Find the Pattern in 3+6+12+20+30 +n
  • Thread starter Thread starter ChiralWaltz
The discussion revolves around identifying a pattern in the sequence 3, 6, 12, 20, 30, and determining a method to sum it up to the nth term. Participants are exploring the nature of the sequence and its terms.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants are attempting to factor the terms and identify relationships between them. Some are questioning the validity of the first term and suggesting alternative interpretations of the sequence. Others propose mathematical expressions that might represent the sequence.
The discussion is ongoing, with various interpretations being explored. Some participants have offered links to resources and alternative formulations, while others express confusion about the sequence's starting term and its implications.
There is uncertainty regarding the first term of the sequence, with suggestions that it might be 2 instead of 3. Participants are also grappling with how to approach the summation of the sequence given the discrepancies in the terms.
ChiralWaltz
Write a loop in C for to sum the following sequence 3+6+12+20+30+...nth.
n/a
I have tried to factor but there are no common factors between 3 and 20 other than 1.
2*5=10------->10+20=30
2*4=8--------->8+12=20
2*3=6--------->6+6=12
2*2=4--------->4+3=7:(
I'm stuck. Any ideas?
Recheck the first term. Hopefully it's 2.
Otherwise OEIS is kind-of your friend - you'll maybe get an answer, but it probably won't be an answer you'll like. https://oeis.org/A066140 is not a sequence you can easily generate.
The other (programming) option is to bounce the problem of the nth term into a function - which you leave unspecified.
Thanks for the link. I have no idea what the reply was telling me.
I'm pretty sure the 3 should be a 2 also.
What if someone utters "hey this looks like ##\displaystyle 1+\sum_1^N n(n+1)\ ## "?
If someone were to utter that, I would enthusiastically test values.
N=4
1+1(1+1) = 3
1+2(2+1) = 7 o_O
1+3(3+1) = 13 :(
1+4(4+1) = 21 :L
Then I would be disappointed and confused as to if I was doing the problem right.
Don't understand. I see 3+6+12+20+30+...nth.
I notice 3 = 1+ 1*2, 6 = 2*3, 12 = 3*4, 20 = 4*5, 30 = 5*6
So methinks $$ 3+6+12+20+30 =
\displaystyle 1+\sum_1^N n(n+1)\ $$
(not ##\sum_1^N 1 + n(n+1)\ ## as in post #5)
This is exactly the same as saying the first term of the series should be 2. - except it isn't, so let's just add a constant to that one term. You are also trying to jump to the sum instead of trying to identify the sequence.
I thought of a kludge to get us around the "faulty" start to the sequence:
##s_n = \max(n+(n+1), n*(n+1))##
Well, sorry for the confusion. I see your problem. My pattern recognition capabilities aren't up to having 3 as a starting term, so I made it (too?) easy for mself.
  • · Replies 53 ·
10K
  • · Replies 21 ·
