Find remainder when x^100 is divided by x^2 - 3x + 2
  • Thread starter Thread starter sambarbarian
    Thinking
40 replies · 7K views
LCKurtz said:
begin {offtopic}
Sambarbarian, I am curious to know if you grew up in or near northeastern South Dakota. If your answer is yes, I will tell you why I thought that. Otherwise nevermind.
end{offtopic}
sambarbarian said:
nopes , I am an indian ... but please tell me y u thought that
Because I did grow up in South Dakota, and I have met people from the eastern part of the state that use the word "dint" when they mean "didn't", which is a contraction for "did not". The word "dint" means something else.
eumyang said:
You'll notice that 2999 is not a factor of 10998. In fact, any factor of 10999 that is divisible by 2999 cannot be a factor of 10998. So how many of these factors of 10999 would that make altogether? (And no, the answer to this question is not the final answer of the problem.)
Curious3141 said:
No, I believe Eumyang was thinking about numbers like [itex]2^{999} \cdot 5[/itex], [itex]2^{999} \cdot 5^4[/itex] and [itex]2^{999} \cdot 5^{999}[/itex] (just examples). Have you considered those?
There are many more such numbers to consider.
Right. 2999 (or 2999 x 50) is not a factor of 10998.
2999 x 5 (or 2999 x 51) is not a factor of 10998.
2999 x 52 is not a factor of 10998.
These are some of the factors of 10999, divisible by 2999, but are not factors of 10998. So how many factors would this make altogether?
Well, hello, I'm (ethnically) Indian too, although I'm a Singaporean by birth and citizenship.
And as LCKurtz points out, "dint" has its own meaning. It means by virtue of (something) when used in a phrase like "by dint of his dogged hard work". It's usually used emphatically, to suggest force, power or perseverance. It can also be an alternative spelling for "dent".
Back to the math now! :biggrin:
eumyang said:
right. 2999 (or 2999 x 50) is not a factor of 10998.
999 + 999 = 1998 ?
sambarbarian said:
999 + 999 = 1998 ?
I have one more than that. How did you arrive at your figure (exactly)?
Now you are just guessing. The critical point is that [itex]10^{998}= (5^{998})(2^{998})[/itex]. That means that [itex]5^n[/itex] is a factor for every n from 0 to 998. But it also means that [itex]2^n[/itex], for n= 0 to 99 is also a factor. That's 2(999) right there, and and we haven't even started combining "2"s and "5"s.
One way to look at it is this: there are 999 ways to find factors using only "5"s and there are 999 ways using only "2"s. And the "fundamental theorem of counting" says that the if there are m ways of doing one thing and n ways of doing another (independently of the first) then there are mn ways of doing both.
Yes, but everything from [itex]5^0[/itex] to [itex]5^{998}[/itex] are also factors of [itex]10^{998}[/itex] and are therefore excluded from consideration. Ditto for powers of 2. Every number that should be considered should have as a factor, either [itex]2^{999}[/itex] or [itex]5^{999}[/itex] or both (the only one that has both is [itex]10^{999}[/itex]).
sambarbarian said:
i don't quite understand
OK, start by considering the numbers with [itex]2^{999}[/itex] as a factor. Now, everything from [itex]2^{999}.5^0[/itex] to [itex]2^{999}.5^{998}[/itex] divides [itex]10^{999}[/itex] but not [itex]10^{998}[/itex]. Agreed? So how many is that?
Now consider numbers with [itex]5^{999}[/itex] as a factor in a similar way. How many do we have here?
Finally, don't forget [itex]2^{999}.5^{999} = 10^{999}[/itex] itself, which I avoided including till the last step so that we don't double-count it.
2^999 . 5^0 is equal to 2^999 . 5^1 ,,, (998 - 1) = 997 ? i am not sure
You're not thinking clearly, and what you wrote makes no sense.
[itex]2^{999}.5^0 = 2^{999}[/itex] because any nonzero number raised to the power zero is 1.
[itex]2^{999}[/itex] is still a number you have to include in the count because it divides [itex]10^{999}[/itex] but not [itex]10^{998}[/itex].
I asked you to count the numbers from [itex]2^{999}.5^0[/itex] to [itex]2^{999}.5^{998}[/itex] going in consecutive exponents of 5. This is equivalent to counting the integers from 0 to 998 inclusive. You replied with '997'. Sure of this?
How many integers are there from 0 to 1 inclusive? 0 to 10? 0 to 998?
