Find the Highest Pressure Point in this Conjoined Container
In the discussion about a conjoined container filled with water, participants analyze which point—C or D—has the highest pressure. The consensus is that point D exhibits the highest pressure due to its greater height, following the principle that pressure in a liquid is determined by depth (P = ρgh). While initial confusion arose regarding the forces acting on the points, it was clarified that pressure is uniform across the liquid and depends solely on depth. The shape of the container does not affect pressure as long as it is open to the atmosphere. Ultimately, point D is confirmed as the correct answer for the highest pressure point.
brainst0rm
In this conjoined container, water is filled up to the top at all three openings. Which letter point shows the highest point of pressure in this conjoined container?
``/~~~~\````````|~~~|```````\~C~~/
`/~~`A~~\_______|~B~|________\~~/
/_____________C__________________/
Key: ~ represents water
` ignore, represents space (used to post on forum)
Pascal’s law, Pressure = Force/Area
I think point C has the highest pressure point because two forces act on it from left to right and right to left. However, the pressure equilibrium comes to play and I am unsure which point displays the highest point of pressure. My second guess would be point C due to the higher force pushing downwards. What is the right answer? Thanks.
welcome to pf!
hi brainst0rm! welcome to pf! :smile:
i'm confused :redface:
why are there two Cs in the diagram? :confused:
Oops. I revised the data points with one point C and one point D.
1. Homework Statement
`/~~`A~~\_______|~B~|________\~~'/
/_____________D__________________/
2. Homework Equations
3. The Attempt at a Solution
I think point D has the highest pressure point because two forces act on it from left to right and right to left. However, the pressure equilibrium comes to play and I am unsure which point displays the highest point of pressure. My second guess would be point C due to the higher force pushing downwards. What is the right answer? Thanks.
right, but for the wrong reason
(i don't even understand the reason…
pressure acts left right and all around everywhere :confused:)
the pressure in a liquid is ρgh (+ atmospheric pressure) …
are you not familiar with that formula?​
Oh yes, P = pgh. How about this?
P = pgh, or Pressure = (Density) x (gravity due to acceleration) x (height). Because all points share the same density and gravity due to acceleration, the highest pressure point would be the point with the largest height, which is Point D.
hi brainst0rm! :smile:
yes, that's right …
the shape of the container doesn't matter …
so long as it's open to the atmosphere, the pressure only depends on the depth :wink:
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
