Finding coincident angle between 2 equally spaced sets
  • Thread starter Thread starter Telosian 7
To find the coincident angle between two gears with 12 and 14 teeth, calculate the angular separation using the formula N(2π/X - 2π/Y), where X is the number of teeth on the first gear and Y on the second. The goal is to determine the smallest angle difference between teeth on both gears when they are aligned. This involves comparing each tooth on the first gear with all teeth on the second gear, leading to 168 comparisons. The key challenge is to simplify this process to avoid extensive coding, focusing on the angular pitch ratios. The solution requires finding the lower value for N that corresponds to the desired alignment of teeth.
Telosian 7
Hi Math people. Budding math wiz here (Aerospace Engineer / Coordinate measuring machine programmer) , need help with a formula.
I have 2 external gears on one shaft, the top gear has 12 equally spaced teeth and bottom has 14 equally spaced teeth. At some location there will be 2 gears visually/nominally in-line or at the same rotation angle around 360°. Assuming a part is loaded and a top tooth or angle value is randomly measured, (this value will be positive from 0-360°). Assume we then measure an arbitrary adjacent tooth on the gear set below the top one. I have these values, and can store these as variables. My program I am using for this purpose is fairly basic, has some algebra and trig, but barely an if/then statement. I need to map or calculate all other tooth positions (angle position) for each gear set, and ideally 'wrap' them to 360 (e.g. 395 = 35). From there I need to find the smallest angle difference between any one tooth on top and adjacent tooth on bottom. Keeping in mind a value of 7 on one gear and a value of 355 on the other is a circular distance or delta of only 12, and not 348.
The trouble is in my experiment (assuming 12T has a start value of 60 (2 pitches), and 14T has a start value of 51.428 (also approx 2 pitches), how could I calculate and find out that 12T gear # 11 and 14T #13 are the teeth 'in-line' or rotationally coincident around 360°? my functions available are : + - / *, MIN ,MAX ABS, < or > , ATAN, ASIN, COS, SIN, and I dont have if/then, else, for, while, loops or patterns, best I have is 'jump to step', I can only jump ahead but I have discovered a clever way of testing things with a boolean ... e.g. STEP1 : (A>B*1)+2 will go to step 2 if false but step 3 if true. Anyways I need less help with programming and more with a simplified formula. Thank you math Team - I have exhausted my options for days on ChatGPT. Obviously, I can compare gear 1 tooth 1 to all 14 teeth on gear 2, and so on for all 12 teeth on one gear for 168 comparisons, would take lots of manual coding I think there must be a way with angular pitch ratios etc. Cheers !
<Moderator note: moved from a technical forum>
If one gear has X teeth and the other Y teeth, Y>X, and we start at an aligned pair, stepping to the next tooth of each in the same direction discovers a separation of ##2\pi/X-2\pi/Y##.
Repeating N times, the separation grows to ##N(2\pi/X-2\pi/Y)##, though at some point this will exceed ##|2N\pi/X-2(N+1)\pi/Y|##.
If this brings us to the randomly chosen pair of near-adjacent teeth, with a separation of ##\theta##, then ##N=\frac{\theta}{(2\pi/X-2\pi/Y)}##.
You can obtain a similar expression for the other case. The challenge then, if I understand the task, is to find the lower of the two values for N.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
