Find constant speed using mass and power
To find the constant speed of a forklift lifting a 613.0 kg mass with a power output of 950 W, the relationship between power, work, and force is utilized. The equations P = W/Δt and W = Fapp*Δd are key to solving the problem. By recognizing that the gravitational force (Fg = mg) acts on the mass, the power can be expressed as P = (mg * Δd) / Δt. Rearranging this leads to the conclusion that speed (v) can be isolated and calculated. The problem is ultimately solved by applying these principles correctly.
DeerHunter
Find constant speed using mass and power [SOLVED]
A 613.0 kg mass is placed on a forklift that can generate 950 W of power. What is the constant speed of the forklift while lifting this load?
P = W/▲t
W=Fapp*▲d
Fg=mg
I am not sure where to go from here, I can't rearrange P = W/▲t to solve for t without having work. I can't find W=Fapp*▲d without d or by rearranging P. I can't find d with the variables given or by rearranging W. Any help is appreciated!
P=(Fapp*▲d)/▲t
P=((mg)*▲d/▲t)
note v=▲d/▲t
insert values and isolate for v
VanOosten said:
P=(Fapp*▲d)/▲t
P=((mg)*▲d/▲t)
note v=▲d/▲t
Thanks! Can't believe I overlooked that. Question is solved
  • · Replies 21 ·
  • · Replies 26 ·
