form, and solved both sides. Let's call AB matrix C, and BA matrix D. I set each entry in C to it's corresponding entry in D to form a system of 9 equations and 9 unknowns. I turned this into a 9x10 augmented matrix and attempted to rref it with my TI-89 but the resulting matrix is too big to display on the screen. I can scroll right and left, but I can't see anything below row 6.
Now, I am pretty confident that, if I did find a value for each entry in B (a,b,c,...,i) then it would form a matrix B such that AB = BA. But I don't think this is the right way to go about this problem at all. I can't believe they would expect me to solve 9 equations with 9 unknowns.
So my questions are:
1.) Would my approach have worked, say, if I computed it in mathematica.
and
2.) What is the proper approach to tackle this problem? I know there must be some way to go about this that is reasonable.Thanks!
-QC
Why not just compute it be hand? You don't need software for a 3x3.
It's a 9x10 (augmented),
I assumed B was 3x3. A and B both have 9 entries, so that's 9 equations. Unless there is some other way to go about it that I am not seeing.
If this:
2. Matrix Algebra
Introductory Example: Computer Models in Aircraft Design
2.1 Matrix Operations
2.2 The Inverse of a Matrix
2.3 Characterizations of Invertible Matrices
2.4 Partitioned Matrices
2.5 Matrix Factorizations
is the second chapter of your book then read section 2.2 & come back to the question
That's the book (well the chapters). I guess I'll make note of it and skip it. Seems like they would ask questions possible with only the knowledge provided in chapters 1-2.1.
Would my method have worked, if I cared to work out the 9x9 matrix?
Note that if you were to write this matrix equation, it would be three equations, not nine. Therefore the system is under-determined, and there may be many possible solutions. I'm not sure how you got nine equations out of it; they can't be unique.
your method would work, and it would find all possible matrices for B, though I certainly wouldn't want to go through all that work
You could just forget about the values of A, and think about what matrices would make AB=BA, you have the zero matrix and the identity, but what other simple matrices can you come up with?
You could also just start off with a 2x2 matrix and see if it gives you some insight.
I can't think of any way to form this as a 3x3 matrix.
Here is how I get 9x9.
The equations on the right are the simplified equations from the left. Then the standard matrix formed by the 9 equations is at the bottom. In this case vector x has components a,b,c,...
CornMuffin, how would you know to start off with a 2x2?
Well, the identity and zero matrix are the only solutions I can think of for any A, such that AB=BA. Unless they just want some scalar multiple of the identity matrix, which I think would work (trying that now to be sure). Something like [5,0; 0,5], but that's still the identity matrix basically.
Sure, but it's not the identity matrix, so it is one possible solution :)
If that's the answer they were looking for that is pretty lame. There still "could" be some matrix B which satisfies this argument. I'll go with some cheap multiple of the identity matrix for now and revisit after I read the rest of chapter 2.
Thanks for the help
Sometimes it is easier to start off with a simpler matrix... by using any simple 2x2 matrix first, it might help you find a matrix B with a larger matrix
edit: there are other matrices that would work that is not a multiple of the identity
Once you get all your equations set equal to each other, you have
\begin{pmatrix}
0&-1&-1&1&0&0&1&0&0&:0\\
1&1&4&0&-1&0&0&-1&0&:0\\
-1&-3&-2&0&0&1&0&0&1&:0\\
1&0&0&1&-1&-1&3&0&0&:0\\
0&1&0&-1&0&-4&0&3&0&:0\\
0&0&0&-1&-3&-3&0&0&3&:0\\
1&0&0&4&0&0&4&-1&-1&:0\\
0&1&0&0&4&0&-1&3&-4&:0\\
0&0&1&0&0&4&-1&-3&0&:0
\end{pmatrix}
Thanks for the help
I think that solving nine simultaneous equations is pretty "lame." Finding simple answers to problems that seem complicated is what is cool.
But I don't know what the authors were looking for. That depends on whether they're the type of author that has a sense of humor or not.
you can use a scalar multiple of the matrix A, or of the inverse of A, or you can even use something like B=A^3+5A+2A^-1 :D
I haven't done the math, but perhaps it might be easier to find A-1 so you get B = A-1BA.
There's an extremely easy choice of B, an extremely easy choice...
If you make B the inverse of A, that would work; however I don't think that's what the author wants for an answer since inverses are covered in the next section...
You all are making this much too complicated. Why not just let B=A (I'm guessing this is what you were getting at, sponsoredwalk).
Maybe A is a bit simpler than A⁵³⁵ :redface:
Okay... let's try something.
B is not supposed to be the zero matrix or the identity.
So let's pick the "best" next thing...
Pick a matrix with all entries set to zero, except the top left one...
Yep, that does the trick! :wink:
I guess you will need to set more conditions...
Edit: Oh, and yes, B=A or B=A-1 will also do the trick. :)
I don't have mathematica either, but I just tried to see what wolframalpha.com makes of it:
http://m.wolframalpha.com/input/?i=solve+{{1%2C1%2C1}%2C{+1%2C2%2C3}%2C{+1%2C4%2C5}}*{{a%2Cb%2Cc}%2C{d%2Ce%2Cf}%2C{g%2Ch%2Ci}}+%3D+{{a%2Cb%2Cc}%2C{d%2Ce%2Cf}%2C{g%2Ch%2Ci}}*{{1%2C1%2C1}%2C{+1%2C2%2C3}%2C{+1%2C4%2C5}}&x=0&y=0
Wolframalpha gives a generic solution based on a, b, and c.
If we pick (1,0,0) we get the identity matrix.
If we pick (1,1,1) we get matrix A back.
If we pick (0,1,1) we get [0,1,1; 1,1,3; 1,4,4].
Take your pick!
This doesn't work. Multiplying by [itex]B[/itex] on the right leaves ones on the first column, whereas multiplying by [itex]B[/itex] on the left leaves ones on the first row.
Oops!
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 26 ·
