Find the effective force constant ke
4 replies · 8K views · last reply
Pupil
This isn't really a homework problem, but I've been going over these Yale problem sets for physics 200 (http://oyc.yale.edu/physics/fundamentals-of-physics/content/resources/problem_set_3.pdf" ), and I'm having trouble with one of the questions.
Two springs have the same unstretched length but different spring constants k1 and
k2 . Find the effective force constant ke if they are connected in series and in parallel.
(To ¯nd ke, imagine stretching the combination by an amount x and keeping track
of the force needed.)
f = ma
fs = -kx
Pupil = awesome
So I figured the parallel spring constant out fairly easily, but I'm having trouble with the series one. The way I imagined it is we tie spring with constant [tex]k_1[/tex] to the wall, and tie spring with constant [tex]k_2[/tex] to spring with constant [tex]k_1[/tex], and finally pull [tex]k_1[/tex] by some amount A. Spring with [tex]k_1[/tex] will stretch by some amount A1 and spring with [tex]k_2[/tex] will stretch by some amount [tex]A_2[/tex]. Summing up, we have [tex]k_2A_2 + k_1A_1 = F[/tex]. The problem is I don't know what [tex]A_1[/tex] and [tex]A_2[/tex] are. I know the springs won't stretch the same amount, so I'm stuck with this ugly expression. Help me get unstuck (don't tempt me to look at the answers)! Thanks!
EDIT: The title was supposed to be Spring Constant in Series...Don't know what happened.
Actually
[tex] k_2A_2 + k_1A_1 = F[/tex]
isn't right. Think about the point where the two springs connect. The first spring applies k1A1 to the second, and the second applies k2A2 to the first, so F=k1A1=k2A2. The problem should be easy from there.
Pupil said:
https://www.physicsforums.com/latex_images/22/2291913-7.png
[/URL]
That's not quite right. Springs in series experience the same force, so
k1A1 = k2A2 = F​
However, the displacements add up, so we can also say
Anet = A1 + A2​
EDIT: Hey ideasrule, great minds think alike :biggrin:
x1 is the extension produced by the force F in spring 1, similar for x2
The force on the first spring=force on the second spring
so we have
[tex]F=k_1x_1=k_2x_2[/tex]
Now the effective spring constant relates to F by this
F=kex (where x=x1+x2)
i.e. we have [itex]F=k_e(x_1+x_2)[/itex]
looks a bit unsettling right? BUT we know that [itex]F=k_1x_1=k_2x_2[/itex]
you can put either 'kx' equal (replace F) to the formula above, and replace the 'other' x using the relation in the last formula. You will understand what I mean when you do it.
For parallel:
Each spring will stretch by the same amount, so finding ke is easier here.
EDIT: seems ideasrule and Redbelly98 can type faster than me
Holy crap! The force of the second on the first is equal to the force of the first on the second. I forgot Newton's third law! *Face palm* Thanks guys. You rock!
