Finding direction vector from symmetric line equation
6 replies · 3K views · last reply
Superdemongob
1. Question:
Find the directional derivatives of f(x, y, z) = x2+2xyz−yz2 at (1, 1, 2) in the directions parallel to the line (x−1)/2 = y − 1 = (z−2)/-3.
2. Solution:
We have ∇f = (2x + 2yz)i + (2xz - z2)j + (2xy - 2yz)k.
Therefore, ∇f(1, 1, 2) = 6i - 2k.
The given line is parallel to the vector v = (2, 1, -3).
The corresponding unit vectors are u =  ± 1/||v|| and v = (±1/√14)(2, 1, -3).
For the directional derivatives we find f'u±(1, 1, 2) = ∇f(1, 1, 2)dot(u) = ±18/√14
3. My Questions:
The only part of this that I have no clue about is how do they get the vector v from the information given.
Could someone please explain how they find that direction vector?
I get that since the lines are parallel the direction vector is the same but how does one find the directional vector?
Any help is greatly appreciated.
Thanks.
Hi Superdemongob! :smile:
Superdemongob said:
… the line (x−1)/2 = y − 1 = (z−2)/-3.
the (x-1) (y-1) and (z-2) are only there to make sure it goes through (1,1,2)
if it went through (0,0,0) instead, the line would be x/2 = y/1 = z/-3,
which is the vector v = (2, 1, -3) ! :smile:​
I get what you mean but how do you know that that is the directional vector?
Like what is the method for finding out?
If the question had the line 2(x−1) = y − 1 = -3(z−2) then how would the directional vector be different?
Sorry but I'm really trying to understand this.
In that case, the line would still go through (1,1,-2),
but the direction would be parallel to the direction 2x = y = -3z,
to which the solution is (x,y,z) = (k/2,k,-k/3) for any value of k,
ie the line containing the vector (1/2,1,-1/3) :wink:​
I think I finally get it.
You take the inverse of the coefficients and that is your directional vector?
yes,
and you can check it works because …
it's the only answer that gives you 1/1 = 1/1 = 1/1 ! :biggrin:​
thank you so so much.
i'm studying for a test and this helps a LOT.
thanks again.
