What Is the Limit of Sequence f(n) as n Approaches Infinity?
  • Thread starter Thread starter chaoseverlasting
The limit of the sequence defined by the recurrence relation f(n+1) = 0.5(f(n) + 9/f(n)) as n approaches infinity can yield two possible values: L = 3 and L = -3. This conclusion arises from solving the equation L = 0.5(L + 9/L), which leads to both solutions depending on the initial condition f(0). If f(0) is positive, the sequence converges to 3; if f(0) is negative, it converges to -3.
  • Understanding of recurrence relations
  • Familiarity with limits in calculus
  • Basic algebra for solving equations
  • Knowledge of sequences and their convergence
  • Study the properties of recurrence relations in mathematical analysis
  • Learn about convergence criteria for sequences
  • Explore the application of limits in calculus, specifically L'Hôpital's rule
  • Investigate initial conditions and their impact on sequence behavior
Students studying calculus, mathematicians interested in sequences and limits, and educators teaching recurrence relations and convergence concepts.
chaoseverlasting
Given:
f(n+1)=\frac{1}{2}(f(n)+\frac{9}{f(n)}
Find lt n->(infinity) f(n)
No idea.
f(n+1)-f(n)=0.5(\frac{9}{f(n)} -f(n))
Replacing n by 1/n, dividing by 1/n and taking limit 1/n->0 which becomes something similar to the f'(n) except 1 should be h. Even still, you can't apply L'hospitals here. I am totally lost.
In your equation f(n+1) = 0.5(f(n) - 9/f(n)), the left side equals the right side, therefore the limit as n goes to infinity of the right side is the limit as n goes to infinity of the right side. Using the above fact, let L stand for the limit of f(n) as n goes to infinity, and solve for L.
Your orginal equation was
f(n+1)= \frac{1}{2}a(f(n)+ 9/f(n)
I think your subtracting f(n) from both sides confused AKG (not to mention me)!
The sequence {f(n+1)} is exactly the same as {f(n)} but with the index changed. If L= lim f(n) then L= lim f(n+1) also. AKG's suggestion is that you take the limit, as n goes to infinity, on both sides of the equation and so get a single equation involving L. Solve that equation.
So, the equation should be something like L=0.5(L+9/L)?
Solving this gives you L=+3 and L=-3. What should my answer be?
Well if you've posted the question exactly as it's given to you, then both 3 and -3 are possible. Observe that if f is a sequence that satisfies the given relation, then so is -f, so if the limit of f is 3, then the limit of -f is -3.
In other words, whether the limit is 3 or -3 depends upon f(0).
If, for example, you know that f(0)= 1, then f(1)= (1/2)(1+ 9/1)= 5, f(2)= (1/2)(5+ 9/5)= 6.8/2= 3.4, f(3)= (1/2)(3.4+ 9/3.4)= 3.0234.., converging to 3.
If, instead, f(0)= -1, then f(1)= (1/2)(-1+9/-1)= -5, etc. converging to -3.
  • · Replies 20 ·
  • · Replies 16 ·
