Find n where sum of triangular numbers equals 364
  • Topic:
  • Thread starter Thread starter Monoxdifly
    Induction Value
5 replies · 2K views
Monoxdifly
MHB
Determine the value of n if 1 + 3 + 6 + ... + $$\frac{1}{2}$$n(n - 1) = 364
What I did:
I know that 1, 3, and 6 are the result of arithmetic series with the starting value 1 and the difference 2, thus that sum can be written as S1 + S2 + S3 + ... + Sn = 364. However, by assuming that Sn = $$\frac{1}{2}$$n(n - 1) I got n + 1 = n - 1 which is simply unsolvable at all. After all, the term $$\frac{1}{2}$$n(n - 1) doesn't match for n = 1. Does this question even have any solution?
Mathematics news on Phys.org
I would write:
$$\frac{1}{2}\sum_{k=1}^n\left(k(k-1)\right)=364$$
$$\sum_{k=1}^n\left(k^2-k\right)=728$$
What are the formulas for:
$$\sum_{k=1}^n\left(k\right)$$
$$\sum_{k=1}^n\left(k^2\right)$$
$$\frac{1}{2}n(n-1)?$$
I don't know...
Not quite, it is:
$$ \sum_{k=1}^n\left(k\right)=\frac{n(n+1)}{2}$$
Monoxdifly said:
I don't know...
Now for:
The sum of squared terms is going to be a cubic function, so let's write:
$$\sum_{k=1}^n\left(k^2\right)=an^3+bn^2+cn+d$$
Now, consider, that we have:
$$\sum_{k=1}^n\left(k^2\right)=\sum_{k=0}^n\left(k^2\right)$$
$$\sum_{k=0}^1\left(k^2\right)=0^2=0$$
$$\sum_{k=1}^1\left(k^2\right)=0+1^2=1$$
$$\sum_{k=1}^2\left(k^2\right)=1+2^2=5$$
$$\sum_{k=1}^3\left(k^2\right)=5+3^2=14$$
So, this gives rise to the system:
$$d=0$$
$$a+b+c=1$$
$$8a+4b+2c=5$$
$$27a+9b+3c=14$$
I would use Gaussian elimination to solve this system:
$$\left[\begin{array}{ccc|c}1 & 1 & 1 & 1 \\ 8 & 4 & 2 & 5 \\ 27 & 9 & 3 & 14 \end{array}\right]$$
$$\left[\begin{array}{ccc|c}1 & 1 & 1 & 1 \\ 0 & -4 & -6 & -3 \\ 0 & -18 & -24 & -13 \end{array}\right]$$
$$\left[\begin{array}{ccc|c}1 & 1 & 1 & 1 \\ 0 & 1 & \frac{3}{2} & \frac{3}{4} \\ 0 & -18 & -24 & -13 \end{array}\right]$$
$$\left[\begin{array}{ccc|c}1 & 0 & -\frac{1}{2} & \frac{1}{4} \\ 0 & 1 & \frac{3}{2} & \frac{3}{4} \\ 0 & 0 & 3 & \frac{1}{2} \end{array}\right]$$
$$\left[\begin{array}{ccc|c}1 & 0 & -\frac{1}{2} & \frac{1}{4} \\ 0 & 1 & \frac{3}{2} & \frac{3}{4} \\ 0 & 0 & 1 & \frac{1}{6} \end{array}\right]$$
$$\left[\begin{array}{ccc|c}1 & 0 & 0 & \frac{1}{3} \\ 0 & 1 & 0 & \frac{1}{2} \\ 0 & 0 & 1 & \frac{1}{6} \end{array}\right]$$
This tells us:
$$(a,b,c,d)=\left(\frac{1}{3},\frac{1}{2},\frac{1}{6},0\right)$$
Hence:
$$\sum_{k=1}^n\left(k^2\right)=\frac{1}{3}n^3+\frac{1}{2}n^2+\frac{1}{6}n=\frac{2n^3+3n^2+n}{6}=\frac{n\left(2n^2+3n+1\right)}{6}=\frac{n(n+1)(2n+1)}{6}$$
Now, can you proceed with these formulas?
What I did:
I think you maybe confusing two things here. If you say the sum can be written as $S_{1}+S_{2}+\cdots+S_{n} = 364$, then $S_n$ is the $n^{th}$ term of the sequence which, as you say, is $\frac{1}{2} n(n-1)$. This is different from the sum. The question is asking you to find $n$ if the sum $S_{1}+S_{2}+\cdots+S_{n}$ evaluates to $364$. Maybe the choice of naming the terms $S_1, S_2, \ldots, S_n$ is a cause for confusion as you might be used to denoting the value of the sum as $S_n$, in which case perhaps naming them $T_1, T_2, \ldots, T_n$ might be better.
To follow up, we have:
Using our summation formulas, we get:
$$\frac{2n^3+3n^2+n}{6}-\frac{n^2+n}{2}=728$$
Multiply through by 6:
$$2n^3+3n^2+n-3n^2-3n=4368$$
Arrange in standard form:
$$2n^3-2n-4368=0$$
Divide through by 2:
$$n^3-n-2184=0$$
Let:
$$f(n)=n^3-n-2184$$
Trying the factors of 2184 in according with the rational roots theorem, we find:
$$f(13)=0$$
Then, using synthetic division, we obtain:
$$\begin{array}{c|rr}& 1 & 0 & -1 & -2184 \\ 13 & & 13 & 169 & 2184 \\ \hline & 1 & 13 & 168 & 0 \end{array}$$
This tells us:
$$f(n)=(n-13)\left(n^2+13n+168\right)$$
We see that the discriminant of the quadratic factor is negative, leaving only:
$$n=13$$
