Find the Equation of a Line with Undefined Slope Passing Through (-1,4)
  • Thread starter Thread starter recoil33
    Line Slope
The equation of a line with an undefined slope passing through the point (-1, 4) is x = -1, representing a vertical line. A vertical line does not qualify as a function because it assigns multiple y-values to a single x-value. The initial confusion arose from mistakenly considering y = -1 instead of the correct vertical line equation. Understanding that vertical lines pass through all y-values at a specific x-value clarifies the concept. This discussion emphasizes the distinction between vertical lines and functions in coordinate geometry.
recoil33
Question:
Determine the equation the line passing through (-1,4) with undefined(infinite) slope.
I put "y=-1"
This was because if it was constant there would be a undefined slope?
Altough, it was obviously wrong.
Help please?
[Wrong section if possible get moved to homework]
Mathematics news on Phys.org
If you draw this line on a coordinate system you will get a vertical line passing through all y values when x=-1.
So x=-1 regardless of the y value, therefore the equation is x=-1
Let's generalize:
The equation of a vertical line passing through (a,b) will be x=a
You should also note that a vertical line does not represent a function because a function must match no more than one y value for any given x value. A vertical line matches infinite y values for one x value so it is not a function.
I noticed i did a simple mistake of accidently thinking of y=-1, and x=-1, for some reason was thinking on the wrong axis.
Thanks for the help
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
