Finding current when voltage peaks in an RLC circuit
14 replies · 5K views · last reply
Stingarov
Information given:
Resistance=105 ohms, , XL= 212 ohms, XC= 93 ohms
V rms is 143 Volts.
Frequency of the circuit is f. Not defined.
Information Solved for:
Impedance (Z) = 158.7
I rms=.901 Amps
Phase angle = 48.58
The final question, which I cannot solve for some reason, is this:
At the instant the voltage across the generator is maximum, what is the current I?
I know that the current will be less than maximum as it lags in this case, but I don't know by what factor or how to compute it from here. Any suggestions?
tan(theta)=(XL-XC)/R
Vmax=ImaxZ=2^1/2*V rms
Z= (XL - XC) / R
I have tried everything here and it's been pathetic so. I tried using the angle difference from 45 degrees (3.58) as somehow why I will not be maximized as the current is out of phase with V. This was wrong. Any suggestions?
Stingarov said:
Information given:
V rms is 143 Amps.
I rms=.901
Phase angle = 48.58
Does fixing your typos help you solve the problem?
Not so far.
Stingarov said:
Not so far.
Let me re-phrase.
Would your fixing your typos in your post help us to help you to learn?
I don't even know where to start here, do you have a diagram you could post of the circuit for us?
Does [tex]v(t)= \sqrt{2}V_{rms}sin( \omega t)[/tex] say anything to you? Is this given in the problem? Or has your teacher said this is the signal you can use in all of your calculations?
Kruum: It was not given in the problem; it *is* relevant in the next problem, but I don't think in this one.
As far as the circuit goes, It is a simple: Generator----R----L----C----(return to Generator) circuit.
berkeman: aside from putting amps where I should have put volts, I don't see any other typos.
You don't need the frequency or the time. All you need to know that sin(90) is 1. But since it's not given or you can't assume that is the signal, it's no use then, obviously.
I don't see how I can use the reactances when I'm given neither the L or C values. I result in variables Lf or Cf either way, as the equations are XL=2pi*fL , and XC=(2pifC)^-1, respectively.
Yeah, I was abit too hasty. I remembered the values were given, but it was only the reactance. But you really don't need that info as I wrote above all you need is the fact that sin(90) is 1. So [tex]i(t)= \sqrt{2}I_{rms}sin(90-48.58)[/tex] sould be the value for current. But if you can't assume that is the signal, then it's no use.
It is indeed the signal. I tested this and it was correct. Thanks. However, I would like to know why this assumption is valid? It doesn't seem so apparent to me.
Which assumption, that the signal for the voltage is what it is or the signal for the current?
The assumption that it 2pi*ft = 90 (= 1 when computed in sin). I know the phase angle, and I know that v(t)=Vmax*sin(2pi*ft + phase angle), but that doesn't give me a logical pathway to i(t)=Imax*sin(2pi*ft - phase angle) nor describe why 2pi*ft = 90.
In other words, my book does a poor, poor job of explaining this relationship.
You probably have had some trigonometry and you know that [tex]\frac {\pi}{2}=90^{ \circ}[/tex] and [tex]sin( \frac {\pi}{2})=1[/tex]. So [tex]2 \pi f*t[/tex] must give us [tex]\frac {\pi}{2}[/tex] in order to get the maximum voltage, right?
Now, the phase angle is quite a bit more complicated story. But basically it's due to the physical properties of the capasitor and the inductor. The inductor creates a magnetic field, which tries to oppose the rise of the current. And the capasitor, on the other hand, is gathering pontetial difference between it's plates. So the faster the potential of the capasitor rises, the faster the electrons has to go from plate to plate, thus stronger the current.
Does that help?
That helps quite a bit. Thanks for the in-depth explanation. That's what I was looking for.
