Finding equilibrium values from two differential equations in capital dynamics
6 replies · 2K views · last reply
beaf123
< Mentor Note -- thread moved to HH from the technical math forums, so no HH Template is shown >
Hi, I have already delivered the homework so my reason for asking is because I want to/ need to understand it.
I am at question d. I have found the two differential equations.
They are:
c° = -1/0,5 * ( f'(k) - 0,04)Ct
and
k° = f(k)-0,06kt -Ct
In equilibrium both c° and k° will be zero so both equations can be set equal to zero.
But how do you proceede from here, to find k* and c*? Can you set f'(k) = 0,25K^-0,75 + 2 since f(k) = k^0,25 and k(0) = 2?
If I have explained it too bad I can elaborate. I hope someone can help me:)
Hi, I have already delivered the homework so my reqson for qsking is becquse I want to/ need to understand it.
They are:
and
The posted images are too small on my screen, and I cannot enlarge them. My eyes are not as good as they once were, so your images are unreadable to me, reading glasses and all. If you post larger images or---better still---type it all out (as per PF standards), then I will be willing to help.
I have answered until c),
question d) is:
d) Find the equilibrium (k* c*).
And its here I am struggeling. I have my two equations, and all the needed numbers, so all I want to do is solve the two equations for C and K.
They are:
and
If ##c^{o}## means ##dc/dt##, etc., and if your two differential equations are correct (I have not checked) then the answer to your questions is YES. You need ##dc/dt = 0##, so if ##c \neq 0## you need ##f'(k^*) = 0.04##. Thus, you can determine ##k^*##. You also need ##dk/dt = 0##, so ## 0 = f(k^*) - 0.06 k^* - c^*##, so you can determine ##c^*##
Thank you. I found a mistake in my differential equation. It should be:
c° = -1/0,5 * ( f'(k) - 0,10)Ct
So this gives:
f`(k) = 0,10
0,25k^-0,75=0,10
k^-0,75=0,4
k=0,4^(-1/0,75)
k*= 3,393
which again gives
c*= 3,393^0,25-0,06(3,393)
c*=1,153
Thanks again for the help. Would you get the same answer if you inserted ct = f(k) - 0,06kt into the first equation?
So this gives:
f`(k) = 0,10
0,25k^-0,75=0,10
k^-0,75=0,4
k=0,4^(-1/0,75)
k*= 3,393
which again gives
c*=1,153
Try it for yourself!
